Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 08-14-2011, 06:55 PM   #5866
COBRARACING's Avatar
Originally Posted by RC MARKET View Post
They Pre-order only !
but instock now !
Dear Rc Market
This is not the place to advertise any other brand but the hobbywing product .This site is for information and setups for hobbywing only .
I hope you understand if you want sales please advertise on the side advertisements offered by rc tech .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-14-2011, 06:57 PM   #5867
Originally Posted by cheapskate.brok View Post
is that the V3?
No it's not the V3 the V3 has a smaller footprint and totally different electronics thats all i can say for now .
Old 08-14-2011, 08:30 PM   #5868
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Vrooom View Post
Hey all. i run HW 17.5 motor with xtreme stock ESC, with 110119 firmware on it, using hobbywing USB link v1.63
2in1 program box are v1.07_110119
ESC are HW427_1.0
The boost start RPM and boost timing ACC are greyed out.. with 1000 rpm(*) in it and 50rpm/deg(*)
any idea why its greyed out ??
You have 119_MOD on it, look for either 119_Stock or 211_stock.
defcone is offline   Reply With Quote
Old 08-14-2011, 08:42 PM   #5869
venom54's Avatar
Default XTREME STOCK
Played this weekend and happy with a set up tried for the 13.5 1/10 TC class here. Car stonking fast with very good acceleration!!!! Driver crap (Too fast for his ability)!
XTREME STOCK setting for 13.5 (TEAM POWERS PLUTONIUM 13.5) using a 4000 40C pack. Software 211.
Track #4 Reversed on TFTR site.
Air temp 19C, track temp average 22C. Motor temps stayed below 71C.
HW EXTREME settings as listed below
1 - 1
2 - 1
3 - 4
4 - 9
5 - 87.5%
6 - 100%
7 - 0%
8 - 6%
9 - 45
10 - 12
11 - *1
12 - 19
13 - 7000
14 - 0.4sec
15 - 450
Hope this helps for any one looking for a starting point.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 08-14-2011, 09:53 PM   #5870
wow i just had an orgasm
Great job!
cheapskate.brok is offline   Reply With Quote
Old 08-15-2011, 12:35 AM   #5871
Sir Tamiyalot's Avatar
yes it can run on the 120 amp
I know you said it can handle a 550 motor but can it handle a 4.5t novak 550 or is that pushing it to hard?
OFNA NEXX10, Schumacher CAT SX3, Mugen MBX6 Eco.
GOODWOOD OFF ROAD MODEL CAR CLUB
Sir Tamiyalot is offline   Reply With Quote
Old 08-15-2011, 04:54 AM   #5872
I run the FW 119_stock. With a 10.5 SpeedPassion V3 motor an 2cell Intellect battery (5600 amp)
This weekend I had one session where the Lipo-Cut off failed. Normally I stop before the cut-off need to kick in.
I set it as 3.2V/cell.
But the Voltage on the table was 2.8V/cell.
So under power it was even less.
I heard some other people with problem with the cut-off.
How are the experiences here?
Or tips that my lipo's don't get these low voltage anymore.
Thanks.
SpeedFreakNL is offline   Reply With Quote
Old 08-15-2011, 05:16 AM   #5873
JRXS_chris's Avatar
Maybe under load the cells dropped below that voltage
JRXS_chris is offline   Reply With Quote
Old 08-15-2011, 05:16 AM   #5874
It might help to move to the newer version.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-15-2011, 07:02 AM   #5875
Yes that was the fact, and the lipo cut-off didn't kick in.
I set the cut-off at 3.2Volt / cell. (Lipo should not go lower as 3.0Volt/cell without load)
I picked the car form the track and measuring on the charger at pit table give me the 2.8Volt/ cell. So without load. And is below the lipo cut-off
Under load I think it was even lower...
Luckily the charger recharged them.
You mean the Firmware version. I just changed tot the FW119_stock. And this gives me the problems.
What would be newer?
Old 08-15-2011, 09:21 AM   #5876
TryHard's Avatar
It's odd you've had this issue. I set my LiPo cutoff to exactly the same on both 119 and 211 software, and never had the issue of the cutoff not kicking in right. That's even running modified motors too (with boost....speeeeeed ).
What were you using to measure the cells after the run?
| THard.co.uk | Xray | MuchMore |
Old 08-15-2011, 10:42 AM   #5877
Try 211
Old 08-15-2011, 05:11 PM   #5878
yes it can run a 4.5T 550 motor but zero turbo function to be safe .
Old 08-15-2011, 05:13 PM   #5879
Thanks.
Its never happened ive never heard of it happening to anyone else with the lipo cut off but there's always a first .
Please download 211stock and try that .
Old 08-15-2011, 11:31 PM   #5880
On the FW518 I used before I did not have the problem and the cut-off kicked in right.
I removed the battery form the car, pluged it in the charger (Graupner Ultramat 16) and before charging I did measure the voltage of the cells.
Than charged it quickly and within a few seconds it was above the 3.2Volt/Cell
So luckily the battery survived
I have to note that we and the 2 other I mentioned with cut-off problems use our Extreme Stock for RC drifting. But looking at voltage that shouldn't make any difference I suppose?
I set mine at 3.2Volt/Cell. So when the 2 cell pack drops below 6.4 Volt for more than 2 seconds the Cut-off should kick in right?
I like to sick to the FW119 because of the turbo settings.
Because with FW221 the turbo kicks in after full timing is applied (and full throttle ofcourse)? Right?
So I don't whant that to hapen mid drift. I want control that with full throttle only. So that is what FW119 is supposed to do right?
Because we are drifting. And have hard slippery tires. Should we compare to the sugestud setting for touring car or off-road?
Thanks for all the advise!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
