Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 01-20-2011, 06:51 PM   #2506
Originally Posted by zamrioo2 View Post
tested 1224 last nite... i would say it was very2 smooth but i found the brake so poor compare with 518/422s... do i need to reflash...?
I use 1224 in my pancar and have TONS of brakes with this version. Make sure you have brakes and reverse set to 100%.
Shawn
Shawn68z is offline   Reply With Quote
Old 01-20-2011, 07:00 PM   #2507
Originally Posted by trx B E View Post
All right guys I have the xtreme stock with the latest firmware! I am running it in a SC truck but I am having nothing but problems! The first problem was solved when the voltage cutoff had to be dropped to 2.8v so the truck could finish the race! Now no rhyme or reason in the middle of the race it seems as though it goes into the sensorless mode or zero timing really slow mode! I reset the throttle and let it sit then it is fine again till halfway through the heat? I switched motors and sensor wires and batteries but not sure what is causing this but very frustrating especially since it is so new and nothing but problems! It appears the green light is flashing when it does this! Any help would be great would be great!
Cobra or someone could you give me any ideas on what is causing this?
trx B E is offline   Reply With Quote
Old 01-20-2011, 07:12 PM   #2508
I would suggest borronwing a known (new) lipo and trying it.
Sounds like your hitting low voltage cutoff under the load of a big heavy chassis, trying to push around an underpowered motor.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-20-2011, 08:55 PM   #2509
Its not the lipo I have three brand new ones ive tried!
Old 01-20-2011, 09:40 PM   #2510
TeamWTF's Avatar
What motor/speed control settings are you using?
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 01-20-2011, 11:19 PM   #2511
Holmenkollen's Avatar
Originally Posted by Andy63 View Post
Ok, i have setup the transmitter and the ESC. But when like i said press the buttons like the manual says the ESC reset itself again when it flashes green and then stop flashing and only turn into red.
Any other ideas would be great if there is any. Thanks
Jag kommer till Vxj imorgon, vi kan titta p det d.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 01-21-2011, 01:20 AM   #2512
M7H
M7H's Avatar
Shawn
I've read this remark earlier, to also set reverse to 100%, even if you don't use reverse, but I can't feel any difference under braking, so I think this was a bug in any of the earlier firmware versions.
Shawn, do you feel a difference?
Also with flashing the ESC, some say you have to flash it 2 times, is this still needed?
Serpent
M7H is offline   Reply With Quote
Old 01-21-2011, 01:52 AM   #2513
sizheng's Avatar
Hi, please reset your full throttle point and a tip is leave a little bit space to the " physical" full throttle point as your "setting" full throttle.
My english is not good. Hope you can understand what I mean.
sizheng is offline   Reply With Quote
Old 01-21-2011, 01:57 AM   #2514
sizheng's Avatar
Originally Posted by dameetz View Post
I m using 224 which has a total timing(boost+turbo) of 46, while the 108 has total of 30 if I understand correctly, so 224 should be faster. I have not tried the 108 yet and I m happy with 224, runs fast and cooler motor temp, I m running 10.5-11.5t stock TC class BTW.
46 and 30 are not the real degree. so they can not be simply compared by the number.
after our recent test, we found 1224 is very good for Hobbywing motors (which relatively has more torque). But for those RPM type motor, 0108 is better.
Old 01-21-2011, 02:00 AM   #2515
M7H
M7H's Avatar
I think you mean to say what "whoopass" also said.
Originally Posted by whoopass View Post
set the epa throttle at 100%. setup the esc/calibrate. then set the EPA throttle to 105/110%
done
Serpent
Old 01-21-2011, 02:14 AM   #2516
sizheng's Avatar
thanks, i think "whoopass"'s method also works.
the reason for this problem is the new software use 99% as the full throttle threshould while the old one use 95%. so sometimes if we set the full throttle point very quickly it will cause the reading-error.
Old 01-21-2011, 02:17 AM   #2517
daleburr's Avatar
Where do you get that information from, or are you just guessing/assuming?
I have seen nothing to state (or even suggest) that they are anything other than actual numbers of degrees.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 01-21-2011, 02:24 AM   #2518
2wdrive's Avatar
An offtopic question but do any of the chinees posters on here know where the rc circuit is in Shanghai? I asked once in a rc shop at Hongkou Stadium and they said it was close by but they could not give me an adres. I vissit Shangai at least once a year so would be nice to vissit the track sometime.
2wdrive is offline   Reply With Quote
Old 01-21-2011, 02:26 AM   #2519
sizheng's Avatar
send me an email before you come. I'm glad to take you there when you are coming.
salton.dong@gmail.com
Old 01-21-2011, 02:28 AM   #2520
sizheng's Avatar
that's something related technical detail , but it is not guessing, it is true.
