Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-05-2011, 02:12 AM   #5521
Trader Rating: 15 (100%+)
thankyou cherry2blost makes it very clear cheers
jay m is offline   Reply With Quote
Old 07-05-2011, 02:15 AM   #5522
COBRARACING's Avatar
Originally Posted by 2wdrive View Post
Copying an expensive product from LRP or something i would understand but what is the world comming to when chinese are copying their own products! .
yes i agree whats the world coming to but i guess its called easy money the Asian way .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-05-2011, 02:16 AM   #5523
M7H
M7H's Avatar
For comparisation, last weekend I managed to get a good exploded view of a 1S ESC , thank to 2wdrive for the pictures:
http://img694.imageshack.us/img694/8569/p1040661j.jpg
Serpent
M7H is offline   Reply With Quote
Old 07-05-2011, 03:45 AM   #5524
Funny, if they can copy. They should start their own brand. Is this the fake one is make by HW too? So they can cover the lowest end market too???
ioxqq is offline   Reply With Quote
Old 07-05-2011, 04:13 AM   #5525
I just dont think hobbywing would do that .They are really worried about it
Old 07-05-2011, 05:39 AM   #5526
rai
Default Any suggestions?
Just to share and at the same time need opinions and suggestions from anybody. I am using a LRP x12 10.5 T stock spec motor and here are the settings:
FW: stock 119
1: 1
Drag Brake : 15%
Voltage Prot: 3.2 V/Cell
DRRS Punch : 6
Brake Force : 100%
REverse Force : 25%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 33
Turbo Slope : 18
Turbo Timing : 24
Start RPM : 5000
Turbo Delay : 0.3 s
Timing ACC : 550
FDR : 7.2
Temp motor: 89 C
Surround Temp: 37 C (Varies)
Track has approximately 45 m long straight with technical infield with two sweepers (can also watch the video : http://www.youtube.com/watch?v=03Ls29mv4hA to get an idea of the track).
Outcome from this setting: Still haven't get the right kick from the speedo esp in the straight without gaining heat on the motor. Any opinions are kindly appreciated. Thanks.
rai is offline   Reply With Quote
Old 07-05-2011, 06:09 AM   #5527
M7H
M7H's Avatar
With the X12, you should really try the 101224_STOCK Firmware.
Drag Brake : 0%
DRRS Punch : 3
Brake Force : 100%
REverse Force : 100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 18
Turbo Slope : 1.5
Turbo Timing : 6
Start RPM : 5000
Turbo Delay : 0.4 s
Timing ACC : 600 (or 450 if outside temp goes down)
Roll-out 45mm, (don't know how to convert this to FDR.)
This is the setting I use with my Pro 10, TC is a bit heavier, and has more drag, but I think it's a good startingpoint.
Don't forget, always use the 4 dots timing insert in the motor.
Serpent
Old 07-05-2011, 07:32 AM   #5528
bigodedonato's Avatar
Originally Posted by JKL1031 View Post
this should be fine for a while. Are you running outside in the sun? Also you know you listed the ratios you've tried from short(cooler) to taller(hotter). Go back with the 6.89-7.34. Play with motor end bell timing if you have to.
I´m using HobbyWing 17.5T motor, and it doesn´t have the end bell timing to play with..
I tried those ratios and ESC timing as well (0 - 55). The temp still up high.
Any suggestions?
Does anyone know which is the default timing of this motor?
bigodedonato is offline   Reply With Quote
Old 07-05-2011, 03:08 PM   #5529
rai
Drag Brake : 0%
DRRS Punch : 3
Brake Force : 100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 18
Turbo Slope : 1.5
Turbo Timing : 6
Start RPM : 5000
Turbo Delay : 0.4 s
thanks for the reply... I used the 4 dots timing insert in the motor yet the temp is still higher.
Sorry but what is the difference in using 119 stock and the 224 stock FW? dont quite get it yet...
Old 07-05-2011, 03:38 PM   #5530
Any suggestions?
18degree fixed.
Old 07-05-2011, 03:59 PM   #5531
M7H
M7H's Avatar
they seem to have the same settings, but the 224 and the X12 is a very nice combination!
224 was the first of the new generation of firmwares, and was never released officially, but it rocks with an X12!
The difference, just try it.....
With 1S lipo in 12th scale the difference is incredible, with 2S it is less, but you will have less motor heat and more punch and speed.
Serpent
Old 07-06-2011, 03:57 AM   #5532
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
were can I get 224 from
Craig W is offline   Reply With Quote
Old 07-06-2011, 04:11 AM   #5533
cherry2blost's Avatar
All the firmwares are here ----------> Hobbywing ESC Settings ONLY
It is what the thread was set up for
I know it's a bit naughty to do it here but wanted to let you all know that we are now importing the entire Eagle Racing line of Hop ups and Electronics including the Awesome Eagle Racing 6000 65C+ LiPo's which we will be entering for BRCA in the next round in September, we are in the process of having the 8.5 to 5.5 XERUN Modified Motors BRCA Approved as we speak. As you all know the Blue 13.5T is already on the BRCA Approved list. If there is a demand we will put the 10.5 and the 4.5/3.5 through as well.
Am I being unreasonable in asking for a 20% restock fee to exchange a motor someone bought in error, but the unit has been opened? Feedback anyone??
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 07-06-2011, 05:34 AM   #5534
would the 224 FW work with a X12 17.5T?...what are the benifits??
sunktothenutz is offline   Reply With Quote
Old 07-06-2011, 06:54 AM   #5535
rai
Will sure try it. Big thanks...
