Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-30-2011, 03:35 AM   #2791
steliosh's Avatar
Originally Posted by clittle View Post
First run with a new ESC.
I'm using the XERUN 120A with a Yokomo Zero 13.5 Motor. I'm using the LCD connection through to my computer and I believe I'm running the latest firmware and software (0119 on the ESC). I have a couple of items in the Advanced tab greyed out and I can't set them. Turbo RPM is one and I can't remember the other right now.
Is there any particular reason why I can't modify those elements?
Cheers
Make sure you install the STOCK119, and NOT the MOD119... The mod has some areas greyed...
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 01-30-2011, 03:41 AM   #2792
Originally Posted by COBRARACING View Post
A cheap battery is a cheap battery in power,quality and performance and as technology gets better and more performance is on demand those sort of cheap cells cannot do the job that is needed.
Absolutely.
I'll choose a quality 20c Lipo over a cheap and nasty 50c Lipo every time.
Because in an electric powered vehicle the quality of the battery is paramount.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 01-30-2011, 03:48 AM   #2793
clittle's Avatar
One thing alot of you guys can't seem to understand is that to run efficiently with no power issues you need quality battery's.Turbo settings require loads of current and if your battery is one of those make believe c ratings as we see on 90% of the batterys on todays market then you will have problems .
I get alot of emails about issues of esc stopping then going then slowing down after a few minutes etc .When batterys have a none linear voltage drop per time cycle they are crap Rubbish in other words.
Appreciate the comment, however these weren't exactly cheap batteries. They hadn't been used in a while (does Lipo have that problem?) and the brand is quite reputable. hmmmmm
I spent big on batteries for exactly the reasons you mentioned. Any recommendations then?
Anyhow, will see next time with a FDR somewhere within the correct range.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 01-30-2011, 03:51 AM   #2794
clittle's Avatar
And there is my answer. Thank you very much
Pity it's night time, I want to go back and try this out now.
Aussie in Japan!
Old 01-30-2011, 04:15 AM   #2795
zipp's Avatar
To share my personal experience,
for those of you experiencing sudden drops in speed, it is due to the low voltage cutoff.
When i first installed my HW, I set the cutoff to 3.4V/cell, which works out to be 6.8V cutoff. What happened was, when the turbo kicked in, the amp draw was too large, causing a voltage drop that dipped below the cutoff threshold. That's when you experience the sudden drop in speed. As Cobra mentioned this also happens if you have weak batteries.
I have since stuck to 3V/cell and no longer have any issues
zipp is offline   Reply With Quote
Old 01-30-2011, 04:21 AM   #2796
irgo's Avatar
we got, one victim the 3RD Generation
1 Motor OverHeat,
bad!! it's adjusted to 60 Degree!
no wonder SP Stayed on 2nd Generation.
Quark Force
irgo is offline   Reply With Quote
Old 01-30-2011, 05:33 AM   #2797
AGNO's Avatar
1 Motor OverHeat,
My Novak and GM 17.5 work very well at 60 , and with version 3 are much cooler of version 2.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-30-2011, 06:13 AM   #2798
irgo's Avatar
sure, the one that too hot was doing the hard Load,
bad settings. ..
The Generation 3 (V3) Firmware, must be provided with
different manual than the (V2)Firmware,
for safety reason.
Quark Force
Old 01-30-2011, 06:23 AM   #2799
chinaman's Avatar
... My Novak and GM 17.5 work very well at 60 ...
Ballistics are good to 70C and GM should be ok to 100C max ... as per manual ... but would stay not more than 90C myself ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-30-2011, 06:28 AM   #2800
AGNO's Avatar
I meant 60 degree of dinamic timing.
GM recommended max 100 c, but not trust, the magnets lose efficiency already at 80 c.
Old 01-30-2011, 07:41 AM   #2801
irgo's Avatar
Default 110119 Ver: HW-09-V2-110119Stock-20110123
The table below is a recommended setting list. (2 cells Lipo, Motor endbell physical timing is 0 to 5
11.5 | 6.0-7.0 | 30-38 | 9/0.1s | 16-26 | 4000 | 0.4s | 300-450
13.5T | 5.0-7.0 | 30-50 | 9/0.1 s | 20-30 | 3000 | 0.4s | 200-300
17.5T | 5.0-7.0 | 30-55 | 9/0.1 s | 20-30 | 3000 | 0.2s | 150-300
This is from the latest manual,
tell me,..
gone 60 with RPM Too low
this may have been asked by someone before,
but true, There is no DMTS2.0 where previously
before the Supercharge start RPM.
Example for 11.5T previously start at 8000RPM
this time is 4000RPM.
tell me....
Quark Force
Old 01-30-2011, 09:25 AM   #2802
steliosh's Avatar
I am setting up two 1/5 bikes with Xerun ESC's: the stock 17.5T with an 60A and the 5.5T mod with 120A, so I accidentally installed the mod S/W to the stock bike... and was wondering... Then I rechecked...
Glad I could help!
Old 01-30-2011, 09:26 AM   #2803
tell me,..
tell me....
What about adding 10.5 to this list, as its probably the most popular after 13.5 in UK. Thx
bozboy is offline   Reply With Quote
Old 01-30-2011, 09:29 AM   #2804
getpip's Avatar
Originally Posted by Shawn68z View Post
I have noticed the 0119 software does like more gear then the 1224 software for some reason.
Shawn ..
What were your findings on this.. Did you notice better speed or better temps?
What sort of fdr did you end up with?
I found 6.6-6.7 worked well with 518/1224. (Tekin redline)
Used the same today but spent my time playing with settings rather than gearing.
Thought 119 was smooth and deceptively quick. (0.2 quicker than 1224)
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 01-30-2011, 09:59 AM   #2805
1 Motor OverHeat,
Wait a sec... You are one of the guys that is always asking for new firmware, with a logger, and a more settings.. And now you are coming across as blaming HW for those settings?
Always start at a conservative setting, and make small adjustments for more power. Any other way, and you taking a risk with your equipement.
Shawn
Shawn68z is offline   Reply With Quote
