Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 02-13-2011, 02:14 PM   #3091
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by COBRARACING View Post
Maximum 8.5T and 2 cell if you want a 3 cell then 10.5T and above .anything below will kill the justock .
is that because of the amp draw or because of heat?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 02-13-2011, 03:17 PM   #3092
M7H
M7H's Avatar
Originally Posted by snabbgas View Post
Thanks M7H! Worked when doing like you suggested!
Glad I could help!
Serpent
M7H is offline   Reply With Quote
Old 02-13-2011, 03:34 PM   #3093
Hobbywing are 2011 EP Onroad New Zealand National Champs in Modified and Super-Stock (13.5).
Lycan is offline   Reply With Quote
Old 02-13-2011, 05:11 PM   #3094
SammyZ's Avatar
new zealand national champs? how many guys showed up, 6?
Hotbodies USA
SweepRacing USA
Old 02-13-2011, 05:25 PM   #3095
TryHard's Avatar
Originally Posted by syndr0me View Post
There's a ton of good info in this thread, but I haven't really seen much in the way of setups. I guess I'll just start where the manual suggests?
I'm looking for a good starting spot with 17.5 and 13.5 DUO3's, 2S touring car w/rubber tires on carpet. Tracks are in the 100x42 range, so a decent straight with a tight infield.
Also, has there been any trouble running this firmware on SP ESC's? I have a HW 2 in 1 and a SP 2.1 ESC and both took the new firmware without issue. The ESC seems to be running fine on the bench.
Setting's for 4.5t having been testing on saturday (at least, what I'll be starting out with at the TITC);
ESC: 120A Blue Spirit (obviously...)
Software: 110119MOD
Motor: MMH 4.5t (it's blue as well...)
FDR: 8.9
DRSS: 6
Endbell timing: Factory setting
Brakes: 75%
Drag brake: 0%
DDRS: 6
Boost Timing: 0 (so not using boost)
Turbo Timing: 20
Turbo Ramp: Fastest
Turbo Delay: 0.2s
Have to say, it was a rocket... Motor was getting a little on the warm side, and given the ambient in Thailand will be a lot hotter, I may have to tone it down a little (probably knock the timing down a little).
The track I was testing on has two significant straights. The big straight that you come onto from a fast left right, so on to full throttle pretty quick, and a shorter one that is just long enough to get the turbo in before hitting the brakes... hence the shorter delay.
Regards
Ed
Old 02-13-2011, 05:32 PM   #3096
RL.2002's Avatar
Software: 110119MOD
FDR: 8.9
DRSS: 6
Brakes: 75%
Drag brake: 0%
DDRS: 6
Turbo Timing: 20
Turbo Ramp: Fastest
Turbo Delay: 0.2s
Regards
Ed
What car you using??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 02-13-2011, 05:41 PM   #3097
cherry2blost's Avatar
Oh Dear............
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 02-13-2011, 05:42 PM   #3098
What an a-hole.
World revolves around you mate.
167 cars
Old 02-13-2011, 05:47 PM   #3099
Originally Posted by Lycan View Post
What an a-hole.
167 cars
Yeah it is kinda typical lol well done NZ guys keep up the good work.
Old 02-13-2011, 06:09 PM   #3100
venom54's Avatar
Default HOBBYWING 120 1S WITH 119 SOFTWARE
New software setup and tests on a XERUN-120A-1S ESC running the new 110119 stock software in 21.5 Touring car class.
Well the results are in. Run Sunday night 13/02/11 at a local track SERCCC (Melbourne Australia) on a flowing track setup. Three speed portions and four tight/hairpins sections. New set up on ESC only.
Michael Clarke (driver)
Car - XRAY T3 2011
FDR - 4.91
MOTOR - SP21.5 V3 SET TO ZERO DEGREE TIMING (Second motor used, first was fried due to incorrect settings)(blame the pit dude (me))
BATTERY USED - YUNTONG 5000 40C
TYRES - Muchmore 32 premounts
RADIO - Futaba 2PL
BODY - HPI MAZDA 6
CAR SETUP - Kit standard with a change to droop on rear
SETTINGS USED ARE LISTED BELOW ARE THE NEW SETTINGS FROM 13/02/11.
1 = 1
2 = 0%
3 = 3.4V
4 = 9
5 = 100%
6 = 25%
7 = 0%
8 = 6%
9 = 35
10 = 24
11 = ENABLED
12 = 24
13 = 3000
14 = 0.3SEC
15= 750
Results were again great acceleration and great top end culminating in a comfortable 3 out of 4 heat wins. Motor temps stayed around 55 degree.
Only the driver has to improve.
More setups to follow. Hope these setup options will be of help to all.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 02-13-2011, 07:11 PM   #3101
TryHard's Avatar
TRF416X, but will be a 417 at TITC (it's awaiting a new chassis plate!)
Ed
Old 02-13-2011, 07:34 PM   #3102
justock,60 amp xerun,xtreme stock and 120 amp 1s and standard all the have the sportsmans class zero timing 2 blinks per second when run with 508 software which all the above escs can run.
can you change from supercharged timing advanced software to zero timing class with out a computor, will the 2 in 1 proram box do it? would be nice to be able to switch back and forth with out a computor.
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 02-13-2011, 08:19 PM   #3103
SNIPR's Avatar
Where can you buy the Xerun 120A 1S in the USA? I have found it on ebay for $117 shipped but takes 2-4 weeks for delivery...
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 02-13-2011, 10:24 PM   #3104
Originally Posted by emerge View Post
This is my issue with that at the moment.
If I increase to 15 endbell which will be 45 motor timing plus 18 ramp esc timing plus 37 boost the heat will go up very quickly. We are in summer at the moment so heat is an issue. So yes I could either lower boost or fdr but I feel that the overall performance will be hampered. I compete on 2 tracks - 1 open and sweeping and other with a very technical infield.
These are my current settings - xtreme esc
FDR 4.5 - 21.5 ballistic
5+ motor endbell
Brakes 100%
Revers 100%
Drag brake - 0, then 10 then 40 (still no change in decelration)
Boost 37
Turbo 23
Ramp 18
Acc 150
DDRS max
I am not seeing anything unusual with any of that that would eliminate my brakes from working. What is interesting is that the brakes did work once but really frustrating the way they just didnt work all of a sudden. The only things that I have been playing with have been boost and acc so unless there is some malfuntion there I just dont know.
To add to this I also changed the trims (m11) to 160% brakes and exp to max - still nothing helped so I am at a loss
Just to clarify,when I say I am running 15 deg timing, that is 15 actual degrees. (so I am minus 15 from the N).
So with 1224 Fw I was running 15deg (End bell) 38 deg boost, and 8 deg Turbo. When I moved the timing (end bell) to 5 deg on the motor, it started to cog.
Shawn
Shawn68z is offline   Reply With Quote
Old 02-14-2011, 01:29 AM   #3105
Jack2's Avatar
people like you, is the reason the rest of the world hates america and its people. ever heard the expression "if you have nothing nice to say, say nothing at all? obviously not.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
