Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 06-15-2010, 10:05 AM   #511
unsp0ken's Avatar
Trader Rating: 24 (100%+)
Originally Posted by mlight13 View Post
Ok...cool. One last question, does the 508 "non timing" firmware lock the timing at 0*, or can the timing still be adjusted with the LCD box? Thanks...
Pretty sure it locks the timing + output an LED sequence for no timing. That's the whole point of the firmware.
unsp0ken is offline   Reply With Quote
Old 06-15-2010, 10:11 AM   #512
mlight13's Avatar
Trader Rating: 40 (100%+)
Ok, then what is the best non-turbo firmware for my XERUN 60a/13.5 combo? I am thinking of switching to a different class (RCGT) which I can not use timing advance for.
Mark
mlight13 is offline   Reply With Quote
Old 06-15-2010, 10:37 AM   #513
unsp0ken's Avatar
Last time I checked, 508 is the only firmware with non adjustable timing.
Old 06-15-2010, 02:53 PM   #514
razzor's Avatar
Its a fixed non advancing software version with no adjustments and can be verified by a flashing red led when in neutral.
I believe its 0 timing.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-15-2010, 02:57 PM   #515
razzor's Avatar
If the class allows the old software then use 312, otherwise most stock classes seem to be adopting the ""0 timing" rule.
Casterracing ZX1.5R
Old 06-15-2010, 05:00 PM   #516
COBRARACING's Avatar
yes you are correct the 508 has no timing function
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-15-2010, 09:18 PM   #517
mlight13's Avatar
Thanks for the response. One last question, if i do use 508 software, will I have the option to change all 11 parameters using the LCD box as before all the "turbo" stuff came along? For example, can I adjust 508 the same way as say 110? Thanks in advance...just trying to understand a few things.
Mark
Old 06-15-2010, 10:58 PM   #518
yes you will be able to change the parameters as pre turbo timing implementation with the 508 not a problem in the world .508 is a upgrade of older firmware pre turbo 422 and beyond just some bugs were fixed and some added braking etc .
Old 06-15-2010, 11:00 PM   #519
Ok Guys
Im putting this out to you guys who own hobbywing products what improvments would you like to see come from hobbywing hardware and firmware?
Let us know by email at teamcobraracing@gmail.com
Old 06-15-2010, 11:08 PM   #520
syndr0me's Avatar
Trader Rating: 32 (100%+)
I don't own one (yet?), but I'm keeping a close eye on the progress you make. Here's what I'd like in an ESC:
1. The raw speed of a Tekin
2. The smooth power delivery and brakes of an LRP
3. The ability to tune it without a laptop, like the little programming box you guys have
4. The ability to go into "spec" mode and back to non-spec without updating or flashing firmware, and without having to reset all your parameters when you toggle between the two.
5. Removable receiver wire that I can shorten or replace without soldering to the board.
As a bonus, it would be awesome if ESC's were capable of storing data about your run so you could dump the info to a PC later on, and see exactly what's going on with timing vs RPM, etc.
syndr0me is offline   Reply With Quote
Old 06-15-2010, 11:39 PM   #521
Hebiki's Avatar
Trader Rating: 26 (100%+)
Syndrome...
you forgot to ask for World Peace.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-16-2010, 03:35 AM   #522
You cant have everthing in this world.
This Hobbywing esc has incredible power. Yes definately for smooth power delivery, set on a higher setting of timing punch (longer ramp).
It makes my 13.5 smoother and have more acceleration than an LRP SPX (that was very smooth) and the same top speed as an SPX with 10.5.
My clubs carpet surface is very sensitive to overheating the tires if theres too much punch in the esc and the hobbywing is one of the few escs that works on it.
The slight niggle is the brakes from slow speed. The brakes from high speed (where you actually use them) are great. Also, theres no lag from high speed like I seen in the GM and Mamba Max Pro.
The LCD programmer does it all, except run mod and stock profiles.
maxg123456 is offline   Reply With Quote
Old 06-16-2010, 05:50 AM   #523
ali_g's Avatar
Anyone have the pictures of xerun 120 amp v2.1??
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 06-16-2010, 09:43 AM   #524
Send a message via MSN to geubes
SP have released both a 528 STOCK and MOD firmware, the latest hobbywing update only includes 528 MOD.
2 questions:
Is there any different between 528 MOD and STOCK in the SP version?
If there is, will we see hobbywing release the update for 528 Stock?
thanks
and to above post, here are pics from RedRC http://www.redrc.net/2010/06/hobbywi...club-spec-esc/
geubes is offline   Reply With Quote
Old 06-16-2010, 11:27 AM   #525
Suspended
Trader Rating: 86 (100%+)
i m interest of getting a hobbywing esc for my parking lot fun car (t2 touring)
just wondering which verion of hobbywing esc should i get (running 10.5, 13.5 and 17.5 bl motors)
anyone try the new extreme stock esc? whats different between ezrun xerun and stock esc?
littlealex is offline   Reply With Quote
