Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 03-08-2011, 04:27 PM   #3661
Originally Posted by M7H View Post
I did.
Let me try to explain, what I found out with Lipo's.
In my M11X transmitter, I have a 2S 2300mAh Lipo, why do I say that, well listen.
Fully charged, it is 8.4V (Duh ) Because I wanted to find out how long I could use my TX, I used it for several days, without charging. At the start of the last day, the battery voltage was 7.4V, which is nominal, so I thought I could still us my TX for a while (was already using it for 10 Hours up to to then)
But on the drivers stand, after a few minutes my transmitter started giving me low voltage alarms, and after checking the display, the battery was 6.7V.
So, conclusion, I drained the Lipo slowly, but when it reached 7.4V, it actually was almost empty.
Going back to the ESC.
The cut-off kicks in when the Lipo, under load goes under the set Voltage for more then 2 seconds.
The Lipo cut-off I have set to 3.4V (I drive 1S) and when the cut-off kicks in, I can still finish my lap (but slowly) and if I then measure my Lipo, it is around 3.7 - 3.8V
If I set the cut-off to 3.2V, the ESC doesn't give me the possiblity to finish my lap, and is even beeping the low voltage alarm... Lipo voltage is then also 3.2 - 3.3V
My conclusion, together with what I found out with my TX Lipo is that a Lipo set at a cut-off of 3.2 will just drain my lipo's to far, 3.4V is ok for me, for your information, I get 11+ minutes runtime on 3.4V....
I suggest you set your cut-off at 6.8V, just to check what happens...
i got confuse on your post "7.4v was almost empty"
but
thank's for suggestion.
flashrevolution is offline   Reply With Quote
Old 03-08-2011, 04:29 PM   #3662
I'm using a Intellect 2S 4000mah 20c with a Xerun / 17.5t and it seems to lack punch (Turbo doesn't hit hard) after two mins of driving running the 119stock software.
Would a larger / high rated LIPO make a difference or should I be looking elsewhere ?
Cheers Alan
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 03-08-2011, 05:33 PM   #3663
TryHard's Avatar
Originally Posted by irgo View Post
Cherry there is something more important, than timing for while now,
did you test the voltage cutoff with 119
i was also find similar cases anomalies.. on 119 perhaps you can proceed the progress to find out ?
because i am still busy with V3.0_110211 for while...
Voltage cut-off on 119 works, trust me on that... 10mins with a 9.5t in high boost settings was enough to dump a couple of LiPo's at the weekend! Had voltage protection switched on, and the car just rolled to a stop when the limit hit.
Old 03-08-2011, 05:52 PM   #3664
cherry2blost's Avatar
Default My settings
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-08-2011, 06:05 PM   #3665
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
Wow very nice Cherry. Do you have the file for download?
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 03-08-2011, 06:22 PM   #3666
Originally Posted by COBRARACING View Post
Dear Guys
Here we are with the proper info :
The timing is programmed to function in single step increments not timing related to angle .so every change you make is in (steps) increments to a maximum of 64 steps may it be internal timing(which changes dynamicaly or turbo timing (related to time).nothing else .
for example if you are running 40 steps in internal timing(related to rpm) and 30 steps in turbo timing (related to time) the effective timing (steps) will be max 64 steps with the 211 software ,were the extra 6 degree (steps) of timing will be useless and thats from the turbo timing not the internal timing .i hope you all understand .
the most important is the internal timing which is a total of 64 degree (steps) not degree angle) max now if you run max internal timing at 64 degree Steps) and 30 degree of turbo timing (Steps) the efective timing is only the internal timing and the 30 degree of turbo timing is wasted no turbo .
conclusion timing is related to steps not angle of degree.
I hope that it helps you guys out
Yes thiis clears that issue up. Thank you Angelo.
Shawn.
Shawn68z is offline   Reply With Quote
Old 03-08-2011, 06:45 PM   #3667
Originally Posted by cherry2blost View Post
Wicked!!!!
cheapskate.brok is offline   Reply With Quote
Old 03-08-2011, 06:47 PM   #3668
BRC
BRC's Avatar
can someone point me to the 1102211 software...
HW website still only has the 110119 software
EP Touring: Xray T4'14 / DualSky 870 combo
GP Offroad: Agama A8 / RB WS7
EP Drift: Xray T2'007 / Mamba Max
Mini: M05 Xevo conversion
Mini Z: Atomic BZ
BRC is offline   Reply With Quote
Old 03-08-2011, 07:39 PM   #3669
smilekt's Avatar
give your email .. i will email to u
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 03-08-2011, 07:41 PM   #3670
smilekt's Avatar
which one generate more heat .. boost timing or turbo timing ?
Old 03-08-2011, 07:43 PM   #3671
sizheng's Avatar
I think all of us should appreciate Angelo first for his hard working instead of complaint.
Almost everyone wants to be fast and want to use the newest weapon just because we are racers. But not everyone knows how the new weapon works even the brother of the weapon maker. Hope you guys can understand my english.
I had posted that the total real timing degrees applied to the motor were same from the version 100518 to latest 110211. (The only one should be mentioned is 101224, it really has some different concept but it was just a test version and now was proved not to be good enough for all kinds of applications by the factory, so it was not released by hobbywing official. But drivers like M7H found it very good for his driving, so just keep it and wait for the better one comes out.)
The difference in timing adjustment of 518,119,211 is from the newer version you can set it with more accurate steps. even 119 (60 steps) and the coming 211(64 steps) is the same. Irgo, I'm very sorry you just posted your imagination and confused so many users, let me tell you how your "4 degree secret" is coming. In 119, Michael has the initial fixed 4 degree(step) applied to the motor, so for users, we setting 0-60 degree(step) actually is 4-64. But in 211, for some detail technical reason , Michael cancelled the initial fixed 4 degree and made it adjustable with the other 60 degree(step), so that's why 211 is 0-64 adjustable.
I must say I really don't want to talk about such details which is not important to we players. I think we should run more on the tracks and found the good settings. The improvement of FW is NOT more timing degrees now, it's the method to make your control smooth and efficient and more adjustable so that the drivers can do faster laptimes by finding the perfect setting.
Hope above can be understood, sorry for my english not as well as you.
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 03-08-2011, 08:10 PM   #3672
venom54's Avatar
Default MANY THANKS
Thank you very much for clearing some questions in relation to timing degrees.
Yes the best situation to clear setups is to set all parameters to the careful low temp options and start from this point to set up for your local track. Been there and destroyed two motors just trying to go fast!
All tracks are different and all brushless motors are different.
A point to this, just set a TP21.5P and a SP21.5V3 with identical software options but knowing that the two motors are different had to set FDRs different.
The SP21.5V3 spools up nicely but does not have the steady climb into turbo territory, a little jump on throttle occurs, where as the TP21.5P is super smoothe and a nice clean but very progressive climb into turbo territory where the motor goes nuts with extra RPM!!!!
Must now go and test......results soon.
Just an insight from across the seas.
Cheers
Ren
P.S. I am impressed.
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 03-08-2011, 08:43 PM   #3673
Timing, no matter how it is applied creates heat in the motor, by lowering its effiency, which increases its current draw.
Generally most people consider Turbo to create more heat because it is only used when the motor is at high speed, and already has alot of timing. So by adding more timing the motor will create more heat.
But its not the turbo, or the boost itself, just a function of the timing.
Shawn.
Old 03-08-2011, 08:57 PM   #3674
irgo's Avatar
yes, i do get the Smooth Cutoff work's, but why is the lipo end Voltage below the Cut-off Custom Voltage?
yes. nice explanation you got there,
Quark Force
irgo is offline   Reply With Quote
Old 03-08-2011, 09:00 PM   #3675
COBRARACING's Avatar
Dear friends
Please also remember that when we say timing we mean Steps of current that is required to advance the timing not timing like you see on brushed motors where you turn the end bell of the motor from 10 degree to 60 degree etc thats all mechanical timing also known as (centrifugal timing advance) so the faster the motor spins the more timing is advanced the more powerful the motor gets .
what we talk about is electrical/electronic and related to current increasing/decreasing and not the angle of the timing to increase the current flow .So the steps we use example 64 steps not degree relates to current increase or decrease per step and we can increase the current flow much faster by using a timer to ramp it up .were the dynamic steps use rpm the turbo function uses time .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
