Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 05-27-2010, 07:14 AM   #391
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by CraigM View Post
it would work keffy but you lose the AMTS settings that are useful in mod
I thought turbo and AMTS were independent of each other?
defcone is offline   Reply With Quote
Old 05-27-2010, 07:21 PM   #392
nikos2002's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to nikos2002
audriusv - I have not run it in 4wd yet - our new car is in final pre-production so hopefully soon. I have run it in 2wd Buggy and Truck so far.
As for settings, I would start with the standard settings and adjust from there as needed. I have changed settings and moved back closer to the standard.
Hobby Authority Distributions Marketing Director
** www.hobbyauthority-dist.com
Sponsored By: Maclan Racing, XRay/RC America, J Concepts, Xpert R/C, G Force USA, X Factory, Boom Graphics, Hobby Authority
nikos2002 is offline   Reply With Quote
Old 05-27-2010, 07:23 PM   #393
nikos2002's Avatar
link for 518 software is on page 25 of the thread.
Old 05-28-2010, 06:12 PM   #394
The supercharged 518 software with my 120A ESC and 5.5T is violently fast. It so fast that it exceeds the driveshaft's critical speed which makes it bend. It never did this before I installed the 518 software.
garycoleman is offline   Reply With Quote
Old 05-28-2010, 06:38 PM   #395
Hobbywing DO NOT recommend use to use 518 software with motors faster than 10.5R.
So you need to be careful with your settings, otherwise you may burn your motor or esc.
hardmankam is offline   Reply With Quote
Old 05-29-2010, 12:17 AM   #396
I know but I had to try it out.
It was so wild. The tires looked like they were going to explode. Eventually they became separated from the rim from because there was so much centrifugal force by going so fast.
Old 05-29-2010, 01:52 AM   #397
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi guys any chance of getting a 10.5t setup for the 518 software as a good starting point.thanks
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 05-29-2010, 05:24 AM   #398
harry_mcoe's Avatar
can somebuddy post a setup for 11.5t motor on 518 software..
harry_mcoe is offline   Reply With Quote
Old 05-29-2010, 06:47 AM   #399
RL.2002's Avatar
Check on the page 24 on this tread.
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 05-29-2010, 08:10 AM   #400
NDZ
Hi Guys,
Tested the 518 software on the MACH track in Heemstede Netherlands and I must say it's a huge improvement over the Mamba in combination with the 13.5 SP 3.0. Top speed on our backstrait (240 ft) 85 km/h and after 7 minutes still 78 km/h. Motortemp w/o coolingfan 60 degr. C. Speedo 38 degr. w/o fan.
FDR: 5.5
Settings:
1. 1
2. 1
3. 6
4. 9
5. 4
6. 1
7. 2
8. 2
9. 8
10. 1
11. 1
12. 9
13. 5
14. 5
15. 3
Top speed was similar to TEKIN but end top speed after 7 minutes was higher (appr. 3 km/h). I will test with a higher FDR and different settings on 13, 14 and 15 next wednesday.
Thanks Hobbywing!!
NDZ is offline   Reply With Quote
Old 05-30-2010, 02:20 PM   #401
Afazli79's Avatar
Send a message via MSN to Afazli79
Hi guys, currently I'm using Orca esc and Team Power 11.5T (timing +2) motor on my Xray T3. Ratio 6.64. Temperature after 5mins 180F. Hot right???
Punch through cornerring is still acceptable but on straight road I'm a loser. Tekin RS Pro bit me so well until I get really mad even do their ratio is 8.14. If their ratio same as mine, I will pack my bag and go straight home.
I think it is a time for me to upgrade my esc because a lot of my friends now using Tekin RS Pro and same motor as mine.
I heard about Hobbywing 120a and none of them are using it. If this esc can bit Tekin and make my motor cooler, I might consider it.
Pls help to advise on it because I'm confuse to choose between Hobbywing or Tekin RS Pro....
If you all said Hobbywing is better, tell me why and perhaps some comparison between Tekin RS Pro. Thanks.
Team MaxPower Malaysia...
Web : www.maxpowerbattery.net / www.bizonline2u.com
MaxPower / HobbyWing / Team Powers / Hudy / Xray / Robitronic / Tamiya / Tekin / Orca / LiteModz / Huge RC / MuchMore / LRP / Exotek / Smokem / SpecR / Atomic / SpeedMind / Sorex / Fijon / Paragon / Team Associated / Serpent / DS Racing
Afazli79 is offline   Reply With Quote
Old 05-30-2010, 04:04 PM   #402
Send a message via MSN to Matt_N
I've now got my Tekin going properly, and, to be quite honest, my Xerun fitted with the same motor can't keep up. Admittedly, the difference probably isn't worth spending an extra 150 or so for an RS Pro and Hotwire.
Matt
Matt_N is offline   Reply With Quote
Old 05-30-2010, 11:11 PM   #403
harry_mcoe's Avatar
come to alor star track..i'll show u how hobbywing 120a perform..tekin rs pro are dominated at alor star..or u can ask mr express rakyat
This Is MY WAY To The HI WAY.....
Old 05-31-2010, 01:35 AM   #404
smilekt's Avatar
pm me the hobbywing perform ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-31-2010, 01:49 AM   #405
P.I.M.P's Avatar
hi guys i run my hobby wing 518 on Sunday and the times where same as my tekin times and the hobby wing setting where on the conservative side to and the brakes where great so well done to hobby wing for bring a product that works better and alot cheaper then a product that cost more ie(Tekin).
Vbc wildfire D06
clinton livingstone
