Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-11-2010, 05:23 AM   #226
Originally Posted by COBRARACING View Post
The esc can hold only 1 firmware at a time but the lcd can hold 3 different settings .
Yes , ESC hold one firmware. If LCD card can hold at least 2 firmware.
We may change the firmware in ESC easily without PC.Just connect LCD to ESC and upgrade the firmware as you wish...
mos-leung is offline   Reply With Quote
Old 05-11-2010, 06:50 AM   #227
Send a message via MSN to Bigger Brother
I'm sort of struggling here to understand why you would want to be changing between mod and stock firmwares during a race day. I can understand you not wanting to take a laptop to the track, but if you are racing mod one day, surely you would load the mod software at home before you go to the track, and then if you are racing stock at your next event, change the firmware to stock at home again before you go to your next event?????
Anyway.....
I had some good results with the new software last week at possibly one of the largest tracks in the UK that 13.5 motors race on. Sadly practise day was a washout so I didn't get a chance to try it before race day, and my driving let me down on what should have been a good result. In terms of straight line speed and accelleration, I certainly didn't feel down on power to the Tekin runners at all! Hopefully I'll get some more practise time before the next big meeting to try some more things out, but I'm pretty pleased with how it was running.
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 05-11-2010, 06:58 AM   #228
Joel Lagace's Avatar
if we have the ability to at least shut off supercharger on the fly then only one firmware would be needed... Sometimes running stock u just may want to shut off the supercharger. Track conditions could be slick when you show up. Or you could be having traction or setup issues where if you took away some power it may actually help
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-11-2010, 07:18 AM   #229
defcone's Avatar
Trader Rating: 15 (100%+)
Ran 422S/W tonight with 17.5 the motor came off at around 130F and I thought it was fading towards the end, anyone have similar problems?
defcone is offline   Reply With Quote
Old 05-11-2010, 10:07 AM   #230
Send a message via MSN to geubes
Yes. It faded but wasnt hot - It was related to running to much timing to quickly I think. Cured it by reducing timing and gearing up
geubes is offline   Reply With Quote
Old 05-11-2010, 01:24 PM   #231
xrayal's Avatar
heat could cause fading as could lipo cut off to high. did you callibrate your speedo at 95 then turn it upto 105?
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 05-11-2010, 01:27 PM   #232
xrayal's Avatar
sp have relesed their version of 422. as far as i can see its exactly the same as hw but for the sc rpm delay. hw 3000-15000 sp 4000-12000.
does this finally prove they are the same speedos?
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 05-12-2010, 04:01 AM   #233
In some competition, it will be mod & stock in same day.
If you join both event, what you need ONE RC car with 2 motor (stock & mod). No PC to change the software.....
Old 05-12-2010, 04:12 AM   #234
Thats why you have 2 cars, 2 esc, 2 motor etc...
chovden is offline   Reply With Quote
Old 05-12-2010, 04:29 AM   #235
defcone's Avatar
I'm running the 6th setting on timing with 10 deg. of timing on the motor can. By gearing up, you mean lower fdr?
My motor was only at 55 degrees Celcius and batteries came off at 7.6V with cutoff at 6.8V so I don't think it was any of those two.
Old 05-12-2010, 04:31 AM   #236
TRF4evr's Avatar
hi keith,
ur car was quick the first qualifier, the second run when u change up timing on esc looks fading towards end of race, but still second quickest against lrp sxx ss which was not much....IMO if u played with gearing more might get more out of it....overall Im impress with the HW software can't wait to have mine installed n start playing with it
TRF - HUDY - Much more - Ride
Proamp Lipo - Speedpassion
www.feralbatteries.com
TRF4evr is offline   Reply With Quote
Old 05-12-2010, 04:39 AM   #237
I was running setting 7 on timing setting and 10 degrees motor advance. Took off the motor advance and increased the pinion by 1 tooth, kept timing setting to 7. stopped the fading
Old 05-12-2010, 04:42 AM   #238
defcone's Avatar
Thanks, will give that a try.
Old 05-12-2010, 05:04 AM   #239
Silvialite's Avatar
Hi bros,
I'm currently using a 7.5T SP motor. Should I be running the stock firmware with turbo or the mod firmware. Would the turbo kill my motor? I'm using it for drifting.
Team Underground
To be Cheaper, Better, Faster...
HB TCD CSed 1:2.5
Silvialite is offline   Reply With Quote
Old 05-12-2010, 07:36 AM   #240
any issues using a "Y" connector for the lcd to the ESC? To avoid constant removal from the ESC or the receiver? At some point we will wear out or damage those connections..
www.rcottawa.com
