Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 07-04-2011, 02:45 PM   #5506
JKL1031's Avatar
Originally Posted by bigodedonato View Post
hello guys
I'm trying to hit a motor hw, and I'm having problems, our track is + - 270 meters and the main straight is 40 meters, and the engine with about 3 minutes reaches 92.7 C, would you have idea what's going on?
I tried to talk about the relations q, along with various settings xtreme stock esc
I began with, 8.0, 7.93, 7.34, 6.89, 6, 69, to reach 5.25, the FDR And no, heated up with all these
now esc
I'm with the 518 because the 211 even more heated, this was the best I could leave but decided not too
DRRs 7
brake force 50
boost timing 8
turbo level 7
start 6000 rpm
delay 0.4
timing punch -3
with the 211 I was just
6 DDRs
brake force 50
boost timing 40
18 turbo slope
24 turbo timing
start 4000 rpm
delay 0.3
350 acc
relations with all this and has not worked after 6 minutes is the 136c
I tried with the 211 timing from 34 to 45
fastest turbo slope up from 24
I've been timing with 45 non turbo boost then he walked next to 90c but not rode anything was final, even with the 6.6 FDR
I tried to start from 3000 until 9000, but to no avail he was powerless, and so had he entered the turbo, i put 150 acc, but improved heated back up
on the bench he consumes 3.67 ah, testaei that too, to see if there was engine trouble, but 4 engines tested, because I bought 5 of them, and all give the same problem, so it's not supposed to be the engine, and tested 2 xtreme stock, q I q same thing, but do not know how to solve it, or if this engine goes hot even
I wish someone would help me with this engine, because I have work to hit, and also tested a novak, and I did not have any problem, he's cold about 78C in the final eight minutes and walk strong, but how we define hw as a mark of our league, we already have drivers for all motor
Thank you and look forward to some help from you
Excuse my English, I do not speak well, then turned to google translator, q hopefully understand what I mean !!!!!!!!!!
this should be fine for a while. Are you running outside in the sun? Also you know you listed the ratios you've tried from short(cooler) to taller(hotter). Go back with the 6.89-7.34. Play with motor end bell timing if you have to.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 07-04-2011, 02:59 PM   #5507
M7H
M7H's Avatar
Originally Posted by cherry2blost View Post
However our own testing of the 13.5's has been under load at 54,000 RPM,
I know, I've seen 44,000 from HW motors, but I do agree on the torque side, they like to rev.
I run LRP X12 10.5T, combined with 101224 FW, which is more towards torque, but really fast!
Serpent
M7H is offline   Reply With Quote
Old 07-04-2011, 05:11 PM   #5508
COBRARACING's Avatar
Originally Posted by Hazar View Post
I used the 211 Stock version on last Sunday. (v2.1 120A / 13.5T) Just wow, loads of torque at low end, blazing speed on straight. I love the ESC but motor bearings seems not last very long. I think to change these to ceramic ball bearings.
Thanks Hobbywing for that quality product and Cobra for your support.
thank you for your kind words Hazar i will pass on your recommendation to michael were he will consult with the motor factory about the bearings .
I will be in turkey next year end of june so i would like to see your tracks and maybe attend a race meeting .
regards Angelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-04-2011, 05:14 PM   #5509
Originally Posted by mcdoogle View Post
Thanks for your quick reply, i will test it at the weekend. I race indoors as well and that has a 30m straight, the rest is fairly tight and technical but still flowing, would you change any settings for this ?
30 m straight say a shorter delay bringing on the turbo quicker and maybe change the slope to ramp up the timing quicker as well .maybe also some less rpm start say 3000 rpm so it ramps up sooner
Old 07-04-2011, 07:21 PM   #5510
cherry2blost: Thank you so much for taking time to answer all the questions!!
You said: You say Boost Timing doesn't affect the top end by much more than 20%, I refer you back to our results the 13.5 with a kV of 2500 has a non boosted RPM max of 21000 RPM, yet with Boost we are achieving 54000 RPM, Hobbywing have destruction tested 11.5's at over 100,000 RPM !!! So, on that point buddy you are barking up the wrong tree.
I use 119 software and 4.5 motor. I have tested to to shut down the turbo and increase the boost to the max. I wanted to get a smooth throttle profile. I see the top end is really a lot slower with no turbo kick in. It is day and night different. So, I forced to turn on the turbo and set the turbo as liner as possible in order to be fast enough on straight. BTW, my motor temp is like 65c.
On the track, it is reacting different then numbers. Andy idea?
ioxqq is offline   Reply With Quote
Old 07-05-2011, 01:29 AM   #5511
Default Fake Hobbywing Xerun 120 amp and 60amp
Dear Customers
I am listing some photos of the fake xerun 120 and 60 amp esc's which were found in taiwan .We dont think they have been manufactured in Taiwan but more in china .
If anyone has a product that looks similar to the fake product please email me at teamcobraracing@gmail.com.
Not only do we have to put up with the fake ezrun series but also the xerun now when will it ever end .so be very careful when you purchase your product especially from ebay stores located out of hong kong .They also have ebay stores with uk listings but they are actually hong kong .
Im sure from the photo's you will be able to pick the fake product.
regards Angelo
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun-120a-3.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-bottom.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-capacitor.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-esc3.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-esc.jpg
Old 07-05-2011, 01:32 AM   #5512
Default more photos
more photos
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-sensor.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-switch2.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-switch3.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-switch4.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-switch.jpg
Old 07-05-2011, 01:37 AM   #5513
Default more photos of fake product
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-wire.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun-120a-2.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun-120a-3.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun-120a-4.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun-120a-5.jpg
Old 07-05-2011, 01:39 AM   #5514
Default last photo
last photo
Old 07-05-2011, 01:44 AM   #5515
steliosh's Avatar
Originally Posted by COBRARACING View Post
Dear Customers
regards Angelo
Hello Angelo!
In 5th pic, black one is original? The one with cables shown as A+B-C, while the blue one with ABC+- is fake?
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 07-05-2011, 01:45 AM   #5516
cherry2blost's Avatar
For a start I hope you are using the MOD software and not the STOCK version as that is totally the wrong software to use with a 4.5T.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 07-05-2011, 01:55 AM   #5517
Bishop's Avatar
Originally Posted by steliosh View Post
Hello Angelo!
Actually HW used ABC+- on like version 2.0, and A+B-C on 2.1 onwards I believe, though I wish they had stuck with ABC+- myself.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 07-05-2011, 01:57 AM   #5518
M7H
M7H's Avatar
Hello Angelo!
I believe it is.
Also with the capacitors.
It's original against fake i believe, for comparisation.
If the black one is also fake, they really did a good job!...
Serpent
Old 07-05-2011, 02:08 AM   #5519
2wdrive's Avatar
Copying an expensive product from LRP or something i would understand but what is the world comming to when chinese are copying their own products! .
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 07-05-2011, 02:12 AM   #5520
Hello Angelo!
Yes the Black one is the Geniune product .
