Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 06-28-2011, 11:37 AM   #5446
Tekinpro's Avatar
hi ... can show me how to calculate the speed of the car from esc settings. i'm using the 119s Software hobywing....thanks
Tekinpro is offline   Reply With Quote
Old 06-28-2011, 02:33 PM   #5447
I really hope that most of the posts about rpm and loggers and how to work out rpms and such are not coming from anyone who designs and engineers any product I use - it would be concerning!!
You can do all these calculations, but they are useless for any meaningful comparison. In order for any of this to help you do anything meaningful, your data has to include corner exit speeds, drag, cell condition and throttle position. Without that, motor speed is irrelevant. We are not trying to get the most out of the motor, we are trying to get the most out of the car. If winning was about getting the most out of the motor, the best software would win. LAst time I looked, the best driver's won.
I regularly manage to pass other competitors on the straight with a slower car because my entry speed and line to the last corner are better than theirs, and I get a better terminal speed. Knowing the motor speed has nothing to do with that, having a better chassis has everything to do with it. And that's before we add in drag (for each extra mph required, you require double the power needed to get the last mph) and cell performance and throttle position and tyre condition and...
Get real guys. All these things are a compromise to each other in order that the car gets around the lap in the fastest possible time. If you don't understand how the triangle of ratio, boost and turbo work, start there. If ever Hobbywing decide to give you all this paraphernalia, can they please have an option to not have it, so I can get my stuff cheaper, and use it to pay for more practice time at the track to improve my driving?
SlowerOne is offline   Reply With Quote
Old 06-28-2011, 07:59 PM   #5448
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
the guy doing the firmware said it could be done but has not because he knows its worthless.
there is only one guy wanting the rpm logger,anyone else that mentions it is just having a little fun at his expense.
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 06-28-2011, 11:37 PM   #5449
COBRARACING's Avatar
Thank you for your post and i agree it takes more than just rpm of a motor it is setup of car ,tyres,track length,batteries and much much more I know irgo wants an rpm log within the esc but dont you think michael would have implemented it a long time ago if it was needed and worth the time .Rpm log is easy to design the software but there are other factors concerning michael like flash memory to store all this data the you get into multi level flash which is more expensive once again which sometimes is easily deleted from strong electric fields and heat do we really need this headache ?
Then it will be michaels fault for implementing the rpm log and temp log and so on and when the info all of sudden is lost then it's our fault and thats the reason why michael will not implemented it, the rpm log is easy to design but a headache to maintain.you get memory upsets and more .please someone correct me if im wrong i have studied alot of this but it has been a long time since ive opened a book .
When michael doesn't implement a feature in his software there must be a reason .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-29-2011, 02:39 AM   #5450
ShadowAu's Avatar
Its been a while for me too but its sounds like things like processor speed, flash memory and then interference are all factors... obviously there is not enough on board memory to doing anything practical and with the sort of frequencies and information that needs to be dealt with controlling the motor there just wouldn't be "time" to do rpm logging as well
On a different question I have a 60A that I think my cat has "modified" by knocking it off the shelf where it was stored... it still takes software and all the setting can be changed etc but it doesn't drive the motor... resetting it to the radio etc makes no difference... as its long out of warranty I pulled it apart but can't see any obvious damage anywhere.... any ideas?
and now the really stupid question... I have an SP 1.1... could i take the controlled board from the 60A and mix it with the FET board of the SP 1.1 if that turns out to be the issue?
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 06-29-2011, 08:23 AM   #5451
irgo's Avatar
fine, next is why i cannot import settings? instead export settings only???
Quark Force
irgo is offline   Reply With Quote
Old 06-29-2011, 08:48 AM   #5452
M7H
M7H's Avatar
I think putting them on paper, and "importing" them by entering the values with the lcd box is a lot faster then hooking it up on a laptop...
Don't forget, you can save 3 different settings in the ESC itself!
Serpent
M7H is offline   Reply With Quote
Old 06-29-2011, 01:37 PM   #5453
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Hi guys
Dont know if I put this in right part of forum but I was wondering if you could help looking for setting for xtreme stock with x12 13.5t running on tight 20x30mtr carpet track and fdr plz
Craig W is offline   Reply With Quote
Old 06-29-2011, 02:04 PM   #5454
Yo, got an EZRUN. Keeps cutting out after 5mins.
Running 4600mah ni-mh batteries.
Only setting I don't understand is:
8) neutral range
9) timing
10) over heat protection is on
thanks
PS. 60a version 2 speed controller and 5.5t motor.
Ian78 is offline   Reply With Quote
Old 06-29-2011, 04:08 PM   #5455
JKL1031's Avatar
8) neutral range
9) timing
thanks
eZRUN brushless system
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 06-29-2011, 04:44 PM   #5456
8) neutral range
9) timing
thanks
seems like a voltage cut off even though its only for lipo but five minutes sounds correct for the voltage to drop very quickly on your nimh battery especially running a 5.5T motor
Old 06-30-2011, 01:09 AM   #5457
What gearing are you running. Is the motor and or the esc really hot? Could be thermaling out.
scoop is offline   Reply With Quote
Old 06-30-2011, 04:19 AM   #5458
smilekt's Avatar
any new software will come out sooner?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 06-30-2011, 04:25 AM   #5459
Craig W's Avatar
hobbywing uk says 310 out but link not working
Old 06-30-2011, 04:26 AM   #5460
Craig W's Avatar
Hobbywing Software V 1.63 (110310) (310) ------> http://www.hobbywing.....63_110310.rar
