Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-14-2011, 06:01 AM   #3931
Send a message via MSN to geubes
Originally Posted by hacker View Post
just remember that the total available timing is 64. You can set your timing to 64, your turbo to 40, but because you have selected all your 64 steps with timing boost, you will get ZERO turbo.
but what happens if you meet the turbo requirements before all 64 degrees of boost are added
eg, 64 boost, but you only using 30 when the turbo requirements are met....
does it ignore the turbo (which will add timing quicker than boost), or does it then add the turbo until it hits 64, then any excess boost and turbo is left out?
worth thinking about
geubes is offline   Reply With Quote
Old 03-14-2011, 07:15 AM   #3932
irgo's Avatar
Originally Posted by COBRARACING View Post
211 as the 213 is not available but it seems irgo has got it wow and i haven't lol
ha..ha you are joking aren't you angelo, it's there official on HW.
So... When is the RPM Log release, cant wait any longer friend..
Quark Force
irgo is offline   Reply With Quote
Old 03-14-2011, 07:17 AM   #3933
hacker's Avatar
Trader Rating: 140 (100%+)
haha there's nothing to think about.
if you have 64 timing boost, you have 0 turbo.
'64' is the magic number you have to work around. It all adds up to 64!
hacker is offline   Reply With Quote
Old 03-14-2011, 07:18 AM   #3934
AGNO's Avatar
This weekend I attended the first race GMV 2011 in Tuscany, Italy, I won the race by taking the TQ and also made ​​the best lap.
For those interested this is my setup:
The track is very technical and small, only 17.5 Superstock category
ESC - Xtreme
Engine - Xerun 17.5
FW - 211
FDR - 6,3
4 - 9
9 - 50
10 - 18/0,1s
12 - 20
13 - 3000rpm
14 - 0,1s
15 - 250rpm/Deg
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-track-n%B01.png   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-foto-pista-1-grande.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-foto-pista-4-grande.jpg
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-14-2011, 07:25 AM   #3935
where i can get the new firmware?
jorgesimes is offline   Reply With Quote
Old 03-14-2011, 07:37 AM   #3936
darrenoakley's Avatar
I thought turbo only comes in once you have reached max boost programmed in and are still at full throttle. If you have 64 boost I wouldn't have thought you would be at full throttle if you only use 30.
This side I understand just wasn't sure on the total amount.
Could be wrong though.
You missed a crack yesterday mate. Hope the hangover was worth it
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 03-14-2011, 09:23 AM   #3937
Originally Posted by defcone View Post
There fixed it for you, so you mean if you run mod or high load motors, need to be careful not to dump your lipos as the voltage cut off doesn't work as well for high load situations?
Originally Posted by irgo View Post
it seem that the Cutoff (no matter you are using The Stock Firmware)
is Designed for Mod/High Load for safety reason.
but this had negative effect when using Stock/Low Load.
we found setting cutoff custom 6.7v = "lipo end3.3v/cell(Mod)" = "lipo end3.15v/cell(Stock)".
depend on Cutoff performance, this also had bad effect when Lipo already
reach near the Cutoff and Kicked with Turbo.
Originally Posted by Will27 View Post
My understanding of this is that
High load(Mod) = larger voltage drop, meaning it cuts off earlier.
Low load(Stock) = Less voltage drop, less difference between load and no load measurement.
So basically, if you set your cut-off voltage the same for stock and mod, and run both cars to the cut off, then measure both batteries, the mod battery will have a higher voltage, because they both hit the cut off voltage under different loads. When the load is gone, you get the true voltage
If this makes sense:
Mod: Cutoff voltage = V Battery(no load) - V drop (bigger V drop=Higher Battery voltage)
Stock: Cutoff Voltage = V Battery(no load) - V drop (smaller V drop=Lower Battery voltage)
So, be careful about cut-off voltage in stock classes according to irgo's findings? (use a higher setting)
I hope I've got that right
Thank you all defcon,irgo and will27
so.. i will need to raise the Cut-off voltage for Stock.
flashrevolution is offline   Reply With Quote
Old 03-14-2011, 09:36 AM   #3938
begrie's Avatar
Hi, which one is better for touring with 2s + 10.5T orca motor.
Xerun 60a or xerun 120a?
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 03-14-2011, 10:28 AM   #3939
cherry2blost's Avatar
Deleted
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-14-2011, 12:59 PM   #3940
Jack2's Avatar
Originally Posted by cherry2blost View Post
Xtreme Stock everytime
Interesting. I need something to run mod & 13.5, what disadvantage is there running a 120amp hobbywing/speedpassion GT 2 pro V.s Xtreme stock/pro stock etc? running same software etc?
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 03-14-2011, 01:44 PM   #3941
the only disadvantage i can see between the 2 is that the 120a is taking alot more space in your car
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 03-14-2011, 02:18 PM   #3942
TeamWTF's Avatar
I say 120a. Much tougher.
I have recently switched from Xtreme's to 120's so i can switch between mod and stock racing.
With the 120a and 17.5 with boost i dont need a fan which means that it weighs the same as an xtreme with a fan....
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 03-14-2011, 02:36 PM   #3943
Put it this way the guy who won 11.5 at the titc used a 120a....In all honesty though you would not tell the difference between the 60/120 or extreme stock. In my opinion the 120 represents the best value due to it's ability to run mod but also costs the most
Bony85 is offline   Reply With Quote
Old 03-14-2011, 03:04 PM   #3944
Originally Posted by Tire Chunker View Post
Amazing the temp is so low-how was the punch out of the turns? I am running 1224 how did the settings 211 compare? Did you just start from scratch and play with the settings?
Punch was great, I had to use throttle control, or I would drift the rear of the car around the corners! I am running 211 from now on (or maybe try the 213 this weekend).
I think I am also going to increase my rollout to 85mm.
Shawn.
Shawn68z is offline   Reply With Quote
Old 03-14-2011, 03:10 PM   #3945
The 120A is also heavier. Not such a major concern for a TC, but it is a concern for 1/12 scale.
Shawn.
