Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-31-2011, 03:45 PM   #2836
Default Little setup help
Guys wondering if someone can help with some aceleration advise. I had a test day yesterday. The track slightly open, infield slightly technical because you really need to hit the right line to carry the speed over from one corner to another, but with very low grip.
The settings I orginally ran with were - P.S. Motor is Nocak Ballsitic with 0 added motor timing. (Ballistics come with +30 added timing from factory)
fdr 4.5
#9 40
#10 18
#12 20
#13 3000
#14 0.2
#15 200
Motor Temps after 10mins 74C
Eval'
Although I was running on 36 and should have been 32 and the track was dirty I was running about 0.5secs per lap off what is good pace for the track. Keeping in mind that the track was filthy and my setup was giving me a bit of an oversteer I wasn't too displeased with that.
I then changed the setup to this - same tires and car setup but starting to allow for the oversteer
fdr 4.5
#9 35
#10 24
#12 25
#13 2000
#14 0.2
#15 150
Motor Temps after 10mins 65C
Eval'
Laptimes were about 0.2 per second better and I could see the turbo kick in a bit more. My only complaint is the acceleration still wasn't there.
Any ideas for room to improve? Apart from the esc I can add more timing to motor (worried that the heat will be back up to 70+) or lower FDR (which will give me more speed overall but not sure how that will improe the acceleration issue)
emerge is offline   Reply With Quote
Old 01-31-2011, 03:49 PM   #2837
Default Setup Help
OH and the motor is 21.5 and the FW is 119
Old 01-31-2011, 05:18 PM   #2838
TryHard's Avatar
Originally Posted by Shawn68z View Post
I understand what you are saying but, if the steps have been broken up for more accuracy, then the documentation on the HW site is wronge. In the PDF file that you left a link to on the HW, states Boost can go upto 60deg in 1 deg steps, and turbo can goto 40 deg in 1 deg steps, for a total of 60deg total timing.
Your post contradictes this, can we get some clarification on the total timing available, and the steps.
Shawn.
Thi isn't ment to be a bag on HW (and as far as I'm aware, they weren't the first in this.. T...n) but I figure it's a little bit of marketing
Put it this way, if all the speedos on the market can only put in a similar useful amount of actual extra timing, then whats gonna sound more impressive?
30 in 0.5 steps, or 60 in 1 steps? Only have to look back through the pages to note that everyone raved about having 60... hey, it's more than 46, so it's got to be better right?
Anyway, I guess as a few have realised, I'm now running a HW 120A in my car... got to say with the 5.5t motor I was using last week, felt very good and smooth, and nice brakes. Thankfully Sizheng was at the track to help get me set-up, and give advice on what to run. Not much to it really though, zero boost, 14 (or should that be steps?) of Turbo, and geared about 7.6FDR... can you say missle?
Hopefully will be able to get some more testing done before the TITC, although I've been told that HW will be there from the 14th for testing, so who know's whats in the pipeline
Regards
Ed
Old 01-31-2011, 09:51 PM   #2839
Regards
Ed
Ill take the 60 deg with 1 deg steps as per the manual. Timing may not be everything but when I am getting run down on straight by lesser drivers, it is a power thing. And proper application of gearing and timing makes power. 1/12 1S 17.5 REQUIRES 60 deg total timing. If the 119 software cant do that, then come clean and say it cant do it. I would have stayed with the 1224, with 46 deg ( if thats correct), and the 15 deg end bell. Its real close to the tekins, but not quite...
1S racing is very different then 2S. On 1S it takes alot to fry a motor, since you dont have the raw power available from the battery. I would never dream of running 60 deg timing in my TC!
The extra timing allows more boost (I would like to run 45-50 deg boost), allowing my car to have a higher RO. This will provide the needed rip out of the corner, while still having the high speed for the straight.
Shawn
Shawn68z is offline   Reply With Quote
Old 01-31-2011, 09:52 PM   #2840
Jack2's Avatar
Regards
Ed
Hi Ed, I'm running the HW 120A speedy, with a 5.5 V.3 speed passion motor. I needed to run max punch and Timing to get the thing to get up out of the grave and getup to the speed of others, geared at 8.3-8.65.
May I ask what software are you running? I also tried 8.0 gearing, with punch on 1 and timing on 8 or so, and it was less that impressive I thought.
Cheers
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-31-2011, 09:58 PM   #2841
COBRARACING's Avatar
Regards
Ed
Im sure michael does have a suprise for the HW guys just before the TITC .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-31-2011, 10:48 PM   #2842
RevMaxx's Avatar
Send a message via MSN to RevMaxx
i tried to run all HW, using HW120A ESC (119FW) and the new version HW Xerun 10.5T on my touring car and i must say i'm impressed with the combo.
geared it at slightly higher FDR (8.8) and really runs well and cool (65C) after 8 minute run. top speed was just fine though i know it can still improve.. initial grunt may not be as aggressive but i can surely feel good boost afterwards
settings below:
#9 35
#10 24
#12 18
#13 3000
#14 0.3
#15 250
question from HW gurus... what can still be improved on my settings? we don't have laptime yet on the track (low to mid grip - concrete)
RevMaxx is offline   Reply With Quote
Old 01-31-2011, 11:48 PM   #2843
sizheng's Avatar
settings below:
#9 35
#10 24
#12 18
#13 3000
#14 0.3
#15 250
Hi, I think if you use HW 10.5T motor, you can lower your FDR to 7.0-7.5, depends on your track layout and straight length. try the following settings if you have time and measure your motor temp. on the first pack to confirm if it is safe(<85c)
#9 36
#10 24
#12 16
#13 4000
#14 0.5
#15 350
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 02-01-2011, 12:00 AM   #2844
MOmo's Avatar
I already emailed my question to hobbywing and awaiting a reply, but i wanted to know does anyone do anything with the 1/8th scale BL setups?
Also, are any of you running the HW in off road? I started here and started working my way backwards.
I'm still new to all this stuff, but I hope to help out as I am a dealer and seller of hobbywing here in the US.
MOmo
Xtreme Toys
Amax
RACE CARS: B44.1, RC8.2E FT, SC10.2 4X4, B5M, YZ-2
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 02-01-2011, 12:56 AM   #2845
Hi people.
I'm running a hobbywing xerun 60amp 2.0 with the new software has anyone got any advice for running with an x12 13.5?
Any help greatly received
James
jameslucas is offline   Reply With Quote
Old 02-01-2011, 12:57 AM   #2846
M7H
M7H's Avatar
Although I had my motor at 90 Celcius.... and could really feel all performance went down the drain....
I went back from 0119 to the 1224, because the set-up I have with that FW is really fast, if not the fastest there is on our track, at this moment, yes even faster then the tekins!
Equal in the first 4 minutes, but then I start having the advantage, because I'm running cooler and more efficient with the power in my lipo's!....
It's not at all fully opened, but that's the secret, you have to run for 8 minutes, and not for only 1 lap!
Serpent
M7H is offline   Reply With Quote
Old 02-01-2011, 02:41 AM   #2847
mc4798's Avatar
MOmo
Xtreme Toys
Amax
Im use Hobbywing stuff in all my offroad cars.
120a xerun /6.5t motor in a 4x4 buggy
60a xerun 13.5t 2wd buggy
Ezrun SC system Slash 4x4
Sorry but dont have a 8th scale though.
mc4798 is offline   Reply With Quote
Old 02-01-2011, 06:22 AM   #2848
OscarF1's Avatar
We will soon buy a programmable controller.
The most powerful engine we use is the Speed Passion 13.3 V3
Is the Xerun 60A suitable for that?
Or is it better to buy the 120A version?
(1:10 4WD TC on 2S lipo on carpet and tarmac)
OscarF1 is offline   Reply With Quote
Old 02-01-2011, 07:58 AM   #2849
daleburr's Avatar
60A is fine; I use one with 2S 10.5.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 02-01-2011, 08:16 AM   #2850
Just upgraded my firmware to 0119stock. I was using these setting on 224
4 = 7
9 = 30degs
10 = turbo ramp 9deg/0.1secs
12 = 20deg
13 = 2000rpm
14 = 0.2secs
15 = timing acc 750rpm/deg
I run a nosram x11 Storm Evolution 10.5 motor in a schumacher mi4 with a FDR of 7.6 on a medium sized carpet track with a 50ish meter straight and normally a tight infield. Ive put theses setting in for 0119 as a start point. Anyone have any suggestions of anything i should change before my first run. Thanks
scytherat is offline   Reply With Quote
