Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 03-04-2011, 09:17 PM   #3541
irgo's Avatar
Originally Posted by Shawn68z View Post
You need to provide alot more information. Type of car, motor, gearing, track layout, and the ESC settings.
With the 119 (or 1224), you can easily Over time the motor, and it sounds like this is what you have done. Try upgrading back to the 119 software, and then start very conservative on the timing. We do know that step #54 Boost is 36 deg of timing. (Confirmed here on Rctech).
Brushless motors will not run properly with more then 60deg of timing, they tend to run slow and make alot of heat.
Shawn.
64Deg on V3.0_110211(213)
Originally Posted by COBRARACING View Post
quality wise yes perfromance similar.Also better hall sensor board which is designed by michael .
What some of you may not know the motors are actually designed by michael at hobbywing and then manufactured in a part owned hobbywing factory
Angelo you got pm..
Quark Force
irgo is offline   Reply With Quote
Old 03-05-2011, 04:49 AM   #3542
guinnes.s's Avatar
Originally Posted by guinnes.s View Post
this are the setting that i used for first time at my racing club.
110119 with sp13.5 v3 at 7.4 fdr ,max temp 72c
4 DRRS 8
9 boost timing 55
10 turbo slope 24
12 turbo timing 30
13 start rpm 2000
14 turbo delay 0.4
timing acc 200
the car felt really quick in the infield and at beginning of the 30 metre straight,but the turbo did not felt to have any punch.what setting could help?
thanx
Originally Posted by sizheng View Post
You almost used up timing in boost, 2000+200*55=13000 , and with 7.4 FDR, the speed of your car is only 20km/h at this RPM.
im asking about the difference because the sp13.5t with any settings under 50 o 55 boost is a donkey,when others with different brand motors are using about 30 to 35 boost leaving them with more turbo setting to play with.
does mean the hw would be the same?any suggestions.
guinnes.s is offline   Reply With Quote
Old 03-05-2011, 05:40 AM   #3543
cherry2blost's Avatar
Right the workout maths is right, but that does not mean that the motor stops pulling once all the timing is used up... 13000 RPM would be where no more timing is added but the motor will continue to accelerate, so that's not a right answer there.
I run 50/18 have 200ACC and start at 2000RPM the elogger logs my max RPM on a 13.5 at 45000 using your maths my car would only be doing 12000 RPM as the boost stops this plainly is NOT the case so please lets get some correct facts / maths on here.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-05-2011, 05:54 AM   #3544
guinnes.s's Avatar
is the firmware with the elogger out yet?
Old 03-05-2011, 06:03 AM   #3545
wait a minute. The boost (timing) and turbo (additional timing, with 'boost' as preliminary) are indicated in steps and not in degrees?
Can someone define how much 1 step represent in degrees? Thanks
cheapskate.brok is offline   Reply With Quote
Old 03-05-2011, 06:18 AM   #3546
If it's linear then 1 step = 0.66 degrees and 1 degree = 1.5 steps.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 03-05-2011, 07:01 AM   #3547
defcone's Avatar
Trader Rating: 15 (100%+)
Is it just me or has battery usage been dropped dramatically with the new software? Right now I'm only using 1.4A per 5min race with my 17.5t as I remember using at least 2A with the old firmwares.
defcone is offline   Reply With Quote
Old 03-05-2011, 07:23 AM   #3548
false!
true is 1 = 1
break through from angelo manual
"with the precision of 1 degree steps."
flashrevolution is offline   Reply With Quote
Old 03-05-2011, 11:28 AM   #3549
SammyZ's Avatar
Trader Rating: 138 (100%+)
I dont know how to update the firmware on my LCD programming box, please help
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 03-05-2011, 11:53 AM   #3550
RC MARKET's Avatar
go to hobbywing web site download update USB Link V1.63
choice Device & 2 in 1 program box
Software page had button Upgrade click will ok !
RC MARKET is offline   Reply With Quote
Old 03-05-2011, 12:02 PM   #3551
Originally Posted by flashrevolution View Post
false!
true is 1 = 1
We have already gone through this before. As of right now, the last FW version that is available 0119 uses steps, and not actual degrees. Angelo previously in this forum apologized that the current manual created confusion, and does not actually represent the current FW accurately.
The last released FW to use degrees is 1224.
Cheers,
Shawn.
Ps. Besides, I am running 0119 with 15deg Endbell, 60 Boost, 20 Turbo. 95 Deg? My motor would be running backwards.
Shawn68z is offline   Reply With Quote
Old 03-05-2011, 12:05 PM   #3552
Great, bringing up FW that isnt released yet. Lets keep our discussions to FW that has been publically released shall we?
Shawn.
Last edited by Shawn68z; 03-05-2011 at 12:05 PM. Reason: Bad spelling, and even worse grammer!
Old 03-05-2011, 12:39 PM   #3553
Few things..... why have you got the new software and the UK team do not?
Oh frack it, it's just the one thing! I can't be bothered to ask any more.....
Old 03-05-2011, 12:44 PM   #3554
false!
true is 1 = 1
Angelo has already stated that the information was wrong and the the new instructions have been 'Pulled'.
Old 03-05-2011, 01:05 PM   #3555
SammyZ's Avatar
thank you!
Hotbodies USA
SweepRacing USA
