Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-25-2011, 05:52 AM   #2671
irgo's Avatar
1.because basicaly SP for SP Firmware only.
But luckly you will be able to switch between them (caution : take it with your own risk),
only if, you are really sure want to use Hobbywing Firmware.
please asked hobby wing and sp for further services,
first you will need intall the previously first HW 518 software released to change it to Hw, firmware for it's LCD,
then install your latest HW software, and update its lcd.
Good luck.
Quark Force
irgo is offline   Reply With Quote
Old 01-25-2011, 05:59 AM   #2672
M7H
M7H's Avatar
Originally Posted by chinaman View Post
The 1224 has been replaced by the 110119. Nobody has come back with what type of bugs the 1224 had, whether they are 6-legged or 8 or those that buzz , just go with 518 or 110119.
Is the 110108 ok to be used as well?
The only "bug" I can think of, was the problem that you could not change the settings with a laptop, but only with the 2 in 1 box.
Serpent
M7H is offline   Reply With Quote
Old 01-25-2011, 06:04 AM   #2673
M7H
M7H's Avatar
Originally Posted by MENTAL DENTAL View Post
It's done it on a 13.5 Losi as well. Maybe reflashing for a third time will help. May even download the next upgrade[110108] and try that?
I would download the latest then, so the 110119.
If you start with 21 boost and 8 turbo, it's the same performance as the 518 (except that you have a lot more punch and a cool motor) then start adding more timing until your the fastest on the track, and still have a cooler motor and more runtime then you where used to with the 518....
Serpent
Old 01-25-2011, 06:44 AM   #2674
Originally Posted by Shawn68z View Post
Boost will normally lower the temperature of the motor. By starting with a conservating starting point, and moving to a more agressive seting if you need the extra power.
What are the settings you are using now? If you post your current configuration, we can make some suggestions.
Shawn.
Now without boost :
motor lrp x12 17.5t
esc HW xerun 120a
final gearratio 3.7
timing on motor +10
esc settings
punch - 7
timing - 2
Temprature after 6min about 150F, and its with stock firmware ( without turbo etc)
But in next competiton I'll need boost but I dont want to burn motor
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 01-25-2011, 07:09 AM   #2675
Good luck.
Thanks will do, but not sure if it will work because when I try to update the the LCD from sp to hw it keeps telling me that the fw is unable to be loaded. However I'm saying that the LCD still allows me to update the hw fw so maybe this will just have to do for the moment as this is more important.
Cheers
emerge is offline   Reply With Quote
Old 01-25-2011, 07:55 AM   #2676
i thaught it was happened to me only... my 1224 braking also dissapointed me eventhough had several times reflash the software...
zamrioo2 is offline   Reply With Quote
Old 01-25-2011, 08:00 AM   #2677
MENTAL DENTAL's Avatar
I'll start on it tonight. Many thanks for your help. Much appreciated.
Dave
MENTAL DENTAL is offline   Reply With Quote
Old 01-25-2011, 08:08 AM   #2678
the way the timings introduce for 518/422s and 1224 is totally different... if 46deg 1224 behave like 518/422s, your motor definately will burn...
Old 01-25-2011, 08:24 AM   #2679
M7H
M7H's Avatar
When I run 34 Boost (350rpm/degree) and 12 Turbo (3/0.1 ramp), so 46 in total, my motor is cooler then it was with 29 total timing with the 518 version. But a lot faster!
I'm not questioning that the timing is build up totally different, I'm only saying the motor runs much cooler with the same figures compared to the 518 firmware.....
Disclaimer:
I'm driving 12th scale, 1S lipo!....
Serpent
Old 01-25-2011, 08:42 AM   #2680
guinnes.s's Avatar
this are the setting that i used for first time at my racing club.
110119 with sp13.5 v3 at 7.4 fdr ,max temp 72c
4 DRRS 8
9 boost timing 55
10 turbo slope 24
12 turbo timing 30
13 start rpm 2000
14 turbo delay 0.4
timing acc 200
the car felt really quick in the infield and at beginning of the 30 metre straight,but the turbo did not felt to have any punch.what setting could help?
thanx
guinnes.s is offline   Reply With Quote
Old 01-25-2011, 09:11 AM   #2681
sizheng's Avatar
Originally Posted by terryh View Post
I tested 1224 on Saturday and was very impressed with it, that was with a GM 13.5 with a 12.5mm 1600 gauss rotor. After reading your comment that 1224 is better with this kind of motor, and thinking that 1224 had bugs, i'm now confused. Am I better using 119, or using 1224?
Hi,just go on to use 1224 if you feel good. In my thought, It's a test version with some new technology.
The only thing you shall keep in mind is if you change your motor type and don't feel good with 1224 anymore, then you can change to 0119.
Remember to keep a copy before you upgrade. Cause 1224 is not in the new 1.63 program.
Hope this will help.
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 01-25-2011, 09:19 AM   #2682
sizheng's Avatar
4 DRRS 8
9 boost timing 55
10 turbo slope 24
12 turbo timing 30
13 start rpm 2000
14 turbo delay 0.4
timing acc 200
thanx
You almost used up timing in boost, 2000+200*55=13000 , and with 7.4 FDR, the speed of your car is only 20km/h at this RPM.
TEAMHOBBYWING CHINA
Old 01-25-2011, 09:33 AM   #2683
Hi there,
has anyone had a chance to run an LRP 10.5 X11 motor/ HW Xtreme stock combination with the new 119 software yet?. If so, do you have any start point settings at all?
Many thanks for any help
xraydad is offline   Reply With Quote
Old 01-25-2011, 11:01 AM   #2684
Andy63's Avatar
Originally Posted by Andy63 View Post
hey all!
I need some help here.
i have a massive delay when braking with the HW Extreme stock ESC. When braking it has some delay, i have adjusted the transmitter EPA to 135% brake and didnt really feel any difference. So what can i do to make it better?
anyone could have any ideas?? Thanks
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-25-2011, 11:22 AM   #2685
csracing's Avatar
Trader Rating: 22 (100%+)
Same here, since day 1 with my Xtreme. Had intended on making a video and posting it for Cobra to review but only seem to remember it when I'm at work..
CSR
csracing is offline   Reply With Quote
