Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-14-2011, 01:30 AM   #3916
blade072's Avatar
Trader Rating: 98 (100%+)
so i take it 211 is good....but 119 is what you are going to run??? but if your faster with 211 then leave it...
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-14-2011, 02:10 AM   #3917
COBRARACING's Avatar
The latest software is the 119 as most of you are aware of and 211 there is no such 212 release but there is a test version of the 213 but will not be released as yet .
The only difference between the 211 and the 213 is 213'S TURBO is limited by rpm ,but 211 was not . so 211 has more acceleration,but 213 will have a lower temp.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-14-2011, 02:29 AM   #3918
irgo's Avatar
Excellent tech option Angelo,
So how is this Turbo(213) Work's Exactly ?
i do feel Colder when using V3.0_110213
Quark Force
irgo is offline   Reply With Quote
Old 03-14-2011, 02:34 AM   #3919
blade072's Avatar
so do i run 119, 211 or the test 213??
David Randall
Old 03-14-2011, 02:35 AM   #3920
Will27's Avatar
Originally Posted by defcone
There fixed it for you, so you mean if you run mod or high load motors, need to be careful not to dump your lipos as the voltage cut off doesn't work as well for high load situations?
My understanding of this is that
High load(Mod) = larger voltage drop, meaning it cuts off earlier.
Low load(Stock) = Less voltage drop, less difference between load and no load measurement.
So basically, if you set your cut-off voltage the same for stock and mod, and run both cars to the cut off, then measure both batteries, the mod battery will have a higher voltage, because they both hit the cut off voltage under different loads. When the load is gone, you get the true voltage
If this makes sense:
Mod: Cutoff voltage = V Battery(no load) - V drop (bigger V drop=Higher Battery voltage)
Stock: Cutoff Voltage = V Battery(no load) - V drop (smaller V drop=Lower Battery voltage)
So, be careful about cut-off voltage in stock classes according to irgo's findings? (use a higher setting)
I hope I've got that right
Will27 is offline   Reply With Quote
Old 03-14-2011, 02:38 AM   #3921
every FW upgrade is base on what? i mean, do they make comparison with other ESC? honestly, we cant achieve as lower motor temp and top speed as tekin if we running at longer straight line and semi technical track... under direct sunny day, with the same motor n timing, tekin show not more than 60'c, otherwise HW i would say is about 78-79'c in 5min race... but at short n technical, i found that HW will dominate the track... this is refer to 199 as i still have no chance to test 211...
zamrioo2 is offline   Reply With Quote
Old 03-14-2011, 02:57 AM   #3922
blade072's Avatar
my understanding of the 2..
tekin runs more rpm....cooler
hobbywing more torque....hotter
so in bigger tracks a tekin is beter
on smaller technical tracks hobbywing is better
have used both
i prefer hobbywing
no need for a laptop at the track to adjust every setting
David Randall
Old 03-14-2011, 03:05 AM   #3923
211 as the 213 is not available but it seems irgo has got it wow and i haven't lol
Old 03-14-2011, 03:07 AM   #3924
blade072's Avatar
mine had 119, 211 and 213 ...
David Randall
Old 03-14-2011, 03:33 AM   #3925
millbank's Avatar
I ran the 213 yesterday at ardent raceway's kick energy winter championship and found it to be very good. I am a driver who doesn't like alot of initial rip so I ended up running a ddrs of 1 and boost of 20 and turbo of 40. I ran with a data logger in practice and found that I never really dipped under 7000 rpm so I set my boost to start at 9000. This gave me a very smooth acceleration out of corners and I knocked .5 of a second off my quickest time. Never saw temps more than 50 degree's. In all a very good job with new software, very impressed.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 03-14-2011, 03:36 AM   #3926
Hello all.
Cobra=> I still wait an answer from Hobbywing for an esc repair... I sent it directly to them 1 week ago and no new...
*LAF Painting*
february is offline   Reply With Quote
Old 03-14-2011, 03:39 AM   #3927
sizheng's Avatar
I think TEKIN has some current limit in the program which will make the motor cooler, but obviously it will cause the accelaration a little bit slower.
For top speed, I must say at the same FDR and all timing open, TEKIN and Hobbywing should be almost same.
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 03-14-2011, 03:48 AM   #3928
darrenoakley's Avatar
So am I right in thinking that I shouldn't go above 60 combined spread over boost and turbo. If I do will it bog down maybe ?
Also what motor are you running mate. Think we were in the same 17.5 heat at Chippenham this year but then I was running Tekin so new to this speedo setup.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 03-14-2011, 04:17 AM   #3929
hacker's Avatar
Trader Rating: 140 (100%+)
just remember that the total available timing is 64. You can set your timing to 64, your turbo to 40, but because you have selected all your 64 steps with timing boost, you will get ZERO turbo.
I would say most guys would be at 60-64 to get the most out of the speed control. I would dare say there are some in the 50's for total timing, however I would not bother turning up to race
hacker is offline   Reply With Quote
Old 03-14-2011, 05:01 AM   #3930
TryHard's Avatar
What motor out of interest?
I've been finding similar for lower wind Stock types (8.5/9.5/10.5 etc), less DRRS (1-2) and a higher boost start (around 8-9000), but with a quicker boost ramp (100-300), seems to keep the punch up out the turns, but also keep the motor cool... Worth a try for sure.
Ed
| THard.co.uk | Xray | MuchMore |
