NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#4876
Hi,.. guys,..
Currently, I am using a 10.5t stock motor with Xerun 120A V2.1.
In the xerun, 211 stock firmware is being used.
What is the diff between mod firmware & stock firmware??
Can I change the esc firmware to mod & use back the same motor??
Just being curious...
#4878
(at this stage, I only want to change the parameters in the firmware, without dialing the timing at the motor)
#4879
I just received a 60a Xerun from ebay.
I bougth it as a v2.0 but I received a v2.1. there are details that make think could be a fake:
* motor & battery wires are thinner than my prevoius xerun
* Battery and motor wires are in a mixed position ( A+B-C not ABC +-)
* Serial No. sticker it's white and not chrome like before
* Comes with a different capacitor bank. Only two with transparent shrink tube
It's genuine or a fake?
#4880
As far as I know only the Ezrun system has been copied, the Xeruns are all fine.
#4881
Hello everyone I have a quick question, my setup is a Xtreme Stock 60a running firmware 211 in a rock crawler with a three cell lipo. I use the esc in forward/reverse mode, my problem is there is not a smooth transition between forward and reverse unless the trigger is moved very slowly, its almost like there's a slight time delay when the neutral zone is hit and then it jumps right to six percent throttle in reverse. Could this be solved by possibly having a smaller neutral zone than 6%? Any thoughts would be appreciated.
#4882
Hi Guys,
I understand turbo comes after boost. But not sure what the difference is.
Why not just set boost = 64?
Or Boost 0 and Turbo 64?
Trying to understand the performance difference.
Thanks in advance.
Thanks in advance.
#4884
@Angelo is that temperature cutoff of 95C measured on the outside of the can or inside where the rotor is?
I ran the xerun 10.5t motor with a xerun 120v2.1 in my 235mm pancar last monday during the easter race and it worked flawlessly. It was quite warm weather, roughly 25-28 C or something.
I run punch at 1 or 2 and with 8000-10.000 start and low to normal settings it has lots of grunt down below and lots of top speed on the straight when turbo engages. With roughly 1/2 to 2/3 of the price of other brands motors it is really an amazing motor. After 7 minutes of hot racing action i had roughly 62-65 degree C on the can. After 5 minutes or so in the race it felt a little flatter then before but that could also be the lipo's that have less voltage to work with.
The sensor screws that backed out previously hold up this time. No problems anymore with a loose sensorboard.
Even though it has fixed timing (something i was a little dissapointed by at first), I must admit now that the xerun is a very nice and well build motor. I also like the fact that the motor wires are solderd on gold plugs so it is easy to remove the motor without desoldering the motor wires. (Just found out that they were gold plugs 2 weeks ago when one plug got a little loose )
Would you mind using Cherry2Blost's setup sheet and posting your Pro10 setup his HW Setup forum? i am trying to download as many HW setups sheets I can for the various types of cars.
Cheers,
Shawn.
#4885
As for running all turbo? You could, but i dont think it would be that effective, your track would have to have a super technical infield (where torque is important), and then a massive long straight for the turbo to be of any use.
#4886
Hi All.
I may wan to know how high speed my sakura zero can do?i mean the Max MPH around?
i runnninng hobby wing ver 2.1 120A.211S firmware
Xerun 10.5T Sensor Motor
FDR 7.26
TUrbo kick 3K RPM
i just wan to know how fast the top speed i can get?i feel the car is very fast at the end.like rev no tomorow
FDR 7.26
TUrbo kick 3K RPM
#4887
it is better to run boost and some turbo thats the way alot do it .The software is designed that way it is more efficient to run more boost than turbo.
#4888
We are in the process of introducing an exchange program for your faulty/non warranty esc's .
The idea has been around for a very long time with others in the industry but also in other industries like Apple etc But someone from this forum from the uk woke me up to it with the lenght of turnaround time it takes for a customer to send there esc to china for repair and then time taken for the repair and then the time taken for sending back to customer .
so what we will put together is the following
Non warranty esc's even in a warranty period that are not a factory defect we will await for the product to be sent back to us depending on the extent of the repair we will repair it or we will offer a replacement esc at a special exchange price .So we will try and cut the turnaround time from 6- 8 weeks at present to 2.5 weeks max .
Ill give you guys more details when im back from Asia .
#4889
i know that this has been answered before but i just cant find it..
the xtreme stock esc has a motorlimit at 8.5t, but if you change the firmware to a non turbo/boost you can run it with a 5.5t
is this correct? i need another esc and ofcourse the only brand im looking at is hobbywing, but not sure if i should buy the regular xerun 60a or a xtreme stock
will be running 13.5t, but might run down to 6.5 (non boost on both, just need a small esc)
#4890
