Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 05-11-2011, 01:56 AM   #4981
Hi,
Is there a difference between setting the brake force and reverse force to 100% then just reduce the EPA of the transmitter versus setting brake force at lower value on the esc (e.g. 50%)?
Other words, should I try to approximate brake strength first on the ESC setting then fine tune with EPA?
Or set at ESC 100% then just tune with EPA?
Thanks in advance.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 05-11-2011, 03:29 AM   #4982
irgo's Avatar
Originally Posted by sizheng View Post
Nick, I have tested on hand, with the same setting of you, two different motors, both work fine, very strong and fast response . Will test on track this weekend.
If you have time, please use the standard modify FW such as 090205 to test.
To confirm it is not a hardware problem.
there is new firmware ? news? it's may 2011 now?
Quark Force
irgo is offline   Reply With Quote
Old 05-11-2011, 03:45 AM   #4983
NTS
Default High speed brake problem...
Salton,
OK I'll give that FW a try and let you know what happens. I can try it on the bench tonight and on the track on Friday.
Cheers,
Nick
Last edited by NTS; 05-11-2011 at 03:50 AM. Reason: Quote added to avoid confusion.
NTS is offline   Reply With Quote
Old 05-11-2011, 03:47 AM   #4984
NTS
irgo,
My problem occurs on the latest 211 software, Salton's suggested FW was to test the hardware functionallity.
Nick
Old 05-11-2011, 04:13 AM   #4985
M7H
M7H's Avatar
NTS.
irgo + n = ignor
Serpent
M7H is offline   Reply With Quote
Old 05-11-2011, 05:21 AM   #4986
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Thanks for clarifying its May 2011.... For a moment I was thinking it was July 2008 and almost missed my meetings today....
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 05-11-2011, 09:41 AM   #4987
dameetz's Avatar
Originally Posted by M7H View Post
NTS.
irgo + n = ignor
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-12-2011, 04:30 AM   #4988
COBRARACING's Avatar
Hi guys
Just a little note to clarify some info about the V3 as ive been getting some complaints from europe that customers are awaiting for the release and holding off from buying excisting products .
Now the V3 is a long long way away not even in production stage then there is months and months of testing so if your waiting on the v3 in the next few months dont bother as you will be wasting your time .
Now the bluetooth unit is not built in to the esc it will be similar to a fail safe unit in size and will work on all xerun esc's no matter what model so its not a built in unit its external .This is to cater for the customers who have existing esc's and will be an option .so for example if you buy a v2.1 120 amp or 60amp,xtreme stock the bluetooth unit will be an option and will plug directly into these units and more .
so dont hold out from buying as the bluetooth will be an option that can be used on all esc's available.Its not only for the V3 unit.
ok thank you for your time
regards Angelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 05-12-2011, 04:33 AM   #4989
JRXS_chris's Avatar
Thanks for the heads up Angelo.
When shall we expect to see the Bluetooth unit hit the stores?
JRXS_chris is offline   Reply With Quote
Old 05-12-2011, 04:38 AM   #4990
Chris we have no set release date but i will keep you all informed dont worry .
Old 05-12-2011, 05:53 AM   #4991
And there was me thinking it's october 2034
gazmond is offline   Reply With Quote
Old 05-12-2011, 05:57 AM   #4992
irgo's Avatar
angelo can you post picture the hobbywing bluetooth,
and new firmware of the month.
thanks
Quark Force
Old 05-12-2011, 06:53 AM   #4993
M7H
M7H's Avatar
Irgo, can you maybe stop posting for a month?
Serpent
Old 05-12-2011, 08:30 AM   #4994
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
@Angelo
Thanks for the heads up. I have been kind of holding out too.
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 05-12-2011, 08:59 AM   #4995
Originally Posted by rccartips View Post
Hi,
Thanks in advance.
I've tried both ways of setting maximum brake and honestly I didn't feel any difference.
So I just leave it at 100% and then play with EPA.
Fastfreddy74 is offline   Reply With Quote
