Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-12-2011, 08:38 AM   #3841
begrie's Avatar
Originally Posted by hacker View Post
I noticed the very few setups on 119/211 that not many people max out the timing boost, compared to the tekin I almost always use max timing or around 50.
might take a while to figure out the best timing/turbo ratio to use. I ran 119 tonight around 40 boost/20 turbo and I had the quickest car, just the driver was mental.
Dude what Turn motor did you use?
Please help me here ....
Track highway at least 60-100feet with tight turn.
Motor im using is 5.5T with HW 120a.
Please advice what FDR range should i use?
Thank you
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 03-12-2011, 08:43 AM   #3842
hacker's Avatar
Trader Rating: 140 (100%+)
Thank you
I meant I had the quickest car in my 21.5 spec class.
5.5T??
why dont you use the basic mod programs? which is what comes with the speed control if I'm not mistaken. You dont need timing with a 5.5
just drive it
hacker is offline   Reply With Quote
Old 03-12-2011, 08:50 AM   #3843
begrie's Avatar
5.5T??
just drive it
Basic mod dont have supercharge or turbo hehe. USing 518Mod at the moment.
Anyway.. i need basic ratio range for 5.5T. Dont want to blow my motor and batt.
Old 03-12-2011, 08:51 AM   #3844
Trader Rating: 16 (100%+)
Am I correct in thinking Hobbywing's firmware works with SP ESCs? What would be a good starting point for 12th scale 17.5 boosted settings and rollout, using either the Xerun 1s or SP GT2.1 EX, with SP 17.5 1s motor?
Search for "Mahamoti's FIRESALE" to see all my FS threads!
mahamoti is offline   Reply With Quote
Old 03-12-2011, 09:45 AM   #3845
TryHard's Avatar
With a 5.5T I was using between 8 and 8.5 on the FDR. That's using the 0119MOD firmware, so it only has turbo available, between 14 - 20 (again dependent on track size).
HiH
Ed
Old 03-12-2011, 10:24 AM   #3846
Chubba's Avatar
Hi I am looking for some help. Tried my new T3 today. Hobbywing v2.1 120a and speed passion version 3.0 competition 10.5T and very very slow
48pitch 78 spur gear and 28 motor pinion.
Best setting and which software is best to use?
A local racer said I need to change / adjust the timing bell.
Or is it my 120a esc problem? Do I need a 60a esc instead?
[Mugen MRX 5] [Yokomo R12] [Xray T3 2011] [Xray X10 Link] [KM HK-1]
Chubba is offline   Reply With Quote
Old 03-12-2011, 11:26 AM   #3847
irgo's Avatar
Default Hobbywing Michael Angelo
Angelo where are you...
This is March,
Michael Angelo.....
Quark Force
irgo is offline   Reply With Quote
Old 03-12-2011, 11:40 AM   #3848
This is March,
Michael Angelo.....
I want a rpm log....baby....
rbakker is offline   Reply With Quote
Old 03-12-2011, 11:41 AM   #3849
See Angelo, you are still required here.
Hobbywing v3.0_110213Stock
Done.
is Recommended, for anyone would like to get best of Hobbywing v3.0_110211,
but with better Power is the Hobbywing v3.0_110213Stock, no comment.
yet...
Irgo, where did you find this comment about 213?
I need to know, I have to start packing my gear for tonights racing, and havnt decided on which FW to run tonight. 1224, 211, or 213!
Shawn.
Shawn68z is offline   Reply With Quote
Old 03-12-2011, 11:58 AM   #3850
begrie's Avatar
HiH
Ed
Thank you so much m8! really appreciated you advice!
Old 03-12-2011, 12:43 PM   #3851
irgo's Avatar
Shawn.
Our Team tested.
we found no bugs yet..
Quark Force
Old 03-12-2011, 12:49 PM   #3852
cuttingedge's Avatar
211 Rocks
Please could we all vote on my new Shell for 2011
I know its off topic but hey ho
Visit www.car69.me.uk and Vote
I normaly Run the Chrome as in the header But i have had a Custom paint job done Should i switch
Its Up to you
Please vote
Thanks Trevor the driver of CAR69
Schumacher uk - Litemodz - Potters Electrical Supplys - The Sign Shack - www.car69.me.uk - Akula Racing
cuttingedge is offline   Reply With Quote
Old 03-12-2011, 01:51 PM   #3853
Jay_P's Avatar
Anyone else tried 211 with a SP GT2.0? Mine loaded on, worked but had no advance or turbo. Tried reloading twice and still the same, reloaded 119 and worked perfectly retried 211 still no advance/turbo
I know its not the sensor lead
Both my HW 1s's work perfectly with 211
Is this a new HW/SP thing?
Jay_P is offline   Reply With Quote
Old 03-12-2011, 03:03 PM   #3854
After doing an upload, always recalibrate your controller. I have found on acouple of occasions I have lost the calibration while switching FW's.
I also uploaded the FW twice (just because), and use a 2S battery, even though the car normally only runs a 1S. I dont know how HW has designed their controler, but I figure alittle extra voltage on tap couldnt hurt.
Shawn.
Old 03-12-2011, 03:04 PM   #3855
Our Team tested.
You do know you didnt answer my question right? And what did your team test?
Shawn.
