Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 02-23-2011, 10:46 AM   #3316
JRXS_chris's Avatar
Try 0 mechanical timing?
JRXS_chris is offline   Reply With Quote
Old 02-23-2011, 10:59 AM   #3317
morgy's Avatar
tried both last nite and still had same problem !!!
morgy is offline   Reply With Quote
Old 02-23-2011, 11:56 AM   #3318
begrie's Avatar
Default xerun 120a 4s??
sorry for my stupid questions... can xerun 120a v2.1 handle 4s lipo for my 1:8 car? thank you.
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 02-23-2011, 01:55 PM   #3319
razzor's Avatar
no it can only go up to 3 cell.
The 80 amp or 150 amp Xerun or 150 amp Ezrun Pro runs 4 cell.
p/n 81020060 = Xerun 80amp
p/n 81020190 = Xerun 150 amp
p/n 81010210 = Ezrun Pro 150 amp
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-23-2011, 02:13 PM   #3320
drsmooth's Avatar
Trader Rating: 33 (100%+)
[QUOTE=cherry2blost;8697962]MY only issue, which may be down to a damaged ESC is with reverse, when I run in reverse, then go into forward the car will not move as if it is cogging then it leaps off as normal and is fine until I use reverse again.
Mine did that at the race Sunday. I lined up for a heat, and I backed into position. When the horn sounded, I pulled the trigger & it just sat there for a second, than took off. I had no other issues during that race.
The next heat I did the same thing. Backed the car into position. But this time I pulled a little forward & stopped. At the horn I pulled the trigger and this time it left the line perfectly.
I surely hope my 120 V2 esc is not damaged. It's never been hot. Take very good care of my stuff.
So if anyone else is seeing this in there esc, might try what I did.
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 02-23-2011, 03:47 PM   #3321
When the esc enters in reverse mode, changing to forward again takes a while. I'm pretty sure that you brake twice the first time and the ESC entered in reverse mode, so when full throttle it tooks some time to change again to forward. The second time it was not in reverse mode, so it accelerated properly.
This is why I asked Cobra to return the delay to enter accidentally in reverse mode. I hope it is back in the next firmware as he promised.
Gusi is offline   Reply With Quote
Old 02-23-2011, 06:26 PM   #3322
cliffhanger's Avatar
Hi does anyone know where to download v3.0_110119 528 mod software thanks
DESC210R ● DEX210 ● DEST210R
Team DE Racing
cliffhanger is offline   Reply With Quote
Old 02-23-2011, 07:14 PM   #3323
[QUOTE=drsmooth;8699261]
Do you really need reverse on a touring car anyway ? Most rules only allow for forward operation only and as such Forward/Brake mode is the only option available.
I shudder to think of the carnage that would follow when a driver selects reverse after they spin out on a track.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 02-23-2011, 07:29 PM   #3324
Bishop's Avatar
Yeah, I know some people use it, but it's not really allowed anywhere, having said that I know of the issue, because when testing my car at home around the deck I sometimes switch on reverse, saves me getting stuck in a corner.
It's a strange issue, kind of like the ESC has a moments brain fade when it's not sure you just hit the throttle, I was fooling with the 6-9-12% band and noticed it 'may' have gotten better, can't remember now.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 02-23-2011, 08:04 PM   #3325
venom54's Avatar
Default 119 528 SOFTWARE
From this link all new software in this down load.
http://www.hobbywing.com/english/Art...?ArticleID=463
The downloaded exe includes all new software versions.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 02-23-2011, 08:16 PM   #3326
Cheers
Ren
yes i got that installed that's' what is saying on the screen:
hardware version: HW 310 V1.0
Software version: V1.07_110119
Under choice version: V 1.07_110119
V 1.07_101224
V 1.06_100512
i don't see anywhere 528 version on there?
Team DE Racing
Old 02-23-2011, 08:35 PM   #3327
venom54's Avatar
Default 119 528 MOD
V 1.07_101224
V 1.06_100512
You must update LCD control box and then choose the version software you require.
As you can see the only choices you have either :
V3.0 119 MOD
or
V2.0 528 MOD
Cheers
Ren
Old 02-23-2011, 08:50 PM   #3328
here is mine
Team DE Racing
Old 02-23-2011, 09:01 PM   #3329
Click the device tab.
your looking at the 2 in 1 box tab.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-23-2011, 09:11 PM   #3330
venom54's Avatar
Default 119 528 MOD
here is mine
As Besercoe has noted you are only looking at the LCD box version software. Connect your ESC and from the menu "Device" option in the top tool bar choose ESC....
Cheers
Ren
