Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-13-2011, 02:13 AM   #5281
defcone's Avatar
Trader Rating: 15 (100%+)
I reckon put your motor timing back on 0 first, I assume -3.5 ticks is from the center?
defcone is offline   Reply With Quote
Old 06-13-2011, 08:48 AM   #5282
Default Boost Ramp
Have a FW suggestion for the Boost Ramp. I normally run 100RPM/Step, but I would like to see 75 RPM/step, and 125RPM/Step added to a future version.
Cheers,
Shawn.
Shawn68z is offline   Reply With Quote
Old 06-13-2011, 08:52 AM   #5283
2wdrive's Avatar
Does Hobbywing sell a brushless motor that is around 48mm in length or less? I want to use it in an old corally pancar but the room is not enough to fit a normal size brushless motor. Sensorless is ok as well, as long as it is 48mm or less in length.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 06-13-2011, 10:15 AM   #5284
JKL1031's Avatar
Yes yes.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 06-13-2011, 02:40 PM   #5285
njt
njt's Avatar
Team Powers make a superlite motor and is 6mm shorter overall with the same diameter, 10.5 and 13.5 winds
Team Powers UK sell the motors
njt is offline   Reply With Quote
Old 06-13-2011, 04:52 PM   #5286
Originally Posted by TeamWTF View Post
Wow... Thats a pretty decent temp layout!
I usually keep my ESC setup pretty similar and adjust FDR
Start - 4000
Boost - 40
Turbo - 25
Timing acc - 300rpm/deg (Starting point... Lower i needed and if temps allow)
Turbo Slope - 6/0.1 (starting point - Very safe... Increase if temps allow!)
Delay - 0.2
FDR will be the key... Depending on motor probably around 5.5 - 6.0
When do you run there? And how often? I'm interested!
hey Mate,
thanks alot for these setting once it turns dry again i will try these out and see how they go.
We run @ Penrith Every Monday night along as its not raining or some Public Holidays. we run atm Mini and 17.5 we can always run another class as long as we get enough entries. if you want more information let me know via PM.
Schumacher Mi4 & Mi3.5.
Hobbywing Stock Xtreme
17.5 Trinity Duo Version 1.
steve_windsor is offline   Reply With Quote
Old 06-13-2011, 07:06 PM   #5287
I have an XRAY T3'11 I am running outdoors on a medium sized track. 150ft straight, running a Trinity Duo3 17.5
I need some help with the settings, what do you guys recommend?
Grant
XRAY T3'12 17.5, Spec R R1 13.5, CRC GenXL, Grant Galloway Designs ( Painter )
lifeguy is offline   Reply With Quote
Old 06-13-2011, 10:59 PM   #5288
2wdrive's Avatar
Thanks, i read that they made a shorter motor but thought i asked here as well. I don't know what a shorter rotor does performance wise but it seems it is the only motor that will fit without dremeling the pod.
www.rc-lemans.de
Old 06-14-2011, 02:01 AM   #5289
Hi
I have been using my HW Xtreme stock for a couple of weeks now and its been awesome !
I had a issue with it at the weekend though that cost me a couple of heats and wondered if anyone had the same issues or knows of a cure ?
I turned the speedo on as normal for my heat put it down and ran it for 20yds to the line. When i set of the car was really really slow as if there was either no timing on the speedo or it had dropped into sensorless mode.
Both times this happened i had my pitman turn the speedo off then on and everything was fine again ?
It is not just me having these issues as a fellow HW runner was having the same issues !
Anyone got a cure ( i know i could just turn the car off and on again) or having the same issues ?
Mark
tc3nitro is offline   Reply With Quote
Old 06-14-2011, 02:49 AM   #5290
defcone's Avatar
Originally Posted by tc3nitro View Post
Hi
Mark
That happened to me and I swapped out the motor sensor and it was fine after that.
Old 06-14-2011, 03:02 AM   #5291
kermit's Avatar
Grant
Here is a good starting point....
17.5 duo 3 standard timing
ddrs 5
boost timing 40
turbo slope 18
turbo timing 25
start rpm 4000
turbo delay 0.1s
timing acc 300
fdr 5.7-5.9
hobby wing 211 stock software
Make sure you temp it after 2-3mins and make sure it doesn't get too hot.
Adelaide RC Team Driver - www.adelaiderc.com.au
XRAY T4 | Futaba | HOBBYWING | Muchmore
kermit is offline   Reply With Quote
Old 06-14-2011, 03:46 AM   #5292
FunkyDunky's Avatar
I agree with swapping the sensor lead first for sure my I had the same fault and it turned out to be the sensor in the motor I was using, changed that worked perfect!
FunkyDunky is offline   Reply With Quote
Old 06-14-2011, 05:09 AM   #5293
Cheers,
Shawn.
nice idea shawn...
zamrioo2 is offline   Reply With Quote
Old 06-14-2011, 05:15 AM   #5294
barts71m's Avatar
Trader Rating: 34 (100%+)
Hi
Mark
Had exact same issue a week or two back, switched sensor lead and all sweet again. Had a pretty good side on hit the previous race.
barts71m is offline   Reply With Quote
Old 06-14-2011, 05:31 AM   #5295
COBRARACING's Avatar
Hi
Mark
Either sensor cable,sensor connector on motor/esc or the sensor board on the motor.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
