Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-01-2010, 09:48 PM   #421
Born2Run's Avatar
Originally Posted by maxg123456 View Post
Anyone who's interested in a good setting for rubber tires indoors I have come accross this setting with a 13.5.
Motor - GM 13.5 with stock timing.
9 - 8
12 - 9
13 - 1
14 - 3
15 - 5
Working out what these settings are actually doing, my cars starting and ending rpms (before turbo kicks in) is 3,000 to 17,400rpm. Even on a small carpet layout, the car exiting a fast sweeper onto a small straight is doing around 18,000rpms!
How I work these settings out -
Timing punch (15) setting 5 is 700rpm increment as per PDF.
Boost (9) is setting 8 (21 degrees) so 700 x 21 = 14,700 then add timing
start (3000) = 17,400rpm. This is before the turbo kicks in!
The car is doing 23,300rpm with turbo and yet a 13.5 motor can easily manage 70,000rpms at full chat with this software. Even with a 13.5 I find it maddening that some people out there are setting this esc with timing punch 1 and start 7500rpm for example. That would mean the timing kicks in between 7500rpm and 11,700rpm before turbo timing! That is insane LOL. The car accelerates to top speed in 1 second, making the car on a technical layout burn out rubber tires out in a few minutes!
I had this in the past with the Mamba Max Pro and it's god awful set like this and I know the GM also doesn't work well either set like this, so I presume this esc works the same way.
I found having a long timing ramp to be far more helpful to getting consistentcy and laptimes as the car progressively accelerates.
You only need to look at the Tekin and GM guys to see how wide a timing ramp they use. Starting the timing lower also gets rid of the kick when the timing starts I find.
Hi max
I don't understand how you calculate the ending 17.400rpm and also how do you know that turbo kicks in after the end rpm.Could you expain please?
Whatever
Born2Run is offline   Reply With Quote
Old 06-02-2010, 02:26 AM   #422
Originally Posted by Born2Run View Post
Hi max
If you look at the PDF its straighforward how they work out the rpm.
Their examples with boost and turbo -
Example #A 4500 RPM /200 RPM/ 12 7 - 8300 RPM
Example #B 6000 RPM /300 RPM/ 15 4 - 11700 RPM
12+7 x 200 = 3800rpm + 4500rpm start = 8300 rpm
15+4 x 300 = 5700rpm + 6000rpm start = 11700 rpm
As far as I know, this works a simillar way to other escs. The start and end ranges can also be worked the same way if you take the degrees of turbo off the calculations above.
maxg123456 is offline   Reply With Quote
Old 06-02-2010, 04:02 AM   #423
Born2Run's Avatar
So 17.400 was a typo thats why im confused. The right ENDrpm is 17.700.
Thanks Max
Whatever
Old 06-02-2010, 04:04 AM   #424
Send a message via MSN to geubes
Ive been reading your suggestions on the timing punch and with people having it set to put the boost in to quick.
Ive also been testing this a lot at my local track and ran at WLRC, now for WL I agree that a less aggressive curve (higher number 15) gave a much smoother motor with greater top end.
however on our small track at home (SHMCC - dont know if you have raced it), the straight isnt that long - and using a more aggressive curve allows the motor to accelerate quicker, if I set 15 any lower than 3 (4,5, etc) the motor isnt using much boost due to the short straight. However its worth noting that I am using 9000 as my start RPM, so using a lot of the non-boost for the first 1/3 of the straight. Interestingly if i set my RPM delay to 10500, then its boosting just after half way and is slower because of this down the straight.
Settings for my 13.5 are:
FDR: 7.2
4:8
9:7
12:8
13:5
14:2
15:2
This gives wicked topend and acceleration down the straight (because its quite short).
However you have intrigued me to try setting 13 down to 1 or 2 and give it a less aggressive timing curve, might give it a go tonight if i get time.
PS. when your calculating your end RPM - because you are using a full throttle delay - the boost wont be kicking in as low as 3000, as im sure the motor will be reving higher than 3000 when the throttle delay is met. so it might infact be higher?
geubes is offline   Reply With Quote
Old 06-02-2010, 04:05 AM   #425
Thanks Max
Oh dear, yes thats right.
Old 06-02-2010, 04:40 AM   #426
FDR: 7.2
4:8
9:7
12:8
13:5
14:2
15:2
I really do not know if its 'actually' kicking in at 3,000rpms. All I know is that If you do the exact same settings you currently use, making a lower timing start will make the timing come in with much less of a surge if the Timing punch is also turned up 1 or 2.
Interestingly your boost (9 - 7) is set to 18 deg, rather than the max 21 deg boost. I'd go to setting 9 - 8 and put 15 - 3 (or 4). At the moment your car is set with 9,000 to 14,400. If you just went from 9,000 to 3,000 start the car would be doing 3,000 to 8,400. That would be very hard to drive, especially indoors. I have no idea about outdoors to be honest. I don't know whether i'm throttle happy, but my rubber tires will not stay in shape on my xray 009 for more than 15 laps with an aggressive setting on a small indoor track.
3,000 to 14,550 might be a good setting for you, which is this setting
Try this on your short track -
FDR - 7.0
9 - 8
13 - 1
15 - 4
I just would like to know how it compares to 9,000 to 14,400 and if the motor in fact gets cooler, because it did for me. It also should be quicker too.
Old 06-03-2010, 01:28 AM   #427
@maxg123456
Well I raced again last night and did the following changes:
9: 8
13: 4 (7500)
15: 4
which gives me a boost range of: 7500 - 22900
when making this change my lap time dropped from 14.69 - 14.48, but the motor was still the same temperature, so it was quicker but just as warm. Im going to continue making the ramp rate less and try lowering the start rpm to suit the track, mayb try something like 13: 3, 15: 5 next.
Old 06-03-2010, 01:38 AM   #428
vid of the race from last weekend. My car is the blue one with yellow stripes in second on the first lap. I was the only one using the HW with the new software, the rest are Tekins. I started with the recommended setup, but I think it is still too hot, so might need to reevaluate the start/end RPM. Regardless, it can definitely run head-to-head with the RS. Can't wait for the new super stock edition.
Please don't mind the bobbles here and there lol.
+ YouTube Video
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-03-2010, 03:03 AM   #429
@maxg123456
9: 8
13: 4 (7500)
15: 4
I have tried that setting the other week and it was good. 2 tenths improvement is a vast one. Im going to try the following tonight, if i'm able to go.
9 - 8
13 -1
15 - 5
3000 - 17700 (or 3000 to 23300 with turbo) Ill let you know how it went.
Old 06-04-2010, 01:05 PM   #430
Afazli79's Avatar
Send a message via MSN to Afazli79
Hi, need to know what i the best 10.5T motor suite with HW120a esc?? Tekin motor of Xerun motor???
It seems that Tekin Redline 10.5T have 4500KV but Xerun 10.5T only 3200KV.
My friend using Tekin RS Pro esc combo with this Tekin Redline 10.5T have 4500KV. His car is fast. I tried his car before. We r using same car Xray T3.
Can I bit him if I use combo Xerun 120a with Xerun 10.5T?
Or should I match it with Tekin Redline 10.5T???
Need everybody opinion on this before I buy either or this motor.
Need to know esc setup if I use Tekin motor of Xerun motor??
Tq.
Team MaxPower Malaysia...
Web : www.maxpowerbattery.net / www.bizonline2u.com
MaxPower / HobbyWing / Team Powers / Hudy / Xray / Robitronic / Tamiya / Tekin / Orca / LiteModz / Huge RC / MuchMore / LRP / Exotek / Smokem / SpecR / Atomic / SpeedMind / Sorex / Fijon / Paragon / Team Associated / Serpent / DS Racing
Afazli79 is offline   Reply With Quote
Old 06-05-2010, 02:05 AM   #431
Tq.
The xerun motor is absolutely fine. Its really the same as a Speed Passion V1. Ignore KV.
I use the following for indoors, but lowering FDR a bit might make it good outdoors.
FDR - 7.00
9. 8
12. 8
13. 1
14. 3
15. 5 (key to keeping temps down and making timing ramp long, so smooth power delivery).
Keep an eye on motor temps every 2 mins or so. Dont let it go over 160F.
Old 06-06-2010, 07:06 PM   #432
old-man's Avatar
Maybe silly question. How to turn off turbo for 0 degree timing racing regulations?
old-man is offline   Reply With Quote
Old 06-06-2010, 07:08 PM   #433
Just like to thank HobbyWing for providing a demo unit of the new Extreme Stocks speedie, a budget priced mid level speedie, rated down to 8.5t
It runs the same software in a much smaller case, its a neat little unit, with a 2 cap board, much easier to mount than the Version 2 units.
Had some very nice performance on the weekend, setting new track record by 4 seconds. Im not going to buy into the whole ESC dick measuring match, but it gives nice smooth power, crisp drag brake and awesome brakes. As most people know, i am a product slut, if its new and shiny i will end up trying one, and have used most on the market, and this is as good if not better than anything ive tried, add to that bargain basement suggested pricing, it will be a very popular litle unit, it will be available soon i believe.
Some pics, sorry for phone quality pics, and dodgy wiring, but give you an idea of the unit.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-picture-1519.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-picture-1521.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-picture-1522.jpg
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-06-2010, 08:32 PM   #434
dameetz's Avatar
Brad, is it rated the same as HW120A or the 60A?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 06-06-2010, 09:14 PM   #435
I understand its rated to a 8.5t
So not as fully equipped as the 120 amp, but considering such a tiny proportion of racers run mod, not an issue.
The event yesterday, on a smallish indoor track, fastest lap and race times were set in 10.5
