Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-16-2011, 07:06 PM   #4021
Mike Haynes's Avatar
I just started playing around with this esc for modified outdoor, and running a 5.0 on a big paved track with boost and turbo is pretty awesome
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-16-2011, 07:54 PM   #4022
Originally Posted by TryHard View Post
Seriously though, boost really shouldn't be needed for a mod. The RPM's they turn is a lot higher than a stock motor, and you'd want to be setting the boost level higher than 15,000rpm to avoid overheating the motor too much (more timing = more amps = more heat).
Turbo's different, as it will only kick in after being at full throttle, and can be used for getting back some top end. Basically means can use a smaller pinion on the in-field (more grunt out the turns), and compensate the top-end with turbo.. simples.
LRP X12 4.5t...
advertise, rpm 56880, 7900kv...
on motor checker (manufacturer timing), rpm 67696, 8059kv
zamrioo2 is offline   Reply With Quote
Old 03-16-2011, 08:57 PM   #4023
anybody do dyno for HW...?
Old 03-17-2011, 01:55 AM   #4024
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i saw have new software uploaded in HW website...0310
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-17-2011, 02:01 AM   #4025
dameetz's Avatar
Just wanted to share a video I took at my local track. The guy was using 3.5t motor using STOCK fw with full boost and turbo
+ YouTube Video
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-17-2011, 02:14 AM   #4026
Originally Posted by COBRARACING View Post
please lets talk live on msn or skype and i can help you out .
teamcobraracing@live.com or skpype teamcobraracing
regards Angelo
When can i contact you on skype
2 Bar Boost is offline   Reply With Quote
Old 03-17-2011, 02:43 AM   #4027
defcone's Avatar
Trader Rating: 15 (100%+)
+ YouTube Video
That's what you get for running green shocks on a pink car.
defcone is offline   Reply With Quote
Old 03-17-2011, 05:43 AM   #4028
+ YouTube Video
Oh. No... That's no way,...
i hope Hobbywing as soon as possible released the RPM Log,
i don't want to burn Things up, no matter using Mod Firmware either..
Michael i want that RPM Log!
flashrevolution is offline   Reply With Quote
Old 03-17-2011, 06:28 AM   #4029
M7H
M7H's Avatar
If that happens, the log is gone up in smoke to....
Serpent
M7H is offline   Reply With Quote
Old 03-17-2011, 06:37 AM   #4030
2wdrive's Avatar
people can you all please stop qouting messages with a lot of pics in it or video's? It makes a mess. You can also quote the message and remove the video attachement. It is still clear what you are referring too, specially if someone already qouted the message in front of you!
About the video, why are you so dramatic about it? Clearly he is not smart if he uses a mod motor with full boost and turbo. So he blows up an esc, so what. Doesn't mean you have to do the same.
Reminds me about someone on my hometrack who used a tekin with full timing, turbo and full mechanical timing on the motor and some made fuss about it that the motor blew up and they blamed the dynamic esc for it on a dutch forum. .
2wdrive is offline   Reply With Quote
Old 03-17-2011, 06:47 AM   #4031
steveonamission's Avatar
Exactly, same with the idiots that charge lipos at excessive amps and then post it on youtube making the world think there dangerous and can malfunction at any moment.
steveonamission is offline   Reply With Quote
Old 03-17-2011, 07:19 AM   #4032
hacker's Avatar
Trader Rating: 140 (100%+)
Default 213
so what's the difference b/n 211 and 213?
have not had time to look at 213 yet!
hacker is offline   Reply With Quote
Old 03-17-2011, 07:24 AM   #4033
all the big names had log, because they care their customers.
this one not ?
and your saying the no timing gone in smoke too...?
Old 03-17-2011, 07:25 AM   #4034
M7H
M7H's Avatar
+1
+2
But don't forget about the other idiots, reading and believing it, without further questioning the circumstances...
Serpent
Old 03-17-2011, 07:30 AM   #4035
M7H
M7H's Avatar
this one not ?
LRP has a log?
Black Art?
Speedpassion?.. (oke, not fair...)
GM, oke, but you also need to be a genius, to be able to program all 50+ settings it has....
I don't know what you are trying to say, but it is You who quote a youtube movie which clearly is of a certain morron, who maybe even did this on purpose, and then you want a log, because you are afraid it might happen to You too?...
I'm confused...
Serpent
