NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#3016
a fast question for all stock pro´s here.
I use Speedpassion 17,5T motor and HW Extreme stock ESC.
What firmware should i use for slow and technical tracks? And what difference do they have to eachother? what settings?
THANKS!
THANKS!
#3017
Start RPM 3000
Boost Full
Turbo Whatever you like
Supercharger Punch at setting 6
Always too quick for my mediocre driving
#3018
I am new to the XeRun system so I just thought I'd jot down some information about my very limited experiences.
Hopefully somone might find something uselful.
I am using the 110119_Stock firmware with a Xerun 17.5t /60a combo.
Vehicle - Tamiya TB-03R
FDR - 7.00:1
Boost Timing = 30degrees
Turbo Slope Rate = 18degrees/0.1s
Turbo Timing = 20 degrees
Boost Start RPM = 5000
Turbo Delay = 0.4s
Timing ACC = 500
Results.
I set the car up this way because I wanted to do a lot of laps at a moderate pace without stressing the ESC or over-heating the motor.
After 15 mins of laping my local track the motor was at 140 degrees (Ambient temp was 80 degrees).
The car was a little docile through the infield sections but had reasonable top end once the Turbo came on.
Conclusions:
These settings are great if you just want to do some laps at a resonable pace and learn about how your car handles and reacts to tire or suspension changes. - without having to worry too much about over-heating.
However, if you are racing, the car will be need to have the FDR increased to around the 6.00:1 mark ( Speed) or, you will need to lower the boost RPM to 3000 Rpm, and increase the ACC to around 200 (faster acceleration).
EDIT: I have found that increasing acceleration increases terminal speed.
Cheers.
FDR - 7.00:1
Turbo Delay = 0.4s
Timing ACC = 500
Results.
Conclusions:
Cheers.
#3019
To do this:
1. Right-click on the file name
2. Select "Run as Administrator"
The program will install fine on Windows 7, that's what I have.
Tony
#3020
RC political statements aside, none of it helps me does it, in fact even the AARCMCC lists do not help me, aside from being offroad anyway, and I'm onroad, my model is not even covered.
Yep, AARCMCC list seems to only list 'current' models stocked by AU sellers, so whoopee, unless you have a blue 2.1 it 'looks' like it's not approved, which is funny with all running the same firmware etc.
I won't go into the politics much, and really choices made by states are just something you wear, you can not fully agree but still accept it, 'but' I am still feeling screwed over my choice of esc, bought hoping and half knowing in theory it should run in what I want it to run, but then seeing that still not play out this year.
Tony
#3021
I have a 12 month plan which started 1 month ago for hobbywing and that is to ....
1.Have all motors approved on a world scale
2.stock racing esc's approved
3.Better easier to understand software with more performance
4.A new esc for pro racing (cant say which one though sorry)will have a new way to program not used by anyone else
5.A modern look for hobbywing (including logo)
6.Better after sales service and customer support .
7.Easier to navigate website with more info .
8.Distributor list and dealer list
9.Racing results posted on website and websites around the world.
10.Loyal customer rewards program
11.A new warranty policy with exchange programs for a fee .
12.exteneded warranty program which will have a small fee implemented .
and thats only the tip of the iceberg .
regards Angelo
regards Angelo
while my suggestion remain the same related to number 3.
#3022
regards Angelo
regards Angelo
I'ld say, scratch #6 of the list. Job done.
rest sounds awesome.
#3023
Sunny weather this morning, 19C temp, work starts at 14.30, so why not take a couple of bikes out to run!
First off my new Thunder Tiger SB-5, in Superbike form, complete with Trinity Duo 6.5T, HW 120A v2.0 with 119mod s/w, no fan, geared at 10.4:1 (usually we gear the 1/5 on road bikes approximately like 2WD buggies...), Turnigy 2S/4000/30C batteries.
I had this setup quite mild, and the punch at 4, so it was manageable, very quick, not punchy, great acceleration but not wheelie-inducing (it also has a slipper!) and great top speed, not really measured... After 12-13 minutes of continuous run, the ESC was nice to touch for a long time, and the motor was at 55C without any cooling aids on it.
Next up, was my 2010 Worlds bike, the KP09e, with another Trinity Duo motor, 17.5T, this time, HW 60A v2.0, 119stock s/w, 6.36:1 FDR, Turnigy 2S/3000/40C batteries, 1895gr weight, as per 2011 Worlds rules).
(Previous setup was LRP X12 13.5T, 6.64:1 FDR, 1805 gr. weight)
This one I had setup as follows:
Punch (4): at first 5, then 9 (full)
Boost timing: 40
Turbo slope 18
Turbo timing 30
Boost start 3000
Turbo delay 0.2
Timing ACC 300
The bike felt very quick to accelerate, and, considering I was alone with two bikes, I could not run them side by side to compare, it was also very fast. The program provides a very linear increase of revs, it will not wheelie at any chance (that's a good thing, actually!), and it can take clumsy use of throttle very nicely, without any unwanted side-effects like stepping sideways... I set the brake and rev on the ESC at 100% and then lowered the brakes on the transmitter at 55%, to provide good consistent braking action, but no rear wheel locking. (I'm not using a front brake on this one).
I also tried the suggested settings for a 2WD buggy with 17.5T at the bottom of the pdf (dated 25.01.2011), but it felt very soft, even slow, like it should be on a 2WD buggy on loose surface. It could be nice, I guess in slippery/rainy conditions, for a bike...
These settings would be:
Punch 4
Boost Timing 20
Slope 6
Turbo timing 12
Boost start 3000
timing acc 250
Since I had my 2-1 box, I realized I could change parameters in both ESC's, despite one being loaded with mod program and the other with stock. This one to partly answer a question about using one program box for two ESC's, though, as i said, I have 119 s/w in both...
Boost timing: 40
Turbo slope 18
Turbo timing 30
Boost start 3000
Turbo delay 0.2
Timing ACC 300
Punch 4
Boost Timing 20
Slope 6
Turbo timing 12
Boost start 3000
timing acc 250
#3024
if you have a 1s speed control and it is prorammed with boost and turbo and then want to race in what is called stok blinky mode, can you just switch by pushing buttons on esc or program box or do you need a differt download with computor? Thanks
#3025
Sorry to ask again, but is possible to downgrade from 119MOD to 528MOD? I've tried it but some options are now not available in 528 from software nor the program card. Anyone have tried this?
#3026
and then reflash to V2.0_100528.
#3027
Hobbywing extreme stock esc problem
Hi everyone,
I need some help fast i got myself a hobbywing extreme stock speedo, came this morning installed it about 5 hours ago, and having touble with the setup,
When i set it up there are no beeping sounds and when i finish the setup ( it does let me ) i but on half throttle ish a red LED shows when i go to max Throttle its still red and the motor does not move, i have tryed this with 2 motors.
I have gone over the setup book troubleshoot nother there to help, i have also email the tech side of giantcod about 14:30 ish and no reply so iam open to any ideas to what my be causing this problem.
Thanks to everyone that might be able to help.
Will look at the other pages to see if i can find anything bu its 200 odd to look at
#3029
just make sure you uninstalled the old hw pc interface and re installing the
latest hw pc interface.
then you will be able to revert back.
#3030
