Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-23-2011, 08:25 AM   #5701
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Hpi 1 is version 3 and it about same size as a tekin
Craig W is offline   Reply With Quote
Old 07-23-2011, 08:40 AM   #5702
Originally Posted by Radio Active View Post
Will the Hobbywing 120A 1S ESC work with a brushed motor?
The manual for the 1S doesn't say anything about brushed, but the manual for the SD says it will work.
I want to recommend the ESC to a 12th racer who wants to start by using brushed motors.
12th blinky 17.5 1S? I've been doing a little 17.5 boosted 12th, that's ok, once it winds out. The first time I put the car on the track, I hadn't dialed on any timing. I decided that was a bad idea after 2 minutes when I got sick of being punted out of the way by the plastic Tamiyas with the kit motors. I found it seriously slow.
XERun ESC's are brushless only.
If your friend wants to run brushed motors to start, have him buy a GTX, or GTS off of ebay for $20. They are good reliable brushed motor speedo's. (And really light weight too). the 120A is also a really heavy ESC, might be better off with a Xtremestock and a booster, for less weight. My car wights 820grams ready to run (about 90 over the minimum).
To be fast with 1S, you need to be really aggressive with your settings. I did run blinky 17.5 against boosted 17.5 before I got my 1S HW ESC, and the difference was about 1 second a lap! (on 11-12 second per lap)
Good luck with your 1/12 racing, keep everyone posted on how you are making out. Not enough of us on this forum run 1S 1/12!
Cheers,
Shawn.
Shawn68z is offline   Reply With Quote
Old 07-23-2011, 05:38 PM   #5703
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by =FLIP= View Post
how do you know?
i just do!!!!!!!
anyway i might look into the hpi esc now that i just destroyed my xtreme...
oh well VTA here i come lol
but am interested in the orion.....now that i just had a closer look....will fit nice on my t3'11
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 07-24-2011, 01:24 AM   #5704
Trader Rating: 15 (100%+)
hey guys how much timming is there in the hw 10.5. and is there endbell adjustment cheers
jay m is offline   Reply With Quote
Old 07-24-2011, 02:26 AM   #5705
COBRARACING's Avatar
No end bell adjustment and fixed at 18-22 degree.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-24-2011, 02:28 AM   #5706
The V3 will be released as the hobbywing brand not any oem brand for atleast the first 6 months of the release and maybe longer .
Old 07-24-2011, 10:23 AM   #5707
Running on a 20x14m circuit with 8ft wide lanes.. Xtreme stock speedo, team powers 13.5 motor
what firmware, gearing and settings should i be looking to run as right now I'm seriously struggling with the motor getting hot and dropping off around the 3 minute mark.
Team Xray:::Team Powers:::Hobbywing Xtreme Stock::: Savox:::Ko Propo III:::LRP
Xray2011 is offline   Reply With Quote
Old 07-24-2011, 10:36 AM   #5708
Craig W's Avatar
119/211
fdr 6.9 to 8.00
Drag Brake : 15%
Voltage Prot: 3.2 V/Cell
DRRS Punch : 6
Brake Force : 87.5%
REverse Force : 100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 36
Turbo Slope : 18
Turbo Timing : 21
Start RPM : 4000
Turbo Delay : 0.3 s
Timing ACC : 450
Old 07-24-2011, 11:02 AM   #5709
Thank you Also if i continue to struggle against the Tekins for out of the corner punch. What can be changed to make it better? Cheers
Old 07-24-2011, 01:08 PM   #5710
Craig W's Avatar
increase ddrs turbo slope
reduce timing acc to 350 250ish
increase turbo timing
there some ideas
Old 07-24-2011, 08:42 PM   #5711
K_Takuya's Avatar
Hi..
I have a problem here..
Yeasterday i ran my xerun 120A ( upgraded to 4 caps) with HW 10.5 motor. Settings is just around the default.
a) After 4 pack of batteries (ranging from 40C to 50c type), all is o.k including temp.
b) For the 5th pack, i used a 65c lipo, then the problem start. the battery only last few rounds at the track but the capacity is 6000mah. i thought maybe forgot to charge but the next battery behave the same. dried out too fast. less than 5 mins.
c) bring back to the bench and try to full throttle a few times (boost/turbo kick in) but after several full throttle.. power seems very low for few sec (like 1/5 of throttle) and suddenly boost/turbo kick in.
d) brought home and reflash and change sensor cable.. problems still happen.
e) left the car for few hours then try again, problem seems gone.
Question.. what may cause the problem? i would like to prevent that before going to the track again...
Thank you.
Bodyshell+kit+bateri+remote+receiver+tayar+rim+esc+charger = Jom main!
K_Takuya is offline   Reply With Quote
Old 07-25-2011, 02:08 AM   #5712
Originally Posted by K_Takuya View Post
Hi..
Thank you.
This problem Sounds similar to mine... Can't remember having an overheating problem with my 50c battery but with the 65c fat cobra the temps are high and dying around 3 mins in... Also Had sensor trouble being intermittent between sensored and sensorless but a New lead appears to have sosted this.
Old 07-25-2011, 02:30 AM   #5713
Barry_Hughes's Avatar
there some ideas
Surely increasing turbo timing will not help with punch out of the corner - on 211 boost is added first then turbo.
try a lower gear ratio (smaller pinion)
increase ddrs (but this might make the back end loose!)
Also it might be your start boost rpm is too low, making the motor bog down, try raising to let the motor spin up on the torque/gear ratio the the boost comes in and keeps it all going. (try driving a real car and pulling away in high gear it is slow til the motor gets in the torque/rev band for the selected gear)
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 07-25-2011, 03:09 AM   #5714
Trader Rating: 17 (100%+)
Hi All,
I have just started to run a X12 13.5 with the extreme stock speedy, in my last race I achieved a track record and the car was nice and fast but came off at 114 degs C. Air temps were around 11-12 degs C
the track is a mix of fast straights and technical infield with a lap time of around 14secs, these are the settings I was using
211 firmware
MI4 CX
FDR 6.95 85spur 22 pinion
4: DRRS 6
9: Boost timing 40
10: turbo slope 12
12: Turbo Timing 18
13: Start RPM 6000
14: Turbo Delay 0.3 sec
15: Timing ACC 400
any suggestions to get the temps down?
Have been using the hobbywing 13.5 with these settings, it was not as quick but coming off the track after a 6min race at around 75-77 Degs
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 07-25-2011, 03:13 AM   #5715
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by lethallee69 View Post
Hi All,
211 firmware
MI4 CX
4: DRRS 6
9: Boost timing 40
10: turbo slope 12
12: Turbo Timing 18
13: Start RPM 6000
15: Timing ACC 400
Leigh,
THe X12 has a large amount of timing inbuilt in the motor compared to the Hobbywing. Turn down some timing
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
