Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-14-2011, 07:40 AM   #5296
hi everyone sorry this isnt actually a question about the software but what is the most powerful motor you can run on the xtreme stock esc with a 2s lipo? Sorry if this has already been asked!
Jammin23 is offline   Reply With Quote
Old 06-14-2011, 08:11 AM   #5297
M7H
M7H's Avatar
for a few seconds to a minute => 3 turns.
For more lifetime, check the hobbywing site, there you can find the info.....
http://www.hobbywing.com/english/Art...?ArticleID=468
Serpent
M7H is offline   Reply With Quote
Old 06-14-2011, 08:18 AM   #5298
cool thanks for that
Old 06-14-2011, 04:49 PM   #5299
irgo's Avatar
Hobbywing untill now, has no release of new Firmware updates,
angelo.....
Quark Force
irgo is offline   Reply With Quote
Old 06-14-2011, 05:05 PM   #5300
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
what you havent gotten the new 215 fw yet.
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 06-14-2011, 05:32 PM   #5301
cherry2blost's Avatar
angelo.....
1106 seems to work a treat, not pushed it too hard yet but you never know
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 06-14-2011, 05:35 PM   #5302
For running Stock software the absolute limit is 8.5T, however we over here advise no lower than 10.5T, just to be on the safe side, If you were to roll it back to 205G etc then theoretically, it should act the same as the XERUN 60A and run 5.5 as a bottom limit. DO NOT TRY LOWER THAN 8.5T WITH STOCK SOFTWARE !!!!! YOU HAVE BEEN WARNED
Old 06-14-2011, 06:16 PM   #5303
Trader Rating: 20 (100%+)
Default Spec class
I am sure this has been covered. Sorry to ask again. My local track is running a spec class No boost or Timing with 21.5, silvercan blackcan 4.0 FDR. My two questions are with the new software is there a non-boost selection or do I choose stock and turn off the boost timing? How to I prove this option has been selected ie blinking lights?
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 06-14-2011, 06:45 PM   #5304
irgo's Avatar
nice cherry, have links ?
Quark Force
Old 06-14-2011, 08:26 PM   #5305
defcone's Avatar
Trader Rating: 15 (100%+)
You plug it in your pc with the lcd card, and you upgrade to 508_notiming software on your esc. Then it should blink at neutral?
defcone is offline   Reply With Quote
Old 06-15-2011, 12:35 AM   #5306
Hi,
Im running a x12 17.5T, FW 211 FDR at 6.13-7,what timing insert should i be running on the endbell?...its in a 1/5 electric bike..plenty of cooling.....
thanks simon
sunktothenutz is offline   Reply With Quote
Old 06-15-2011, 12:49 AM   #5307
Originally Posted by COBRARACING View Post
211 is the latest software version .i can send it to you just send me an email to teamcobraracing@gmail.com
HI , Angelo , is this you ?
ZTW Manager is offline   Reply With Quote
Old 06-15-2011, 12:54 AM   #5308
Rather than bugging Angelo for software as I know he is a busy bunny all firmwares are downloadable from here......
Hobbywing ESC Settings ONLY
Has a plethora of firmwares, old and new.
Just read the whole post
Old 06-15-2011, 01:07 AM   #5309
M7H
M7H's Avatar
Originally Posted by sunktothenutz View Post
Hi,
thanks simon
I always run the X12 with 4 dots insert ****, this gives the minimum end bell timing, so the ESC can do the rest.
Check lrp.cc (and then there forum) for question about the X12.
Serpent
Old 06-15-2011, 11:52 PM   #5310
millbank's Avatar
The best way to run a LRP X12 is with 2 dot because the motors generate less heat. The motors don't like to run in a retarded position. I got this info from a team driver. If you want to see the difference then run a conservative setting on the speedo with the 4 dot in, then switch to the 2 dot and see which ran cooler. I know it will be the 2 dot.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
