Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-20-2011, 06:43 PM   #4171
WishUCould00 is offline   Reply With Quote
Old 03-20-2011, 06:46 PM   #4172
smilekt's Avatar
Originally Posted by AGNO View Post
New win
Today I won the first round of the Superstock 17.5 Laurenziana Florence, Italy.
I used a 'Xtreme with 211 FW and Novak motor.
Congrate Agno .. any tekin racer there ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 03-20-2011, 10:06 PM   #4173
COBRARACING's Avatar
Hi Guys
The following motors are now with roar and being inspected for approvals
21.5T,17.5T,13.5T,10.5T,8.5T,6.5T,5.5T,4.5T and 3.5T
also 1/8th motors
2000kv and 2250kv
Also some info about Pro amps Batterys which is owned by myself ,the military factory and one the hobbywing directors brothers have got the following batterys with roar for approval should be finalised by the middle of april 2011
7.4V 5500mah 60C 2s lipo
14.8v 5200mah 60C 2s lipo
3.7v 5500mah 60C 1s lipo
7.4v 5500mah 60 2s saddle packs
thank you for your time
regards Angelo
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-21-2011, 12:05 AM   #4174
irgo's Avatar
Angelo you need to update the site with this list..
Quark Force
irgo is offline   Reply With Quote
Old 03-21-2011, 12:32 AM   #4175
AGNO's Avatar
Yes, there were Tekin and LRP Stock Spec V2.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-21-2011, 12:52 AM   #4176
AGNO's Avatar
Originally Posted by snabbgas View Post
Ok!
So that is the 30deg absolute Novak standard setting then.
Off topic I see you live in Firenze. It is supposed to be something of a Minimoto mecca. Do you know of any Minimoto racing over there?
Here I have a doubt ... I do not know how many degrees is the neutral position of the Novak SS Pro, at the neutral I consider 0 .
In Ballistic was declared by Novak that the neutral position is 30 , with Ballistic normally use 15 (-)
I respond to off-topic
Honestly I do not follow the races of minibikes, I do not know where to compete, but I have a friend who has raced, I could ask.
Contact you, if I have news.
Old 03-21-2011, 06:17 AM   #4177
guinnes.s's Avatar
Originally Posted by cherry2blost View Post
It does make a difference to the accelleration of the car, but it also depends where you place your boost start point, if it's too high you will still be using the motors' own 'grunt' for the corners, so the timing ramp up won't happebn until a bit later, have run on small tracks with 2000RPM and 200ACC is way too lively on the acceleration front
ok been flashing between 119 and 211 using same settings
9* 50
10* fastest
12* 24
13* 2000
14* 0.2
15* 200
119 is definitely faster on the low end then the 211 ,when changing setting 15* on the 119 i can see the difference , but on 211 not. low end on the 211 is smooter.
the only thing i can think is that my 13.5t SP V3 for some reason works better on 119.
guinnes.s is offline   Reply With Quote
Old 03-21-2011, 06:37 AM   #4178
2wdrive's Avatar
what about laptimes and temperature of the motor?
2wdrive is offline   Reply With Quote
Old 03-21-2011, 06:57 AM   #4179
guinnes.s's Avatar
cant say about lap time as the lap counting was off, the temp on the 119 was about 85c and i could see the difference in temp if i was higher or lower on the 15*, but on 211 was allways 72c and no changes if i was going higher or low on 15*.
Old 03-21-2011, 07:21 AM   #4180
getpip's Avatar
Does anybody have poor brakes with 119?
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 03-21-2011, 08:09 AM   #4181
darrenoakley's Avatar
Just found your set up sheet on Cherry on the 1s thread. Great stuff cheers
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 03-21-2011, 08:14 AM   #4182
cherry2blost's Avatar
You're welcome
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-21-2011, 08:21 AM   #4183
I had a problem at a race on Saturday with 211, would brake initially ok then just disappear, was really strange! Changed motor, re flashed Speedo and re calibrated and was perfect for rest of the day..
Was testing on the Friday and had problems with turbo not kicking in, re flashed with 211 and 119 a few times and eventually it worked.
Speedo was a SP 2.0 with a SP V3 10.5 also tried the 1s 10.5 version.
kdempsey is offline   Reply With Quote
Old 03-21-2011, 08:30 AM   #4184
9* 50
10* fastest
12* 24
13* 2000
14* 0.2
15* 200
Have you changed your gearing at all? With 1224 I was running a RO of 78, and with 211 I am running a RO of 88mm. Thats about 5 teeth on a pinion for my pancar! The car gained low-end and topend when I geared up.
Shawn.
Shawn68z is offline   Reply With Quote
Old 03-21-2011, 09:33 AM   #4185
guinnes.s's Avatar
i went down on the pinion to 8.6fdr to get the best out of the motor coming out from the turns on both FW,and this looks to be the right spot.
