Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 05-13-2010, 07:55 PM   #256
JKL1031's Avatar
i plan on getting xerun,, but maybe i will just stay 5.5 w/o this upgrade. Would i still blow up something if i used minimal supercharging, etc?
JKL1031 is offline   Reply With Quote
Old 05-13-2010, 08:21 PM   #257
Send a message via AIM to A-Ko
TTT
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 05-13-2010, 09:27 PM   #258
You should stay with the normal firmware with a 5.5R.
With the supercharger features enabled, it is already stressing the ESC, Motor and the batteries with higher turn motors (10.5 and up). Even if you use minimal turbo settings on 5.5R, it will create unwanted heat to all the components.
Having said that, I have tried boost/turbo with 8.5R and its as fast as 5.5R's, but again the components are hot after a few minutes. So I rather run a normal 5.5R over a supercharged 8.5R.
hardmankam is offline   Reply With Quote
Old 05-13-2010, 09:49 PM   #259
JKL1031's Avatar
cool
Old 05-14-2010, 05:54 AM   #260
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
A special designed stock ESC will be released soon (in June).
This is Xtreme Stock ESC with full functions of turbo.
hobbywing is offline   Reply With Quote
Old 05-14-2010, 06:00 AM   #261
The size of XERUN-120A/60A ESC vs a Xtreme Stock ESC.
Old 05-14-2010, 06:04 AM   #262
Jakesterama's Avatar
Trader Rating: 64 (100%+)
Nice reduction on size! Any plans for a 1S compatible ESC?
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 05-14-2010, 07:29 AM   #263
gixer's Avatar
Quick bump.
Any thoughts please Hobbywing?
Originally Posted by gixer View Post
Hobbywing,
Quick question please.
I use my car mainly for drifting, i'm currently swapping between 2 motors.
1/ XeRun 13.5T
2/ Speed Passion V3 10.5T
Because there is very little resistance in the drive train while drifting (as the wheels are effectively spinning all the time we're driving) what FDR would you recommend for these motors with th SC software at the advised settings for each motor?
What's your thoughts on gearing for drifting as well please?
Should i go with bigger pinion and gear for top speed to provide more resistance for the motor.
Or should i go for a smaller pinion and gear for acceleration?
If so how will this affect the motor/Esc having it what is essentially free spinning most the time?
Cheers
Mark
HB Cyclone (WCE Exotek) x 2, Pro3 (Penguin chassis), Pro4, M-04M (Eunos Roadster)
Losi MRC, Axial XR-10
ERevo Erbe, HPI Firestorm (Nitro), Blitz,
gixer is offline   Reply With Quote
Old 05-14-2010, 07:45 AM   #264
dameetz's Avatar
I hope the Xtreme Stock esc will come in more color choices.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-14-2010, 02:07 PM   #265
AGNO's Avatar
Xtreme Stock
Beautiful!
I want it!
There are new features?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-14-2010, 03:25 PM   #266
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
That would be good. At least red, blue and black would be good.
Originally Posted by AGNO View Post
Xtreme Stock
Beautiful!
I want it!
Yeah is there any different features and will it run on the LCD programming box with the same software as the Xerun v2 ESC's?
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-14-2010, 03:42 PM   #267
To Hobbywing:
Fantastic software mate!!!!! I have broken the track record by 6 seconds at our local track(in 13.5 Super Stock Touring Car) and set a time 12 seconds faster than anyone set at the nationals 3 months ago.
I have a question regarding software testing:
Have you done any testing with an exponential curve instead of a linear curve and removed the turbo function? I think it could be even better than 422.
For example(hypothetical): you could have a start rpm of 6000 and an end rpm of 25000 and you could have a max timing of 45 degrees (at 25000rpm). In that rpm range the timing would go up exponentially. There would be no need for any turbo whatsoever.
Just a thought. I believe it may be faster but also a lot simplier for the average racer to get set up right as you wouldn't have to worry about the turbo feature.
regards
Michael Jones
ixlr8nz is offline   Reply With Quote
Old 05-14-2010, 04:10 PM   #268
steliosh's Avatar
Very nice addition to a very good lineup, Hobbywing.
I can see a sensor cable socket, but on the sides you showed, there's no socket for the fan... Is it on the other side, maybe, or it doesn't need a fan?
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 05-14-2010, 07:47 PM   #269
You may notice that there is a small white connector just under the word "FCC", it is used to connect with a cooling fan.
We recommend using a cooling fan for stock racing. If the turbo timing function is activated, the ESC works hard and generates more heat, a cooling fan is very useful in such a case.
Old 05-14-2010, 07:51 PM   #270
Originally Posted by ixlr8nz View Post
To Hobbywing:
regards
Michael Jones
Hello, Michael
Our engineers are also checking the threads on the forum, and will carefully consider your suggestions!
Thanks very much! And have fun with our ESCs!
