Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 03-10-2011, 08:09 AM   #3766
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
On the 8.5T 4.000kv running in STOCK mode with XTREME STOCK ESC, which would be the maximum temp that i would admit to go on 6 minutes runs ?
thanks
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 03-10-2011, 08:23 AM   #3767
razzor's Avatar
ideal is not to go higher than 70/75 deg/c but it varies from motor brands/winds used, what type of track as well as how you drive to mention a few.
if you can get good performance around +-60 - 65 deg/c i would say you good to go and can find more pace with chassis setup and get more corner speed as well as drive tighter lines and more consistent.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-10-2011, 08:44 AM   #3768
Tabushi's Avatar
The motor is a HOBBYWING 8.5T Sensored mounted on a Hotbodies TCX car running on RUBBERS over ASPHALT.
So, equipment is :
No timing/turbo permitted so will be STOCK,
any tip on temps?
thanks
Old 03-10-2011, 09:31 AM   #3769
razzor's Avatar
if you not running the turbo software then start with conservative gearing and gear up a tooth at a time and watch lap times. temps will go up gradually but wouldnt let it go higher than 75 - 80 deg/c. would also invest in a good heat sink like the LRP one.
http://www.lrp.cc/en/products/new-pr...efter/details/
Casterracing ZX1.5R
Old 03-10-2011, 09:53 AM   #3770
pasar minggu's Avatar
hello guys..
i just bought HW esc (119 stock) and still doesnt have any idea to set it.. i currently run it with tekin redline 10.5t motor and trf 416 chasis.. so what is the best setup i need to use? wish u guys can help me..
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-dmcs6%5B1%5D.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-niteview%5B1%5D.jpg
TRF 417 Hobbywing speed passion venom futaba savox Sakura Zero speed energy
-D'DALIMA RACING TEAM-
AmAr_D
pasar minggu is offline   Reply With Quote
Old 03-10-2011, 10:34 AM   #3771
stuey's Avatar
hi
what is the maximum timing that can be achieved with the latest software
(211) Is it 60deg or 64deg
stu
stuey is offline   Reply With Quote
Old 03-10-2011, 10:37 AM   #3772
64 deg (or steps)
Manu W. is offline   Reply With Quote
Old 03-10-2011, 11:04 AM   #3773
irgo's Avatar
Originally Posted by snabbgas View Post
Well then it would be just as smart to make the boost start rpm in percent wouldn't it?
Instead of 1000-15000rpm you could just go 0-100% because no one could ever be interested in knowing what speed the timing is started to beeing added or?
Sorry but i don't agree here, degrees are degrees and they are universal.
All the previuos softwares have been in degrees and i for one really like the idea that 5 degrees on the endbell equals 5degrees in the software!
It's a completely different ballgame in the case of for example the Punch setting or the brake. You cannot meashure it in any good way so here % or steps or whatever is good.
And unfortunately it isn't as easy as putting more timing in always makes more power.
It's a case of putting exactly the right amount of timing in at the right point as more timing at low rpm can make less torque hence less power.
That beeing said. The hardware and software are truly awesome for the price and at this point i would not considering anything else!
Thank you Hobbywing but please bring back the degrees in the upcoming softwares!!!
At the very least provide info on how many actual degrees of timing the new 211-213 softwares have so i can calculate how many degrees 1 step represents!
/Mattias
Very good Mattias, i know sweeden people like to be scientific.
degrees is degrees, i could not teach student's with aliases.
it's better to use 0.5deg increment's rather than aliases.
Quark Force
irgo is offline   Reply With Quote
Old 03-10-2011, 11:08 AM   #3774
stuey's Avatar
Originally Posted by Manu W. View Post
64 deg (or steps)
thanks
Old 03-10-2011, 12:06 PM   #3775
Tabushi's Avatar
Thanks, will take a pic of my setup and will post it tonight ... right now i geared 6.3 FDR
thanks,
Old 03-10-2011, 12:12 PM   #3776
Default The reason that there are 64 timing steps
/Mattias
There is a very clear practical technological reason for having 64 steps. One of the HobbyWing guys alluded to it a few days ago.
The HobbyWing speedo has onboard memory. The advanced timing programs are becoming more complicated than the speed controls were ever designed for. This means that every Bit of information counts.
Now, memory is just a string of 0's and 1's, and therefore you must make numbers out of these 0's and 1's. To have an on/off switch there are two possible states so you can use a single Bit to describe it. to make a number that is up to 2^n you need n Bits. This means that you need 1 Bit to have a choice of 2 options, 2 Bits to have a choice of 4 options, 3 Bits to have a choice of 8 options...6 Bits to have up to 64 options.
This 6 bit address limit is the reason that you have 64 steps/options for timing. To change it to % you need at least 100 options requiring an extra Bit. This is the reason for having 64 steps. As this is still beta software I can completely understand why they use this number, and maybe for the release software they could use % or something similar with a courser step size. While it is beta is is good to have the software as tunable as possible.
What I do agree with is that it would be nice to have a conversion to actual degrees of timing, if only to compare different software versions.
Hope this clears things up a little
Ben
Rocking Donkey is offline   Reply With Quote
Old 03-10-2011, 12:40 PM   #3777
Andy63's Avatar
hey all! I have only one question. what firmware version is the best for 17,5 stock racing? And also got good brakes, and good temp in the motor?
Thanks alot all!
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 03-10-2011, 12:52 PM   #3778
steliosh's Avatar
delete... sorry!
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 03-10-2011, 02:37 PM   #3779
Originally Posted by pasar minggu View Post
hello guys..
your track about similar like our local track... straight is about 200ft... try this... (motor timing at 9deg instead of manufacturer timing is at 12deg)
fdr 7.0-7.4 (7.4 is my current)
punch 9
boost 36
ramp 18
turbo 24
start 5000 - 8000 (pls select your preference)
delay 0.3/0.4
accl 350-400
this is my current setting with RX2 10.5 motor... all is same except boost acceleration which is mine 300... u shud try 350 as i think tekin motor prefer little bit more rpm...
zamrioo2 is offline   Reply With Quote
Old 03-10-2011, 02:45 PM   #3780
2wdrive's Avatar
looking at the HW website i see version 310 in the dl section.... what is that?
2wdrive is offline   Reply With Quote
