Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-16-2011, 01:37 AM   #5881
M7H
M7H's Avatar
Originally Posted by SpeedFreakNL View Post
On the FW518 I used before I did not have the problem and the cut-off kicked in right.
I removed the battery form the car, pluged it in the charger (Graupner Ultramat 16) and before charging I did measure the voltage of the cells.
Than charged it quickly and within a few seconds it was above the 3.2Volt/Cell
So luckily the battery survived
*The following description is for your own risk*
If your charger does not want to charge your lipo anymore, because of low voltage, there is a very easy way to get it above 3V/cell again.
Put your charger in NiMh mode, and charge the battery, with the lowest current setting possible, 0.1A if possible. Charge your Lipo on this setting, for a brief moment, and watch the voltage of your pack during charging. When it gets above 3V (per cell), stop charging, switch the charger to Lipo mode and start your normal Lipo charge program.
I set mine at 3.2Volt/Cell. So when the 2 cell pack drops below 6.4 Volt for more than 2 seconds the Cut-off should kick in right?
Yes, but only if you set it at the preprogrammed settings. If you choose the "custom" setting, and want a cutoff of 3.2V/cell, you need to set it at 6.4V
Serpent
M7H is offline   Reply With Quote
Old 08-16-2011, 02:20 AM   #5882
TryHard's Avatar
I've done this myself as well, it does work to bring a pack back if the charger doesn't want to accept it. However, just need to remember to switch back to lipo mode as soon as the voltage is right!
Old 08-16-2011, 03:19 AM   #5883
COBRARACING's Avatar
The safest way to bring back lipos to above the cut off voltage is to do the following
2s lipo charge with 1s setting with no balance lead for a max 10 minutes
3s lipo charge with 2s setting with no balance lead for max 10 minutes.
4s lipo charge with 3s setting with no balance lead for max 10 minutes
and so on
then use the proper function to full charge the packs .
I dont recommend nimh setting .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-16-2011, 04:39 AM   #5884
M7H
M7H's Avatar
A 2S lipo, of 2.5V/cell, will give an over voltage error on a 1S charge setting.....
A completely dead Lipo, will have a huge internal resistance, and will even on a low current of 0.1A quickly rise above 4.2V/cell, I've even seen 6V!...
But because it was dead already, it will not explode, or what so ever, because there is no juice left in it anymore to give such a reaction!....
Serpent
Old 08-16-2011, 04:52 AM   #5885
i had a customer who discharged his 7.4V pack waaaay too low (4.48V), under 1S it registered as too high voltage and at 2S, it registered as too low voltage.
Yup, go into any other non-lithium battry profile, bring up the voltage back to 6V and you're good to go. No myths. Just do it, no ill effects assured.
cheapskate.brok is offline   Reply With Quote
Old 08-16-2011, 05:17 AM   #5886
i am just giving you information from my long testing a good charger will work that way as i mentioned .
Old 08-16-2011, 07:14 AM   #5887
Yes, is wat al sugestud setting and not a custom setting.
Thanks.
SpeedFreakNL is offline   Reply With Quote
Old 08-16-2011, 07:21 AM   #5888
rai
Made a stupid mistake before where I forgot to plug off the battery connector from the battery. I am one of the guys who like to connect my cooling fan directly to the wire that leads to the battery. It was left on for 2 days before I realised it. Battery went bloated and could not be charged using normal function. Again what I did, I charged it using NiMH function for a few minutes before charged it again using Lipo function. Battery was ok until now. The real stupid thing was the battery was only a couple of weeks new.
Nowadays, I checked the car twice to make sure I really did plug the battery connector off the battery.
rai is offline   Reply With Quote
Old 08-16-2011, 08:18 AM   #5889
Hi,
I am trying to change my esc from stock to mod.....but nothing happens?...green esc lights up in the box on the screen to say its connected?
also what mod firmware should i go for?.....its for a electric motorbike,using a speed passion 6.5T motor,want smooth power delivery.....
thanks simon
sunktothenutz is offline   Reply With Quote
Old 08-17-2011, 12:48 AM   #5890
Hi,
managed to get firmware changed,but went for V1 508 no timing...is this any good?..like i say just want very soft/smooth power delivery.....
Old 08-17-2011, 01:54 AM   #5891
The best thing to do is never leave a battery in your car, I always stock my battery packs in a proper paddded suitcase
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-17-2011, 02:28 AM   #5892
WildManDriving's Avatar
Trader Rating: 27 (100%+)
Awhile ago now I reverse plugged a battery to my XERUN 120A v2 and tried to send it in for repair just to have have it return to sender. I now have a second 120A v2.1 speedy that keeps losing calibration. I would like to try and send both of these in for service/repair, what is my best option?
Thanks,
Michael.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 08-17-2011, 05:46 AM   #5893
whats the difference between the v2.0 and v2.1
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-17-2011, 07:22 AM   #5894
rai
Yeah it was a lesson well learnt. Guess at that time I was in a rush and was tired after setting the car up in the middle of the night..Dont want to repeat mistake twice...hehehe
Old 08-17-2011, 09:30 AM   #5895
Right,gone to the 528 mod software for my bike..........can anybody give me a clue as to the softest settings???...
simon
