Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-27-2011, 07:12 AM   #5161
Trader Rating: 56 (100%+)
Default Service
Where does one send one of these in for service? We have a hobbywing Xtreme stock, another car crashed into the back of the 2wd buggy and smashed the b and c poles together or the motor and quickly stopped the buggy, smell of burning electronics ensued. Thing links up to the USB fine and callibrates up with the radio, but no throttle response. Had it sitting in the box for over 6 months, finally hooked it up last week and now kaput. LOL. Prior to the crash, it was a great speed control!
dynamic_e is offline   Reply With Quote
Old 05-27-2011, 04:58 PM   #5162
COBRARACING's Avatar
Originally Posted by zipp View Post
I found out through experience that there are 2 major causes of the 'half-throttle' syndrome.
First, as mentioned by Angelo, is the quality of the batteries. I have cheap 20 dollar packs as well as race packs, and the problem only occurs when using the cheap packs. What happens is that the cheap packs show a much bigger drop in voltage under load, triggering the low-voltage threshold. This can occur even if the pack is fully charged, with low wind motors using high boost/turbo. If this is the case, what you can do is simply lower the low-volt threshold on the speedo, to 2.8V/cell or even switching it off. Of course, do keep a watch on run time as the possibility of over-discharging is higher. you will find that this solves the problem.
The second and more common cause is the sensor cable. check to see that the 6 small wires are intact, and the plugs securely attached. A good tip would be to buy the most flexible sensor cable you can find, because these take hits better, and last longer as the wire strands are more resistant to bending.
cheers
Great info Zipp your experience now can help others .thank you for your input.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 05-27-2011, 05:15 PM   #5163
JKL1031's Avatar
not trying to whore out, but when i did try to reflash, I cant find 211 anymore I have too many USB link downloads on my PC, old and new.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 05-28-2011, 12:11 AM   #5164
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by blade072 View Post
had a good club run sunday....car performed great (even with a cracked rim)
qualified 2nd finished 1st...
ran an express motorsports duo1 17.5 standard timing set and it never got over the 60deg mark and had great speed and rip out of the corners...
here were my settings
ddrs 5
boost timing 40
turbo slope 18
turbo timing 25
start rpm 4000
turbo delay 0.1s
timing acc 300
fdr 5.7
car xray t3 with exotek chassis muchmore 32's
hobbywing xtreme stock esc. 213 stock software
might try an extra tooth next time....
just realised was running FDR 5.93 not 5.7 as stated above...just checked
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-28-2011, 01:25 AM   #5165
guinnes.s's Avatar
what is the difference between PUNCH and TIMING ACC?
thanx
guinnes.s is offline   Reply With Quote
Old 05-28-2011, 01:39 AM   #5166
M7H
M7H's Avatar
110211 (and all other FW ever released) you will find in the latest PC software package called V1.63_110310
And maybe you have to scroll up/down in the list of FW's available....
Serpent
M7H is offline   Reply With Quote
Old 05-28-2011, 06:00 AM   #5167
Address:
Hobbywing tech co ltd
ShenZhen, China
attention miss carolyn and mention my name Angelo on the box and carolyn will take of of it .
thanks
Old 05-28-2011, 11:58 AM   #5168
steliosh's Avatar
Doing some TLC on my Xray TC, I realized that due to some bad... landings, my Xerun 120A case is broken in a couple of places.
So, is there a way to get just a case for the Xerun 120A V2.0 ESC?
From where? How? any ideas?
TIA
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 05-28-2011, 03:53 PM   #5169
you can contact kyosho de in Germany or racers in exile uk cherry2blost for a new case for your 120 amp.
Old 05-28-2011, 05:00 PM   #5170
any new firmware coming out? we used to get updates every 2months or so...now it's been awhile
cheapskate.brok is offline   Reply With Quote
Old 05-28-2011, 09:49 PM   #5171
steliosh's Avatar
Thanks, Angelo!
Stuart has been very helpful again, in the past with parts.
I will contact them.
Old 05-29-2011, 04:48 AM   #5172
Test Driver's Avatar
Has there been any further development on the bluetooth adapter as to when/if it will be available?
Eden
SSE - SmallScaleEngineering
DASH-1
1/12 scale Eurostock
Test Driver is offline   Reply With Quote
Old 05-29-2011, 08:51 AM   #5173
can someone recommend a good setup for a 13.5t on a LARGE asphalt track? (tamiya ff03)
running 518stock today and 4.05fdr, havent tested so much outside with stock and not sure how to start with the newer firmwares
also cant change the settings with my 2in1 box (turnigy branded) with firmwares newer than 518!
and the update button on my computer is grayed out in the hobbywing program
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 05-30-2011, 01:00 PM   #5174
did some testing with the 213 firmware today, tamiya ff03 with duo2 13.5t motor on a large asphalt track
ddrs 7
boost timing 40
turbo slope 18
turbo timing 25
start rpm 4000
turbo delay 0.1s
timing acc 300
(basically the same as blades setup earlier in this thread)
fdr 4.44
the motor barely gets warm with this, and my xtremestock is just fingerwarm (outdoor temrature was around 17c ans quite windy)
the motor just screams down the straight
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Old 05-30-2011, 11:11 PM   #5175
razzor's Avatar
If the weather holds up i hope to get to the track this weekend to run my Touring cars.
Have a few setup changes to try.
Just to back up what zipp mentioned, the batteries you use is definately a factor if you hitting the low voltage cut off also the quality of the solder joints on the battery plugs and esc posts can contribute to the problem.
On batteries i ran the Pro Amps in my 1/8 buggy on the weekend and also loaned them to a buddy to try. I found a noticeable difference in punch while my buddy got more run time out of his 1/8 buggy.
compared to my other branded batteries the Pro Amps are definately having a edge on performance.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
