Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 06-10-2011, 08:08 AM   #5251
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
love my xtreme esc but were can i get a new fan,mine started playing up after about 3 runs,took it about 10 seconds to get going,now its about 25 seconds,makes a weird noise like its trying to spool up.
i run a onroad track but it gets fairly dusty
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 06-10-2011, 08:40 AM   #5252
blade072's Avatar
Trader Rating: 98 (100%+)
give angelo a pm....(COBRARACING) i know he has them...
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 06-10-2011, 11:06 AM   #5253
irgo's Avatar
when racing on Direct Drive Rpm log are more important,
also work's on buggy, so how about new esc Firmware with rpm log.
Quark Force
irgo is offline   Reply With Quote
Old 06-10-2011, 11:53 AM   #5254
Hi,
I have seen on ebay a bullistorm 60amp sensored esc with programme box..is this the same as a hobbywing 60amp esc and is the firmware updatable?
Also,can the 120amp HW esc run a sensored motor if you take the sensor lead off,as i tried this with mine ,LRP x12 17.5T,and it would not run?..i thought they could run sensored and sensorless?
One more question!...when i ran my 17.5T x12 Lrp,with 120amp HW esc,after about 5 mins it lost a bit of power,motor not hot,all settings ok....put and new battery on and the power was back..plus there was plenty left in the battery that i took off,??....
Cheers simon
sunktothenutz is offline   Reply With Quote
Old 06-10-2011, 05:26 PM   #5255
Telemetry is pretty much useless on in off-road, to much wheel spin to make the recording usefull. Its mainly an on-road tool.
Still wouldn't mind having it though, then to make a dyno you would only need a flywheel. (or even just acouple of rollers with a conveyor belt to make a chasis dyno. )
Shawn.
Shawn68z is offline   Reply With Quote
Old 06-11-2011, 12:41 AM   #5256
irgo's Avatar
see, we do not need Dyno, ESC Firmware with RPM Log, in it would bee the best.
Quark Force
Old 06-11-2011, 12:44 AM   #5257
cannon's Avatar
Trader Rating: 35 (100%+)
Just go away with your constant dribble .... you contribute nothing
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 06-11-2011, 01:03 AM   #5258
I live in the certainty that when the new one comes out, you are going to be so disappointed, and I am going to be really happy. In the meantime, shutup.
SlowerOne is offline   Reply With Quote
Old 06-11-2011, 01:15 AM   #5259
ozzy-crawl's Avatar
entot salah irgo
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
Old 06-11-2011, 04:51 AM   #5260
TryHard's Avatar
Old 06-11-2011, 05:21 AM   #5261
I had the same problem.
As the amps increase the voltage decreases. Even if the battery has 7.7v left in it the turbo / timing features might be enough to drop that down to the LVC level under load and as a result you lose power.
Buy a ThunderPower LIPO.
Problem solved.
It worked for me anyway.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 06-11-2011, 06:54 AM   #5262
Hi,
Thanks...what about lowering the LVC?..its on 3.2 at the mo......
Cheers simon
Old 06-11-2011, 08:55 AM   #5263
COBRARACING's Avatar
Hi,
Cheers simon
Bullistorm is a copy of the hobbywing ,not manufactured by hobbywing
Yes can run sensorless and sensored .
what the c rating of your battery ?see you can have capacity but how quick does the voltage drop on your pack is it linear ?or does it decline very quickly.?
from what you have told us i see that you have a big voltage drop and very quick drop at that .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-11-2011, 09:27 AM   #5264
Hi,
its a 6500mah 30C.............have used it with a 8.5t losi motor with no problems over 8 mins heats............someone said that if a rotor has been overheated it can use up more power?....i bought the motor second hand,seems to run well apart from this problem......
Old 06-12-2011, 10:47 AM   #5265
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by VooDooPH View Post
HW 120A 1S... running a 4.0T with 1S... blinking green led after the run means low voltage?
Originally Posted by COBRARACING View Post
Overheated esc .
haven't run 1/12 since posting this...
anyway, was bench testing my car this evening after installing higher turn motor (7.5T SP Comp2). so i put on a 1S pack, turned the radio and the esc on and pulled the throttle... the car would rev but i wouldn't get that sudden high-pitched rev indicating the boost wasnt kicking in. looked at the esc and noticed the green blinking led again. when i 1st turn on the esc, no lights. pull the throttle, even just a fraction to roll the motor and the blinking green led lights up when i let go.
esc fried?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
