Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-05-2011, 01:16 PM   #3556
RC MARKET's Avatar
Originally Posted by SammyZ View Post
thank you!
OK !
RC MARKET is offline   Reply With Quote
Old 03-05-2011, 02:19 PM   #3557
Hey Guys,
Sorry if this has been mentioned over and over but im just getting ready to race 10.5 tomorrow from modified and just need this confirming
The 119 firmware does use steps? and not actual degrees?
I believed that 1 step = 1 degree? wrong ?
So 1 step = 0.66 actual degrees of timing?
Thanks to anyone who replies
Stefan C
Stefan-Hpi Uk is offline   Reply With Quote
Old 03-05-2011, 02:44 PM   #3558
M7H
M7H's Avatar
Originally Posted by Shawn68z View Post
We have already gone through this before. As of right now, the last FW version that is available 0119 uses steps, and not actual degrees. Angelo previously in this forum apologized that the current manual created confusion, and does not actually represent the current FW accurately. The last released FW to use degrees is 1224.
Lets create some more confusion.
Ehh, I really thought that the 1224 max 46 was actually 60 real degrees!
Ps. Besides, I am running 0119 with 15deg Endbell, 60 Boost, 20 Turbo. 95 Deg? My motor would be running backwards.
60 is the total available timing, so 60 boost and 20 turbo will only make 60 total....
But I think 75 total timing is possible, only not when you apply it when the motor RPM is zero.
Serpent
M7H is offline   Reply With Quote
Old 03-05-2011, 03:22 PM   #3559
irgo's Avatar
i like you M7H,
That's True Guys it's "60" on version 3.0_110119
and what ever the timing is set to over 60 Steps ex:70, it's end is 60
by completing the Priority it's the Boost first, or completing with the turbo if the full throttle is activated.
an excellent technologies that Michael build.
and Angelo have been showing the new 110211 (213)_STOCK Firmware
that it has "64"
which is "4" over timed than the theory 60, it's a new secret.
Quark Force
irgo is offline   Reply With Quote
Old 03-06-2011, 01:06 AM   #3560
Originally Posted by guinnes.s View Post
im asking about the difference because the sp13.5t with any settings under 50 o 55 boost is a donkey,when others with different brand motors are using about 30 to 35 boost leaving them with more turbo setting to play with.
does mean the hw would be the same?any suggestions.
because Your final Gear too small. try higher pinion.
is the firmware with the elogger out yet?
Angelo said it's implemented now.
flashrevolution is offline   Reply With Quote
Old 03-06-2011, 01:37 AM   #3561
COBRARACING's Avatar
I said no such thing ,what i said was michael is going to program a rpm log only for the esc soon .Not completed yet.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-06-2011, 01:52 AM   #3562
whoops, sorry Angelo, you're not mad at me right
but that's a Great News!
thank's angelo.
Old 03-06-2011, 01:59 AM   #3563
irgo's Avatar
wow Nice!, Keep inform us the progress angelo,
Quark Force
Old 03-06-2011, 02:09 AM   #3564
guinnes.s's Avatar
Done that and is slowwwwww,like I said anything under 50 does not perform atall. I will have to try s different motor maybe.
guinnes.s is offline   Reply With Quote
Old 03-06-2011, 04:15 AM   #3565
RevMaxx's Avatar
Send a message via MSN to RevMaxx
any of u guys experience this with 119 firmware?
i flashed my Xerun120A V2.0 with 119 firmware (did it twice as suggested here) and configured the settings to my preferences. after which i calibrated my Tx and ESC.
i noticed that when i run the car right after callibration, i sometimes would loose initial punch. the motor punch right after you pull the throttle would be significantly lower... turbo would later kick-in as u can really hear the motor screams but initial motor punch is really missing.
i believe its DRRS setting has been lost during calibration, coz when i reprogram the ESC with the LCD programmer by just setting the DRRS to my preferred value (DRRS = 8), the initial punch returns...
just want ur thoughts or have you experience this on your set-ups?
RevMaxx is offline   Reply With Quote
Old 03-06-2011, 04:21 AM   #3566
defcone's Avatar
Trader Rating: 15 (100%+)
I think it's just the voltage in your lipo dropping and thus not getting the same level of punch as a freshly charged lipo.
defcone is offline   Reply With Quote
Old 03-06-2011, 05:07 AM   #3567
RevMaxx's Avatar
nope, i think batt voltage is not the cause. i replicated the problem and did it on my table with a newly charged batt, did not run the car on track. same thing happened. the turbo still screams but the initial punch was missing. programmed it to DRRS=8, and punch was back again.
i'll monitor this particular esc if it runs funny...
Old 03-06-2011, 08:02 AM   #3568
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Samll query here ...
I installed my ESC + Motor from Hobbywing, updated software, selected 508 no timing version as i will be racing 8.5 stock BUT the led in neutral is not blinking as supossed to be for legality checking ...
Power is great no turbo nothing, but if i go to tech, will not pass because of the non blinking led (an alternative is to go with program box and show to tech guys to check through that) ...
Any tip ?
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 03-06-2011, 08:23 AM   #3569
razzor's Avatar
have you recalibrated the esc after installing the firmware ?
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-06-2011, 08:52 AM   #3570
Didnt think that would slip past you, you are correct. However, I have run 75 degrees on a motor, and it slowed the motor down, and created alot of heat. I left the Novak at N (30) and ran the 46deg from the 1224 software, motor was dead slow, and created alot of heat. I should have probably run the overheat protection.. Oh well.
Shawn.
Shawn68z is offline   Reply With Quote
