Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-26-2011, 09:46 AM   #2716
jonest's Avatar
Originally Posted by TryHard View Post
Hi Salton, thought it was you, I've been keeping an eye on this thread recently. Can't make it to Hangzhou this weekend. Saturday I'm off to test motors at TRS, and Sunday need to go to work And I'm also having to spend the new year in Japan on work too...
Regarding this, I've attached an excel spreadsheet to help figure this out (albeit in mph). Just need to put in the internal ratio of your car, the gear ratio, tyre diameter and the speedo settings, and it calculates the speed for the start and end of the boost phase. I made it up originally to get a better understanding of the mamba cheat timing, and I've made some alterations to suit the HW software (as the end rpm is set differently on the mamba).
What about a brit based in china?
Ed,
China then Japan.... envious.... See ya at BKK next mth!!
btw, anyway can churn out the excel calculation for the modified f/w?
jonest is offline   Reply With Quote
Old 01-26-2011, 09:51 AM   #2717
TryHard, your zip file does not appear to open with any particular file association, am I doing something wrong here?
Regards
Phil
xraydad is offline   Reply With Quote
Old 01-26-2011, 09:59 AM   #2718
jonest's Avatar
Went out to a wet track tonite to test the esc.... though traction is almost undrivable, finds the esc is quite smooth.... hope to test more tomorrow....
Old 01-26-2011, 10:28 AM   #2719
Hi need some help I have downloaded the newest firmware from the Hobbywing site v1.63 019 but I can see a 019 option in the drop down menu to update it?
008-Racer is offline   Reply With Quote
Old 01-26-2011, 10:31 AM   #2720
chinaman's Avatar
... What about a brit based in china?
have you got any fish n chips withdrawal symptoms???
i presume you meant 'you can't see the 019 option'. are you an SP user? if yes, i believe you need to select the 'adminstrator' mode.
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-26-2011, 11:15 AM   #2721
steliosh's Avatar
Regards
Phil
Well... it unzips with winzip, but... the file inside has no extension. I renamed it as speed chart.xls, but its contents are unreadable...
Can you tell the version of Excel it was made, maybe?! (Using Win XP, Office 2003, here, sorrry!)
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 01-26-2011, 11:47 AM   #2722
i presume you meant 'you can't see the 019 option'. are you an SP user? if yes, i believe you need to select the 'adminstrator' mode.[/QUOTE]
What administrator mode? Sorry confused? This is for a Fleta 3 (SP GT2 Pro)
Old 01-26-2011, 11:49 AM   #2723
steveonamission's Avatar
Run the program as administrator, right clickity click
steveonamission is offline   Reply With Quote
Old 01-26-2011, 11:50 AM   #2724
What administrator mode? Sorry confused? This is for a Fleta 3 (SP GT2 Pro)[/QUOTE]
Ah OK found it you mean right click on the Hobbywing program icon and run program as admin!
Thanks for your help
Old 01-26-2011, 12:08 PM   #2725
Trader Rating: 20 (100%+)
Default Thanks
Originally Posted by cherry2blost View Post
Thank you
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 01-26-2011, 05:41 PM   #2726
TryHard's Avatar
Regards
Phil
you right, something wrong there... I'll make up a new file tonight, guess the zip became corrupted, because it's deffiently an excel file at home!
Old 01-26-2011, 05:57 PM   #2727
jekyll08's Avatar
does anyone know where i can get a capacitor for the extreme stock?
jekyll08 is offline   Reply With Quote
Old 01-26-2011, 06:27 PM   #2728
If you want HW, try rc-fans88.com (he is also on ebay).
If you dont care who makes it, then goto an electronic shop and buy some capacitors. 16V or better (25V if you are running 3S), 470uF or should do the trick.
Shawn
Shawn68z is offline   Reply With Quote
Old 01-26-2011, 06:48 PM   #2729
jekyll08's Avatar
thanks for the info
Old 01-26-2011, 06:58 PM   #2730
cherry2blost's Avatar
we have the 2 part and the upgraded 4 part in stock if it helps at all
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
