Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-25-2011, 12:36 PM   #2686
njt
njt's Avatar
Hi Sizheng can you walk us through how you got to the 20kph speed for guinnes.s touring car please, could be useful info . Thanks
njt is offline   Reply With Quote
Old 01-25-2011, 12:53 PM   #2687
guinnes.s's Avatar
Originally Posted by sizheng View Post
You almost used up timing in boost, 2000+200*55=13000 , and with 7.4 FDR, the speed of your car is only 20km/h at this RPM.
What setting u would suggest then?
Can u explain the calculation that u making?
Thanx
guinnes.s is offline   Reply With Quote
Old 01-25-2011, 01:22 PM   #2688
chinaman's Avatar
Originally Posted by Andy63 View Post
... i have a massive delay when braking with the HW Extreme stock ESC. When braking it has some delay, i have adjusted the transmitter EPA to 135% brake and didnt really feel any difference ...
Have you tried to re-calibrate your transmitter end-points.
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-25-2011, 01:44 PM   #2689
Originally Posted by daleburr View Post
You're reading the wrong instructions; download the latest ones from the Hobbywing website and these explain all of the settings, with their new limits.
For 21.5 you can start with the 17.5 settings in the instructions and maybe add a bit more boost timing and/or drop the FDR.
Thanks mate, you wouldn't have the direct link to this? I just want to make sure I'm looking at the right ones
emerge is offline   Reply With Quote
Old 01-25-2011, 02:14 PM   #2690
chinaman's Avatar
cobraracing has downloaded a copy.
pls see post #2662 on page 178 ...
Old 01-25-2011, 02:19 PM   #2691
Default Esc
Thanks mate appreciate the help
Old 01-25-2011, 02:30 PM   #2692
M7H
M7H's Avatar
Originally Posted by guinnes.s View Post
this are the setting that i used for first time at my racing club.
110119 with sp13.5 v3 at 7.4 fdr ,max temp 72c
4 DRRS 8
9 boost timing 55
10 turbo slope 24
12 turbo timing 30
13 start rpm 2000
14 turbo delay 0.4
timing acc 200
the car felt really quick in the infield and at beginning of the 30 metre straight,but the turbo did not felt to have any punch.what setting could help?
thanx
As you can read in the manual, total timing can be 60 degrees, not more.
If you have already 55 boost, only 5 will be additional available for turbo, even if you set it on 40!....
So this 5 turbo, doesn't really give a lot of punch offcourse....
It's nice that these options are there, but users should try to understand them, and not just do something......
Serpent
M7H is offline   Reply With Quote
Old 01-25-2011, 02:51 PM   #2693
COBRARACING's Avatar
Have you installed the new 119 software it fixes the bugs .please send me an email at [email protected]
To everyone please send me email at either [email protected] .com or [email protected]
I dont like using the pm feature
thanks guys
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-25-2011, 04:00 PM   #2694
terryh's Avatar
Can anyone tell me the size (diameter) and gauss of the the Hobbywing 13.5t rotor? I want to try one and this will help me with a starting point for gearing and settings. I know they have overheat protection and shouldn't cook the motor, but I would rather get an idea before running one.
terryh is offline   Reply With Quote
Old 01-25-2011, 04:53 PM   #2695
cherry2blost's Avatar
hey all!
I need some help here.
i have a massive delay when braking with the HW Extreme stock ESC. When braking it has some delay, i have adjusted the transmitter EPA to 135% brake and didnt really feel any difference. So what can i do to make it better?
When setting up your radio please make sure that the ABS function is TURNED OFF as with Futaba and Flysky TX's I had a crap time with the brakes, with the ABS turned on. Also set reverse to 100% and fit the 4 part Capacitor gives much more braking.
Hope it helps you.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 01-25-2011, 05:22 PM   #2696
Trader Rating: 20 (100%+)
Default Install new software
If I have the SP v1.06_100617 soft on my 2in1 box, how do I put the new HW release on it? Everytime I try it says it can not be upgraded.
I tried using the disc that came with my esc the first version to back grade but same issue. I also ran it in admin mode(i think).
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 01-25-2011, 05:47 PM   #2697
TryHard's Avatar
I have a chart somewhere to calculate this... will drop it in this thread later
| THard.co.uk | Xray | MuchMore |
Old 01-25-2011, 06:25 PM   #2698
BRC
BRC's Avatar
Originally Posted by jonest View Post
That's great! Will upgrade the esc tonite
jonest/dameetz....
anyone tried this???
i've seen the programme.... 119MOD
it seems theres 30 points for boost timing...
and still 20 points for turbo....
but havent tried....
need to find settings that would make a 8 min heat/final
i'll be using either 10T LRP X12 (119 stock) or the 5.5T (119 MOD)
EP Touring: Xray T4'14 / DualSky 870 combo
GP Offroad: Agama A8 / RB WS7
EP Drift: Xray T2'007 / Mamba Max
Mini: M05 Xevo conversion
Mini Z: Atomic BZ
BRC is offline   Reply With Quote
Old 01-25-2011, 08:44 PM   #2699
dameetz's Avatar
Originally Posted by BRC View Post
jonest/dameetz....
I haven't try it yet bro....maybe this wknd....I ll be using 5.5t also....see u at the race....ok...
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-25-2011, 09:44 PM   #2700
jonest's Avatar
jonest/dameetz....
Upgraded the esc but I can't set the boost timing more than 10 and 20 using LCD box. Any1 has any idea?
jonest is offline   Reply With Quote
