Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 01-14-2011, 02:18 AM   #2326
hey guys what program do I need to open up the usb software? The disk that came with my esc comes up blank on my computer? I want the new stock firmware but I cant find the right programs to open up the software? Any help would greatly be apreciated!
trx B E is offline   Reply With Quote
Old 01-14-2011, 02:28 AM   #2327
Jamesalex's Avatar
TRX B E - you will need winrar to open the download which is a free software program.
Okay due to work my day of testing is not going to happen tomorrow now and i have i race on sunday, with the 101224 software with 13.5 brushless in touring cars going, are the settings close to the suggested settings or slightly different. profile numbers would be brill if posted.
thanks in advance
Jamesalex is offline   Reply With Quote
Old 01-14-2011, 02:33 AM   #2328
M7H
M7H's Avatar
Originally Posted by rbakker View Post
Nice to hear, with the speedtrap it`s so easy to tune the HW...
Did you noticed any difference on the turbo? With the old software it always was very smooth and i never noticed when it kicked in, with the Tekin it was 100% different, thats just like a second stage.
Hope it is still very smooth....Noticed any gain in topspeed or acceleration in the higher rpm`s?
Didn't really play a lot with turbo, but for what I've noticed, it felt the same.
I really think only boost timing is enough for our track, (for most tracks I even believe, for 1/12 scale)
The turbo timing is nice, but is a big energy consumer (or heating system ), which in the end of a 8 minutes final kills your performance.
Check once more my times on mylaps, and take into consideration, that the first 3 sessions were driven with the same Lipo...
http://www.mylaps.com/practice/showL...date=12-1-2011
If you check the topspeed, you can see that even after 6 minutes I am still able to drive 59!....
If you check the 9th of January (the clubrace, only the first qualifier is there, then the computer crashed. ), you can see that the speed drops a lot more, this was with the 518 firmware....
This drop in topspeed gives you a good picture about the performance of the whole system (battery, ESC, motor) during the run, the drop in topspeed on the straight end, tells you that you will also loose performance in the infield...
Serpent
M7H is offline   Reply With Quote
Old 01-14-2011, 02:38 AM   #2329
M7H
M7H's Avatar
I don't think the latest firmware will be on the disk.
Just download it from here http://www.cobrarc.com.au/ (thanks Cobra!)
And download the free "7-zip" program to unpack it.
Serpent
Old 01-14-2011, 02:50 AM   #2330
Nobody
Originally Posted by moraccio View Post
Hi guys.
Is there somebody that can help me?
I would like to use my Hobbywing 120A v2.1 fw 528 with a lrp x12 10.5t.
Which is the best set up that help also to mantain low temperature so that i can avoid damages?
best FDR (a range of course) ?
Thank you so much in advance!
moraccio is offline   Reply With Quote
Old 01-14-2011, 03:15 AM   #2331
M7H
M7H's Avatar
Nobody
The 528 is for modified, 10.5T is stock.
Your better of with the 518 firmware, or better even, the newest V3.0_101224....
Serpent
Old 01-14-2011, 03:17 AM   #2332
daleburr's Avatar
Hi guys.
The 528 is mod software so has minimal turbo etc. It won't produce much heat, but it will be fairly slow.
Run the 518 stock software with the recommended settings from the hobbywing PDF; those settings are on the conservative side.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 01-14-2011, 04:59 AM   #2333
sorry. i mean sp fw 528stock, not modified fw
Old 01-14-2011, 08:28 AM   #2334
dameetz's Avatar
You can try fw224, its running cooler with that firmware compare to the previous one.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-14-2011, 10:40 AM   #2335
Guys, tell me please, what software use for a stock 17.5T ? Boost it is not necessary, because it is forbidden at competitions.
( lrp x12 17.5T and xerun 2.0 )
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 01-14-2011, 04:40 PM   #2336
dameetz's Avatar
If you want without boost/turbo use fw508.
Old 01-14-2011, 06:29 PM   #2337
DriftMonkeys's Avatar
Send a message via MSN to DriftMonkeys
Default set up Blues
Hello Ive updated me FW to the 224 and there is alot of new setting then the old one .. Does any one have any recommended set up for a 11.5 T orion ?
~www.driftmonkeys.org~
DriftMonkeys is offline   Reply With Quote
Old 01-14-2011, 10:52 PM   #2338
blade072's Avatar
Trader Rating: 98 (100%+)
yes i have noticed that myself....any ideas for a tourer running 10.5 aswell??
thanks
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-15-2011, 01:23 AM   #2339
zipp's Avatar
Default Recommended Setups
here's the link Cobra posted:
http://www.filefactory.com/file/b4g9...are_110106.doc
download the word document and scroll right to the bottom for recommended settings
I tried the 11.5t recommended settings and it worked well. Compared to the previous recommended settings for fw518, motor temps for fw224 were 10deg celcius cooler with the same fdr (6.5) that i was running.
zipp is offline   Reply With Quote
Old 01-15-2011, 01:51 AM   #2340
Hi Guys,
Just updated my unit to the new V1.63_110108 firmware (SP V3 13.5) and I cant set the turbo timing (#12) to anything higher than 12 degrees.
Is that normal?
Additional info doc mentions 16deg timing as recommended setting.
What have I done wrong?
Cheers
Andrew
Lycan is offline   Reply With Quote
