Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-15-2011, 07:56 AM   #3961
Originally Posted by TryHard View Post
Again, still don't know why max RPM is useful.. as full boost will have been long added before then. But anyway, I've updated the speed chart to help a little.
Second tab, has a summary table of what speed should be achieved for a given rpm vs rollout (thereby removing gearing/tyres/etc from the equation). For 42kph, your rollout is going to need to be near 70mmpr if you think your only getting 11,000rpm.
HiH
Ed
Ed, looks good mate, will take a proper look when I get home from work, I did this as well at Maritime with a speed gun to get rpm going onto the straight to enable setting timing switchpoints on another speedo, but it's always interesting to learn about this stuff
Hope everything is good over there for you, shame you're not here for some WLRC action this year !
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-15-2011, 10:24 AM   #3962
darrenoakley's Avatar
Originally Posted by cherry2blost View Post
OK so you want me to delete it then?
OK will do it now.
Had a skinfull of this place .....
Hi mate I didn't get to see the post you deleted but if it was the set up sheet I would like to use it if possible please.
I do agree though this thread is starting to get full of muppits. If someone has gone out of there way to design some thing or post something useful on the forum and you dont want to use it why even comment ? Just dont use it.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 03-15-2011, 10:37 AM   #3963
+1 what he said!
stevebaker is offline   Reply With Quote
Old 03-15-2011, 11:42 AM   #3964
HiH
Ed
Max RPM is needed mainly because I want to keep my RPM under 45K. Novak warns against revving their motors above 50000 rpm as the rotor may explode. RUnning 1S this obviously isnt a problem, but when running 2S Mod motors, it would be nice to know.
Shawn.
Ps. My rollout is 85mm. :-)
Shawn68z is offline   Reply With Quote
Old 03-15-2011, 11:42 AM   #3965
cherry2blost's Avatar
Deleted
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-15-2011, 11:44 AM   #3966
HiH
Ed
What file format is the file?
Old 03-15-2011, 05:40 PM   #3967
And it's not blost, it's Cherry, if you had been here for more than a few weeks and been reading all the way through you would understand that.
Whoops Cherry are you Not happy,
"like i said i like your Design!"
and never told you to delete your Link's
(but the images is too big)
i just, unhappy like you,
and wonder if those Setup Sheet is already on Hobbywing Interface,
Setting's like Yours i can do simply by pressing Alt+Printscreen
and paste it to my paint, and save it.
But i Prefer Hobbywing To improved their interface on their Export Settings
and add the Import Settings as well...
I Like Sharing Setting's but i Hate when i have to do it manually.
and the availability of Profile inside Firmware is wasted because every time i change firmware, all setting's change to factory default.
If we can Import The setting's of what We have been Export it,
Those Problem Solved, and We can share Easier.
flashrevolution is offline   Reply With Quote
Old 03-15-2011, 05:52 PM   #3968
deleted
Old 03-15-2011, 06:00 PM   #3969
genuinely entertaining
cheapskate.brok is offline   Reply With Quote
Old 03-15-2011, 06:01 PM   #3970
Trader Rating: 8 (83%+)
hey guys spent all day setting up 211 and this is what i have ended up with.
After 5 min runs motor was coming in at 60c
Fdr 5.92 26tpinion,81t spur
boost timing-48
turbo slope-24
turbo timing-20
start rpm-4000
turbo delay-0.1sec
timing acc-350
drrs-2
A mate had his 4.5t out at same time and was really close on speed with it.
All i can say is gotta love the feel of 211
shano83 is offline   Reply With Quote
Old 03-15-2011, 06:05 PM   #3971
http://www.mediafire.com/?cgkkmr5fifdzw87
Setting Sheet TC V1.4 ^^
http://www.mediafire.com/?50y7w4xgpssi86b
Setting Sheet Pan Car V1.0 ^^
No S#@T sherlock!
No
Fine. Carry on doing that then.
Ask them then, send an email to
Mr. Yannick Yuan
E_Mail:
help@hobbywing.com
MSN:
hobbywing_help@msn.cn
Is it that much of a hardship?
Different firmware demands different settings
'nuff said
That's Right every time you change setting on different firmware,
can be done by simply importing setting's.
and every time you release setting's we can simply importing.
Simple right..
and.. do you think Yannick will respond ?
what about angelo ? michael ?
Old 03-15-2011, 06:09 PM   #3972
deleted
Old 03-15-2011, 06:30 PM   #3973
Can join Irgo on my ignore list can't be doing with this anymore.
So you are sayin it's useless if i am using Xerun hobbywing ?
so i will stop using one ?
you cried, but you delete it. why
so i must use your setup sheet.
change setting's on the your setup sheet, and get's nothing changed on my firmware setting's ?
So... were just playing with your setup sheet right ?
and don't tell me if you have to do it manually to enter the LCD or pc interface setting's, because that's wasting time..
Oh you are right We do have Cherry Setup Sheet
Cheers
Old 03-15-2011, 07:05 PM   #3974
TryHard's Avatar
it's a .xlsx file, so latest Excel (2007? I don't keep up with office!). Rctech doesn't allow attachment of .xls or .xlsx, hence the zip file
Old 03-15-2011, 07:14 PM   #3975
irgo's Avatar
Shawn.
indeed shawn, we here really need to know the exact rpm to decide,
Start RPM and which acceleration fit on track,
so we can really racing, instead Blind setting's.
1Scaled racing is always using Tacho on it's car.
10 Years in Brushless i drove blind car.
Quark Force
irgo is offline   Reply With Quote
