Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-03-2011, 11:56 AM   #3511
Anyone know the ESC setting for 11.5T that team Hobbywing used to Win in TITC 2011? i have race on sunday, i hope i can use that seting for my race (i use HW Xerun 120A V2.1 and HW 11.5T motor)
nietzbatik is offline   Reply With Quote
Old 03-03-2011, 05:03 PM   #3512
Originally Posted by Tabushi View Post
Guys,
If i have to race 8.5T (lipo 7.4v) touring class STOCK (no turbo, no timing allowed). Will the XTREME STOCK perform in the same way as XERUN 120amp ? ... or because of the higher "amp" of the 120amp (xtreme stock its 60amp), will be stronger ?
thanks,
As long as you have the same settings in the ESC they will perform almost identically. However, 8.5T is the limit of the Xtremestock. Personally I would run the 120A ESC. Just to be a on the safe side.
Shawn
Shawn68z is offline   Reply With Quote
Old 03-03-2011, 05:37 PM   #3513
DRRS 9
Boost 36
Turbo slope 12
Turbo 24
Start RPM 3000
Delay 0.2
ACC 300
FDR 6.9
___________________________________
Elvis Hsiao
unionjkm@ms14.hinet.net
JoJiAuE is offline   Reply With Quote
Old 03-03-2011, 08:09 PM   #3514
fullout's Avatar
Send a message via MSN to fullout
Default cutting the red wire when using a 1s booster
I will be running my extreme stock in 1/12 on 1s and will be running a novak booster, do i cut the red wire from the speedo? And if i do does this affect the ability for it to be programmed via lcd programmer card?
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 03-03-2011, 10:12 PM   #3515
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
When the 508 (no timing) firmware is flashed to the esc, does the LED in the esc flash orange all the time to indicate its got the no timing firmware on the esc?
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 03-03-2011, 10:23 PM   #3516
Bishop's Avatar
Well actually it flashes red, though I supose it can look a little orange if you have the blue case?, and it will not flash red all the time, just at idle, it turns solid red under throttle and green at full throttle.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 03-03-2011, 10:32 PM   #3517
Johnny-RC's Avatar
Great I was hoping this was correct, and yes I do have the blue case Thanks for the confirmation.
Products I run
Old 03-04-2011, 03:41 AM   #3518
Originally Posted by JoJiAuE View Post
DRRS 9
Boost 36
Turbo slope 12
Turbo 24
Start RPM 3000
Delay 0.2
ACC 300
FDR 6.9
from rcfans -马达王 TITC 11.5组好盈电变设定
内齿比1.9 38-20 6.70齿轮比
0211 STOCK
启动模式 9,
进角 40
TURBO进角24
起始转速4000
换挡转速300
TURBO释放速度 18
延时0.2
任何设定都是需要符合当时的赛道和地面条件
这个设定可能对有些玩家来说是不够暴力的 但是对我来说是最舒服的 因为在15.9的最快单圈情况下最后几圈这个设定都可以做出16.1的单圈成绩
mos-leung is offline   Reply With Quote
Old 03-04-2011, 04:28 AM   #3519
cherry2blost's Avatar
0211 STOCK
启动模式 9,
进角 40
TURBO进角24
起始转速4000
换挡转速300
TURBO释放速度 18
延时0.2
from rcfans - Wang TITC 11.5 motor power variable group set a good profit
6.70 gear ratio within the gear ratio of 1.9 38-20
0211 STOCK
Start Mode 9
Timing 40
TURBO into the corner of 24
Start Speed 4000
Shift speed 300
Release rate of 18 TURBO
Delay 0.2
Any settings are required to meet at the track and ground conditions
This setting may not be enough for some players, but the violence is most comfortable for me because the fastest lap in the 15.9 case, the last few laps this setting can make 16.1 lap
Thought I would do this first
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-04-2011, 05:56 AM   #3520
defcone's Avatar
Trader Rating: 15 (100%+)
0211 STOCK
Start Mode 9
Timing 40
Start Speed 4000
Shift speed 300
Delay 0.2
Did he win the 11.5t titc class?
defcone is offline   Reply With Quote
Old 03-04-2011, 06:52 AM   #3521
Default Forms in Word.....
Can someone please help me out here, am trying to add editable fields into this form, have limited skills in Office so hope someone will be able to help me to add drop down boxes / click boxes to the empty fields in the Form.
Help !!!!!!!!
Cherry
Hope a genius can help out, i know what I am trying but it is beyond my capabilities I am afraid
Old 03-04-2011, 06:58 AM   #3522
Default 0119 DL Link for those that can't find it on HW Site
Just for those that have asked here is the link to my hosted version, hope it helps
Download Hobbywing_USB_Link_setup_V1.63_110119.rar from FileFactory.com
Cherry
Old 03-04-2011, 07:03 AM   #3523
Angelo can we get try the latest firmware ?
flashrevolution is offline   Reply With Quote
Old 03-04-2011, 07:05 AM   #3524
I wouldn't rush him as several people have complained about being used as 'Beta Testers' so let the Factory guys test it up to make sure it is perfect... Have patience Padwan
Old 03-04-2011, 07:46 AM   #3525
is there any difference between the 2.0 & 2.1 versions of the esc
or are they the same thing?
andy o is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Monsta
