Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-17-2011, 01:55 PM   #2416
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Originally Posted by rbakker View Post
Hey people,
got a strange thing with my software....
I upgraded the esc and 2 in 1 box with the new 1224 software,
that all went ok. Then i try to change the timing settings to my own choice.
Standard the boost setting is 22 and the turbo 14,
When i try to change this to lets say:
boost 19 and turbo 12 all works out as it should have when i do the apply.
So everything loads in the esc.
Then i go for a drive...and after that i check the settings:
The boost and timing setting are back at the standard 22 boost and 14 turbo.
It looks like the esc doesn`t hold the settings, same for rpm ranges etc..
Tried to reload the 1224 to esc and 2 in 1 box and also back to 518 and back...
the 518 does hold its settings.
Does anybody has the same problem or knows a method to get it right...????
Exact same thing an my 1S and Xtreme esc's. It save the other settings but not the boost and tubo. Calibated ect.........using the LCD the settings save and and show on the computer but changes made on the computer do not load to esc.
Tire Chunker is offline   Reply With Quote
Old 01-17-2011, 02:15 PM   #2417
I checked it again and it is indeed only the boost and turbo.
The 1224 and 110108 software dont hold the settings and after disconnecting the pc or 2 in 1 box, the boost and turbo settings are lost.....
the old 518 software does save the settings.
ARE THERE MORE PEOPLE THAT HAVE THIS PROBLEM..???
rbakker is offline   Reply With Quote
Old 01-17-2011, 02:45 PM   #2418
Jamesalex's Avatar
How have you been setting the speedo up via pc?
I downloaded and updated the lcd box, (flashed twice) then updated the speedo (flashed twice) then I set the speedo up using the lcd box only and my sppedo saved all the settings and went like a rocketship on the standard suggested 13.5 settings.
Jamesalex is offline   Reply With Quote
Old 01-17-2011, 02:48 PM   #2419
Yes i set the esc with the PC, not the 2 in 1 box.
Think setting does work with the lcd 2 in 1 box.
It doesn`t work with the PC....its a bug.....
Will be fixed i hope.
Is it possible for others to try this through the pc, just to make sure.
Old 01-17-2011, 02:50 PM   #2420
getpip's Avatar
Tried the new 1224 yesterday.
Thought it was ok but it just didnt seem to have the rip of the 518. (13.5 motor)
Played with the settings a little and ended up with a comparable lap time but without the real fast feel of the 518.
Temps were lower and maybe I felt this way because it was smoother but so far I am not too excited. I guess I will play around some more with the settings and see what I can find.
Is it just me?
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 01-17-2011, 03:05 PM   #2421
Man....I`m a idiot....
here the instructions....its only possible with the program box:
CAUTION!
1. Once the new firmware has been loaded into the ESC, you can only use the LCD Program Box to set the parameters of the ESC.
2. You need to update the firmware of the LCD Program Box to compatible with this firmware.
HOW TO UPDATE THE FIRMWARE OF THE LCD PROGRAM?
Please check here: http://www.hobbywing.com/upload/manu...k%20manual.pdf
So, no bug....lol
Hope they will change it anyway, otherwise my special small laptop is useless.
Come on Cobra..
Old 01-17-2011, 03:09 PM   #2422
M7H
M7H's Avatar
Would say that they are all up to the task, performance difference will be near to zero... The 1S doesn`t have a cooling body on it, i would buy the xerun 120A either v2.0 or v2.1....
Also the 1S comes with cooling body and fan, but you can choose yourself if you want to mount them or not....
(Roy, je bent soms voor je beurt aan het praten, als je het niet weet, zeg dan niets..... )
Read the 1st page of the manual documents, allready mentioned a few times now the last few pages of this thread, and fid out that in RED there in mentioned the word CAUTION and see what's written there....
Serpent
M7H is offline   Reply With Quote
Old 01-17-2011, 03:13 PM   #2423
M7H
M7H's Avatar
Is it just me?
Not?...
It really has a lot more rip!...
with the 518, I put exponential on my throttle, to get some "bottom power"
with the 1224, I lower the exponential, because it was to much!....
So, yes I think it's you...
Serpent
Old 01-17-2011, 03:44 PM   #2424
can`t know it all....
(maar meestal wel..... lachuh...)
Old 01-17-2011, 03:52 PM   #2425
CAUTION!
So, no bug....lol
Come on Cobra..
You forgot to read the whole sentence!!!!!!!!!!!!
CAUTION!
1. Once the new firmware has been loaded into the ESC, you can only use the LCD Program Box or PC
software to set the programmable parameters,
neither the LED Program Card nor the SET button is
available for programming the ESC with this new firmware.
Old 01-17-2011, 04:01 PM   #2426
Hey hobbywing enthusiasts
I'm after a setup for 224 will be running Lrp x12 10.5t motor on open carpet track with 30metre straight.
pm me or email me on channy54321 @ Hotmail . Com
MChandler is offline   Reply With Quote
Old 01-17-2011, 04:32 PM   #2427
getpip's Avatar
Not?...
OK .. Maybe I will just wind up #15 and see what happens!
Are you running 13.5 M7H?
Maybe you could PM me the settings you have been using so I can take a look?
Old 01-17-2011, 04:42 PM   #2428
M7H
M7H's Avatar
Yep, 13.5...
Posted my settings a few days ago, mind you i'm talking 12th scale...
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
Serpent
Old 01-17-2011, 05:05 PM   #2429
BennyBagems's Avatar
Trader Rating: 15 (100%+)
Originally Posted by chinaman View Post
Had cogging problems when I used my older batteries, but ever since I changed to my newer 5000mAh 40C battery, it was fine.
apparently it has to do with increasing internal resistance of lipo batteries as they get older.
All my batteries are new, 5600 50c IP packs.
It's not like a normal cog where it cogs at take off then comes fine, it cogs so bad the wheels can't turn, even when it's off the ground. It does that after a couple laps of normal driving, if I turn it off and on it comes right for another lap or two.
BMAX 4 III - YZ-2 - S350BE-1
Ryper Hobbies - AKA - Arrowmax Tools - Yokomo Australia
Vice President GOMCC - http://www.gomcc.com.au
BennyBagems is offline   Reply With Quote
Old 01-17-2011, 05:55 PM   #2430
smilekt's Avatar
Hey people,
for problem return back to default factory setup .. you need to do any item u make change should press o.k button first & then u can go another item ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
