Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 06-24-2011, 05:39 AM   #5386
COBRARACING's Avatar
Originally Posted by AGNO View Post
Already available the new Xerun 160?
No its not the V3 the v3's footprint is much smaller and it's not available yet.Plus Hobbywing branding will have the first V3 .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-24-2011, 08:51 AM   #5387
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Is it the new orion or hpi flux
Craig W is offline   Reply With Quote
Old 06-24-2011, 09:55 AM   #5388
AGNO's Avatar
You think that the new Flux esc is made Hobbywing? I still not see image of new Flux, where I can find?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 06-24-2011, 10:06 AM   #5389
Craig W's Avatar
if you go into cyclone forum there is pic of hara car look at wire and fan
Old 06-24-2011, 11:14 AM   #5390
AGNO's Avatar
Hara said on its setup esc Hobbywing
Old 06-24-2011, 11:32 AM   #5391
Craig W's Avatar
I'll see if I can get picture of Andys car over next couple of week as I know there hpi flux in his car as well ayrton car as well
Old 06-24-2011, 11:52 AM   #5392
AGNO's Avatar
Would awesome
Old 06-24-2011, 12:50 PM   #5393
Hi,
On the 211 FW what would you adjust to give a bit more accelaration?
thanks simon
sunktothenutz is offline   Reply With Quote
Old 06-24-2011, 01:49 PM   #5394
Default 10.5 help
Guys ive been slogging through this thread but havent found what im after yet so i'll put it you all.
I've bourght a second hand xerun extreme stock, dont know what software and a GM 10.5. i was going to gear it at about 7.5 to 8 on an xray T008 to be safe but not sure where to start on the settings. The settings it comes with is with full 18 degrees of timing.
Any suggestions?
scoop is offline   Reply With Quote
Old 06-24-2011, 04:16 PM   #5395
TryHard's Avatar
What I can say for sure is that the flux's use the same software... Deduce from that what you will
When I popped back to the uk, spoke to with Andy, Ayrton, Jonny B and Elliot over settings at WLRC national. All of those are using either a Orion R10, or the pre-production Flux.
Old 06-24-2011, 04:24 PM   #5396
TryHard's Avatar
Originally Posted by sunktothenutz View Post
Hi,
thanks simon
Firstly, don't rule out trying a smaller pinion with your current settings, it's all a balancing act between fdr and the speedo settings.
In the software itself, for more acceleration, try a faster boost ACC figure, higher DDRS, lower boost start RPM. Try a few different things, keep your eye on the temps, and check the times and what feels best to you.
HiH
Ed
Old 06-24-2011, 04:29 PM   #5397
TryHard's Avatar
Any suggestions?
I'd start around 8 on the fdr, and then use the following;
DDRS: 9
boost timing: 40
start rpm: 6000
ACC: 400
Turbo timing: 15
Turbo ramp: 18
Turbo delay: 0.2s
The other settings adjust to suit. That will be pretty conservative, but a good base to start from. Should mention that would be for the 211 software, try and get someone to load that for you if you don't have a program box.
HiH
Ed
(and sorry cherry, will copy the settings advice over to the other thread later!)
Old 06-24-2011, 10:53 PM   #5398
All of HPI's new esc's are designed and made by hobbywing even the new waterproof unit they offer in the ready to runs .
Old 06-25-2011, 01:08 AM   #5399
Thanks a lot. Mine doesnt have half of those settings so must be something like the 518 software? But i can take bits from it and use those.
Old 06-25-2011, 03:48 AM   #5400
AGNO's Avatar
very interesting...
