Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-21-2011, 06:56 AM   #5356
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
anyone got a tc recommendation with a x12 10.5 on a large-ish 1/8 track
one 55 meter (180 feet)and one 50 meter straight,very wide open track with 180 deg corners.only one small tight section other wise its free flowing. i think guys running 5.5t mod are fdr 7 or less.
looking for a close fdr if possible as lhs are 10-18 bucks a pinion
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 06-21-2011, 07:13 AM   #5357
Bishop's Avatar
48 pitch?, I know two different AU based sellers with 6 packs for $20 or singles around $5.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-21-2011, 07:24 AM   #5358
ozzy-crawl's Avatar
yea i have a mate on holidays for a few days so trying to get a run in tomorrow
had the combo in my 1/10 pan car but going to tame that down a bit and give the tc a boost.(was 2s, 45mm roll out, 30 boost, 25 turbo,5000rpm start)
i have pinions to go from 8.2 up to 6.6 fdr or 4.5-4.0 nothing in between.but i am guessing i need in between that 6.5-7.5 ???
i was running 13.5 (no boost) at 4.0 and that was cool after 6 min
i dont race so i use the full track at gilston and like some top end speed
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
Old 06-21-2011, 08:01 AM   #5359
Bishop's Avatar
i have pinions to go from 8.2 up to 6.6 fdr or 4.5-4.0 nothing in between.but i am guessing i need in between that 5.5-6 ???
You know you may get away with around a 7 fdr, I was using like a fdr of like 7 when I was playing with mine and a SP 10.5 last year, though I read the hotter setups were in the 6 range from memory, around 7 was the original recommendation a half dozen firmware versions ago though.
QRCCRA
www.qrccra.org.au
Old 06-21-2011, 09:57 AM   #5360
JKL1031's Avatar
Originally Posted by radwerx View Post
Hi. I am running the V2.1 120A ESC on v211 software with a EPIC D3 17.5.
The track has a very technical infield and a 60 meter long straight after a short sweeper. I am finding that while in the infield my car is quite fast, on the long straight I am running out of steam about 1/2 way through. By the end of the long straight the Tekins are right behind me though I am able to pull away a bit in the infield where HW tends to have more low end pull.
Can someone help me with this? This is my setting at the moment which I felt gave the best temperature (after 8 mins) and best power. I am now looking for more top end speed. Infield rip is just nice at the moment.
FDR: 6.5
Endbell timing: 0 deg
Punch: 6
Boost: 35
Boost accel: 300
Turbo: 29
Turbo slope: 18
Delay: 0.1sec
Temp after 8 mins (90 deg C)
Have tried FDR 7.2 with the same esc settings and temps dropped to about 80 deg C but car was noticeably slower.
Originally Posted by defcone View Post
90 degrees is pushing it a bit isn't with the d3's?
Yes man, I wouldnt continue to run the car that way. I have the same equipment as you. Cant help with settings neither cause I dont know that much myself. I will however give you my set-up for an indoor track.
Endbell at 0 timing
FDR: 6.8
punch: 9
Boost: 45
Boost ACC: 50
Turbo: 19
Slope: 18
Delay: .1 sec
Sart RPM: 4000-5000
MY temps r still too high at 160, but this was practicing down a whole pack.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 06-21-2011, 10:04 AM   #5361
defcone's Avatar
Trader Rating: 15 (100%+)
Endbell at 0 timing
FDR: 6.8
punch: 9
Boost: 45
Boost ACC: 50
Turbo: 19
Slope: 18
Delay: .1 sec
Sart RPM: 4000-5000
Try the D3 setup on Speed Passion's site.
defcone is offline   Reply With Quote
Old 06-21-2011, 01:44 PM   #5362
Default motor getting too hot!
guys, need some help!
have been running a sp v3 13.5t in my tc with the following settings on an indoor track, around 30m x 15m with great effect:
motor timing full
fdr 8.1
drrs 9
boost 50
turbo slope 18
turbo timing 25
start rpm 3000
turbo delay 0.1
timing acc 350
temps after 5 mins around 60 degrees
at the weekend, i tried an orca 13.5t with 2 markings advanced on the motor, same settings but fdr was 8.7
car was silly quick, checked temps after a couple of minutes only to see thrm at 90 degrees!!
moved the motor timing back to zero which did help but was still getting hot.
what would you suggest i tuned down? was thinking about lowering my fdr to around 8.3 but reduce boost to 40, turbo to 24 and start rpm 4000, drrs 8.
would this help keep temps down but also keep the car quick? any other suggestions would be great.
mark
Mb3195 is offline   Reply With Quote
Old 06-22-2011, 05:17 AM   #5363
FunkyDunky's Avatar
motor timing full
fdr 8.1
drrs 9
boost 50
turbo slope 18
turbo timing 25
start rpm 3000
turbo delay 0.1
timing acc 350
mark
Hi I found raising the ACC timing to around 500 dropped the temp in my motor and I didn't feel any overall effect. What software version you running?
FunkyDunky is offline   Reply With Quote
Old 06-22-2011, 07:21 AM   #5364
Default software
fw is 211
Tried increasing it already but changed on or two other things at the same time such as start rpm, didnt like the feeling as you could really notice the 2nd gear effect in the wrong places and then lost some punch out of the corner.
Old 06-22-2011, 08:27 AM   #5365
Default Brake issues
Does anyone experience a lack of braking power when trying to brake after turbo kicks in? I have this issue where after the turbo kicks in and I try to brake at the end of a long straight I find that I have less than 20% of the original braking power.
In the short straights in the infield the brakes are working fine.
radwerx is offline   Reply With Quote
Old 06-22-2011, 08:42 AM   #5366
FunkyDunky's Avatar
Smile
fw is 211
Hi,
The second gear effect would be caused by the RPM change and the delay with the turbo coming in. Go back to a setting that you are happy with the feel but not the temp and change just the ACC. I you move the ACC up (500) drop a pinion at the same time this then gives you your punch back. I doubt very much you are hitting top RPM on a straight so you wouldn't notice the difference.
Old 06-22-2011, 09:22 AM   #5367
defcone's Avatar
I assume you have reverse force at 100%?
Old 06-22-2011, 10:34 AM   #5368
steliosh's Avatar
Back on my Thunder Tiger SB-5 1/5 rc bike...
Xtreme Stock with a new Nosram Pure Evo 17.5T motor (X12 equivalent), with 4-dots insert.
Xtreme settings:
211 sw
ddrs 5
boost 34
slope 12
turbo 25
start 3000
delay 0.2
acc 250
Before the X12 I had an X11 Nosram, with 7.5 FDR. I upped that to 8.1 FDR and the bike gained top speed and good acceleration out of slow corners. With the X11, motor temps were 90C with the 7.5 FDR, went down to 80C with the 8.1.
Yesterday I installed the X12 motor, FDR tested were first 8.1, motor temps 80C... I went to 8.7 FDR and motor temp soared to 125C!!!!!
But...it was absolutely ripping all over the track, I believe it was like a mod motor! Amazing...
And I use both a cooling fin and a fan on the motor (and on the X11, before)!!!
I left the bike with the esc switch on for 10 minutes on a new battery, just to cool the motor after that run, but I was scared, to say the least! after it went down to 50C, I ran the bike again, with 8.5 FDR and motor temps were again 120 or so...
Battery consumption in all cases was around 1900 mah... Ambient temps all these days are 32-35C...
Any ideas on what could drop motor temps AND keep that great feeling in the motor?!!!
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 06-22-2011, 04:06 PM   #5369
Sounds like your motor is spending to much time with alot of timing. Have you tried taking timing away from the motor, and running a bigger pinion?
A rule of thumb is 5 degree's of timing, is 10c of temp. One tooth (.15 of FDR Change), is also good for 10c of temp. That would be for a 2S 17.5 Touring car. Your Motorcycle might behave alittle different.
When running a lower FDR, you will find it better to use more boost then turbo. this will allow you to still have alot of acceleration in the infield, and just use alittle extra turbo on the straight to keep the top end. Your motor will spin less RPM, and spend less time at full timing, keeping your temps down.
Shawn
Shawn68z is offline   Reply With Quote
Old 06-22-2011, 05:55 PM   #5370
Reverse force is at 25%. I am using forward / brake only mode. Does reverse force affect braking force? My Brake force is set at 87%. 100% brake force doesn't make a difference to the problem either.
