Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 01-23-2011, 11:57 AM   #2596
MENTAL DENTAL's Avatar
Questions??
Running a HW 60A Xerun with 518 software 13.5T GM ,
FDR 7.57
1=1
2=5
3=5
4=5
5=4
6=4
7=1
8=1
9=5 [changed to 7 for last final]
10=2
12=5
13=2[ 6000 changed to 4500 for last final]
14=2
15=6
During the last final the car was fast then slowed then fast and so on . Almost like it was going from sensored to sensorless. Brand new sensor lead was in place. This also happened for the first two runs last week when changing the lead cured it and enable a qualifying time and two subsequent fast finals.
Today four good runs and then fast-slow-fast. Motor temps max at 42oC
Any ideas?? Anyone??
MENTAL DENTAL is offline   Reply With Quote
Old 01-23-2011, 12:26 PM   #2597
SammyZ's Avatar
Trader Rating: 138 (100%+)
anybody know the hottest motor you can run on the Xerun 120 v2.1?
Would the xtremestock ESC be a good choice for modified TC asphalt? Probably 5.5t brushless wind?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 01-23-2011, 12:44 PM   #2598
Check the spec on the extreme stock: 5,5t...?
http://www.hobbywing.com/english/Art...?ArticleID=464
rbakker is offline   Reply With Quote
Old 01-23-2011, 01:28 PM   #2599
COBRARACING's Avatar
The xerun v2.1 can run down to a 3.5T
The xtreme stock can run a 5.5T with no turbo timing at all (switched off) with turbo timing on can run a 8.5T and up .Must always run a fan no matter what .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-23-2011, 01:35 PM   #2600
chinaman's Avatar
Originally Posted by irgo View Post
... still need to know the max rpm from esc firmware ...
if HW do come up a log ... it will be thanks to your persistence (since Sep 2010???)
but you know they are only doing it just to keep you quiet ...
have you ever watch Shawshank Redemption, how Andy managed to get the city to fund his library? hopefully it will not take you that long to get your prayers answered ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-23-2011, 01:40 PM   #2601
Great ESC. Are the release numbers based on date? Is 119 equal to Jan 19? Maybe more descriptive names for easier reference, e.g. 19Jan2011STOCK?
Just a suggestion.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-23-2011, 01:40 PM   #2602
@Cobra,
cann you give us a link to the new instructions for the 110109 when ready?
Old 01-23-2011, 01:43 PM   #2603
Barry_Hughes's Avatar
Originally Posted by stumpiey View Post
Hi guys
just put the new firmware on my SP 2.0 pro, works really well, didnt feel faster than the 518 i was running friday, but after checking lap times i was just over 4tenths faster on my fastest lap and nearly 9sec's over a 5min run
but im having problems updating the lcd programing box, any idea's ?
cheers
stumpy
try loading an early version on the box the install the latest HW version, especially if you sp on the programming box, with the HW software on the box it should load OK.
I always load it twice, just to make sure.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 01-23-2011, 02:06 PM   #2604
njt
njt's Avatar
My the stock programme 1224 has changed in the following way
turbo slope has the following value
1=3 2=6 3=12 4=18 5=24 6=fastest
also timing acc has changed
1=50 2=100 3=150 4=200 5=250 6=300 7=350
is this a new programme change ?
njt is offline   Reply With Quote
Old 01-23-2011, 02:11 PM   #2605
Ran mine tonight for the first time with 224 in (nosram x11 10.5). Initially i used the recomended settings for 11.5 but left my FDR at 7.6 as thas what i used to run with 518. Could instantly tell it was smoother than 518 and soooo much cooler on motor temps but i needed more speed. Adjusted the settings to punch 7,
30deg boost timing,
18deg turbo timing,
start rpm 2000,
0.2s turbo delay,
12deg/0.1 sec turbo ramp,
750 boost timing acceleration
Its faster than 518 was now but the temps are nowhere near what they were, I think its alot nicer than 518 to drive but i may need to lower my punch a little as it goes sideways a bit too easily.lol
Not sure if im gonna try 119 or not yet as im nowhere near max settings on 224 and its one of the fastest (in a straight line) cars where i race.
Thats my little opinion and settings if there any help to anyone. Track is medium sized with a tight infield and around 50m straight
scytherat is offline   Reply With Quote
Old 01-23-2011, 02:22 PM   #2606
nope, still wont upgrade, it's saying the current version (v1.06_100617 cannot be updated to v1.07_101224
and when the box is connected tothe ESC it is saying please upgrade software and wont let me change anything
any help would be cool
stumpiey is offline   Reply With Quote
Old 01-23-2011, 03:14 PM   #2607
SammyZ's Avatar
do I need to run a fan on the ESC and the motor using xtremestock and 5.5 turn motor?
Hotbodies USA
SweepRacing USA
Old 01-23-2011, 03:21 PM   #2608
Those are the settings for the 0119STOCK software. So, that is the newest version.
Shawn
Shawn68z is offline   Reply With Quote
Old 01-23-2011, 03:24 PM   #2609
Yes for the ESC, and highly recommended for the motor.
I would also highly recommend buying the Xerun 2.1 (120A) version instead of the XtremeSTOCK . The 2.1 model is more suited to running high current that is demanded for mod motors.
Cheers,
Shawn.
Old 01-23-2011, 03:59 PM   #2610
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by dameetz View Post
I tested the new fw0119 with SP 11.5t v3.0 today, mine has adjustable timing maybe for TITC this year it will be same as last year's handout SP that has got fixed timing. Here's the set-up I ended up with after 3 packs of testing. I might fine tune it again, maybe trying different FDR and start rpm.
4-7
9-37
10-6
12-25
13-3
14-5
15-15
Motor end bell timing at max 10deg
FDR 6.88
Max Temp 70C
Track is technical infield with long straight, medium grip. Temp is almost like in Thailand, I also live in South East Asia. I m happy with the torque and top speed of this new firmware. The best so far....great job Hobbywing.
Thanks. Ill give it a shot
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
