Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 02-02-2011, 07:34 PM   #2881
Thank you for the apology Angelo.
You have restored my faith in HW once again. I am looking forward to future HW products, and especially cant wait for you to establish a North American dealer.
Shawn.
Shawn68z is offline   Reply With Quote
Old 02-02-2011, 07:38 PM   #2882
Originally Posted by Rocking Donkey View Post
Before I buy myself an Xtreme Stock, is there any advantage to buying the 60A V2.1 instead? Do they both have the same FETs etc inside, or is the cooling better on the V2.1 because of its larger size?
Cheers
Ben
XtremeStock has a 6V BEC, where the 60A has a 5.75V
I dont see a reason to go with the 60A.
Anyone else have a comparison?
Old 02-02-2011, 11:58 PM   #2883
TryHard's Avatar
Originally Posted by Lycan View Post
Are the Punch Level settings for 110119MOD the same for 110119STOCK?
e.g. if I wanted to run MOD profile with my 8.5, the same setting can be carried across?
I believe this is the case, as I ran a 5.5t with the STOCK version for a bit (couldn't upgrade the software due to no net connection), so just turned the boost settings off and worked from there.
And agreed and thanks for the explanation Angelo.
HiH
Ed
Old 02-03-2011, 01:53 AM   #2884
daleburr's Avatar
Setup for 10.5 in TC.
Track - 50m straight with mixed infield
Motor - SP v3 10.5, motor timing on max
FDR - 6.5
Firmware - 0119
9 - 40
10 - 3
12 - 20
13 - 3000
14 - 3
15 - 200
The car was superb on the straight, with very good mid-range and top end. A little faster than with the 518 firmware I think, which used to lack mid-range.
Initial acceleration out of low-speed corners was okay, but could be better. This feels worse than the 518 which was very good out of the corner. Possibly a higher FDR will help here as long as it doesn't imact the straight speed too much.
Motor temp was only 45deg, compared to 70deg with the 518 firmware, so this is a huge improvement. Should make for more consistency throughout the run, especially on hot days (its 0deg outside at the moment).
I'm going to be installing a Novak Sentry data logger so I can analyse the performance in a bit more detail, and I'll also test the 1224 firmware to see if this offers any advantage. With the motor only at 45deg there seems to be room to improve the performance even more, but I'm already at the 60 "degree" maximum timing on the 0119, so the 1224 is worth a go.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 02-03-2011, 03:47 AM   #2885
M7H
M7H's Avatar
Originally Posted by irgo View Post
Guys Let's get back on track,
i see many asked and talked about software and typed 1224
Please correcting that the right version is V3.0_101224STOCK
V3.0 = is a Third Generation Software
Do not Compared it with
V2.0_101224STOCK
V2.0 = is a Previously Second Generation Software
That's all may come new updates but different Version Generation,
So please don't just type 4 digits "1224"
typed it completely ex : V3.0_101224STOCK or V3.0_110119STOCK or V2.0_101224STOCK
date version is (version Generation + 6 digit)
So we all know which version is to be discussed.
Thank's For attention.
If you are complaining about this, then please be accurate.
As far as I know, V2.0_101224STOCK never existed....
V2.0_100518STOCK did...
Serpent
M7H is offline   Reply With Quote
Old 02-03-2011, 09:29 AM   #2886
cuttingedge's Avatar
Does anyone run there HW Extream stock like the Black Diamond works ??????
RE No Turbo Just a steady timing advance over the whole trottle range ??
Is this possable ?
If it is which i am sure it is can somebody suggest some settings to try please
Running the latest 119 software and a HW 21.5 motor
Thanks in advance
Schumacher uk - Litemodz - Potters Electrical Supplys - The Sign Shack - www.car69.me.uk - Akula Racing
cuttingedge is offline   Reply With Quote
Old 02-03-2011, 10:07 AM   #2887
FDR - 6.5
Firmware - 0119
9 - 40
10 - 3
12 - 20
13 - 3000
14 - 3
15 - 200
I would say that no.13 and no.15 are too low. Basically you are trying to throw too much timing at the motor too soon. I would try no.13 at 6000-8000 and no.15 at 600
Mike
ixlr8nz is offline   Reply With Quote
Old 02-03-2011, 11:19 AM   #2888
irgo's Avatar
Thank's for attention, that been corrected.
Quark Force
irgo is offline   Reply With Quote
Old 02-03-2011, 12:42 PM   #2889
Trader Rating: 20 (100%+)
Default Trying to back grade my soft
I current have SP v1.06_100617 on my HW 2in1 box. I am trying to install the latest HW soft. I have been told to install the old version of the SP then the old HW finaly to the new HW soft. I have been running the update application in admin mode.
I am tryin to back grade to the SP v1.32
This is the error I keep getting
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 02-03-2011, 02:28 PM   #2890
getting ready to test my 1 12!
running 1s lipo, should i choose "Custom" at voltage and select 3.5v at cutoff?
also what settings is recommended to start with running 13.5t, 1s lipo on a medium-large size track? (110119stock software)
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 02-03-2011, 03:18 PM   #2891
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
turn cutoff off.
Tire Chunker is offline   Reply With Quote
Old 02-03-2011, 03:53 PM   #2892
venom54's Avatar
Default SOFTWARE V1.07-110119
Is this possable ?
Thanks in advance
New software setup and tests on a XERUN-120A-1S ESC running the new 110119 stock software in 21.5 Touring car class.
Well the results are in. Run tonight at a local track SERCCC (Melbourne Australia) on a flowing track setup. Three speed portions and four tight/hairpins sections.
Michael Clarke (driver)
Car - XRAY T3 2011
FDR - 4.91
MOTOR - SP21.5 V3 SET TO ZERO DEGREE TIMING (Second motor used, first was fried due to incorrect settings)(blame the pit dude (me))
BATTERY USED - YUNTONG 5000 40C
TYRES - Muchmore 32 premounts
RADIO - Futaba 2PL
BODY - HPI MAZDA 6
CAR SETUP - Kit standard with a change to droop on rear
SETTINGS USED ARE LISTED BELOW.
1 = 1
2 = 0%
3 = 3.4V
4 = 9
5 = 100%
6 = 25%
7 = 0%
8 = 6%
9 = 35
10 = 18
11 = ENABLED
12 = 24
13 = 4000
14 = 0.3SEC
15= 500
Results were explosive acceleration and great top end culminating in a comfortable heat win. Motor temps stayed around 55 degree and all but driving incidents did not add more wins to the tally.
I'm very impressed with the new software and with a little more track time i'd say a few more tweaks on setup will produce more impressive results. Only the driver has to now improve.
Hope these setup options will be of help to all.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 02-03-2011, 04:18 PM   #2893
Could you tell us what setings you were using when you blow the previous motor? So that we don't do the same mistake.
thanks.
Jeppi is offline   Reply With Quote
Old 02-03-2011, 04:21 PM   #2894
pettyeagles's Avatar
Trader Rating: 79 (99%+)
Default 25A 1/18 ESC
I have a Hobbywing 25A esc in my SC18. I recently picked up the 2 in 1 programming box. When I hook it up to esc all it displaysis "connecting to esc". I assume this mean I have the version 1 esc. Does anyone know if I can upgrade the software in the esc to the version 2?
A bad day racing beats a good day at work. My RC fleet:
SC5M, B5M, FT B4.2, SC10.2, FT SC10(x2), FT TC5, FT TC4, 12R5,
AE Rival MT, RC10 Classic, CW Pro Comp Outlaw, F104, F104 pro v2, RJ Speed Legend
Traxxas Slash(x2), 4x4 Slash VXL, Vendetta SC/ST
Axial SCX10, Axial Yeti, G-Made/AX10, Losi Micro Crawler, Sakura D3 CS(x2)
pettyeagles is offline   Reply With Quote
Old 02-03-2011, 05:12 PM   #2895
venom54's Avatar
thanks.
Motor had 10 degree timing origionally and values 13 was set at 2000 and 15 was set at 750.
FDR on our track was changed from 4.4 to 4.91.
Taming the settings down gave the car better top end speed but improved the acceleration by at least 50%.
Cheers
Ren
