Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-12-2011, 01:43 PM   #2296
TeamWTF's Avatar
Has anyone had experience with the Duo3 and the new software? (10224)
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 01-12-2011, 01:58 PM   #2297
sosidge's Avatar
Are these new softwares final releases or betas?
Old 01-12-2011, 01:58 PM   #2298
eceer's Avatar
Originally Posted by Damon View Post
excuse me Angelo, but the files of additional instructions are the same...
It appears to have been updated
Looking forward to trying the new software myself.
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 01-12-2011, 02:30 PM   #2299
Send a message via MSN to geubes
I ran it stock settings (suggested settings for 13.5 from the original manual), no timing on the endbell, geared between 6.8 and 7.2. it was good,
geubes is offline   Reply With Quote
Old 01-12-2011, 02:34 PM   #2300
TeamWTF's Avatar
Ok sounds good...
Forgot to mention i run 17.5.
I was using 1.5 'ticks' of timing (Fantom Ion3 has timing marks...) and it was too hot... so i will try no timing on the endbell. I have found most of the time that little bit of motor timing makes a lot of difference on the track... How can i tune aroun this? More dynamic timing and lower rpm/degree?
Old 01-12-2011, 03:08 PM   #2301
having run 17.5 as well a fair bit (with the older software) comparing how the two profiles changed between the motors, ide try something like:
FDR:6.0
Boost: 30
Trubo Ramp:9/0.1 s
Turbo:16
RPM: 3000
Full throttle delay: 0.2
SC ACC: 350
Old 01-12-2011, 07:47 PM   #2302
COBRARACING's Avatar
Hi guys
Flying in from hong kong to my adopted home state of brisbane Australia i couldnt beleive what i was seeing .
please take a look and may we all prey for the victims in this tragedy .
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-img00041-20110113-0943.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-img00042-20110113-0943.jpg
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-12-2011, 08:09 PM   #2303
Trader Rating: 20 (100%+)
pictures speak a thousand words...
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 01-12-2011, 08:13 PM   #2304
Godbreaker's Avatar
Originally Posted by COBRARACING View Post
Godbreaker both versions are the latest just the one program is much more safer for some other motors like the sp and the duo so we are giving you the best of both worlds .
Thanks cobra... cant wait to try it out..
Godbreaker is offline   Reply With Quote
Old 01-12-2011, 09:19 PM   #2305
Jack2's Avatar
Hi guys
we've been watching the news coverage all day. have many family and friends there, such a shock. going to be years of rebuilding, clean up etc. praying for those missing. not to mention the cyclone brewing off the coast of townsville
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-12-2011, 09:36 PM   #2306
Godbreaker's Avatar
Hi guys
my condolences and pray for victims in this tragedy.
Old 01-13-2011, 12:19 AM   #2307
Trader Rating: 44 (100%+)
sorry to see those pics.
I just have one question though, will the xtreme stock hold up in off-road racing? I am looking to run it in my slash with a 10.5 motor and some boost(will most likely run a fan on the esc just because
anyway what are your thoughts
also if I decided to go with the 120A SD V2.1 will this firmware work?
lmk
thanks,
Jayson
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 01-13-2011, 12:59 AM   #2308
chinaman's Avatar
terrible tragedy in Queensland ... my prayers to all those affected. not to forget there are floods in Sri Lanka and landslides in Brazil as well.
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-13-2011, 01:52 AM   #2309
Default fw 528 with lrp x12 10.5t
Hi guys.
Is there somebody that can help me?
I would like to use my Hobbywing 120A v2.1 fw 528 with a lrp x12 10.5t.
Which is the best set up that help also to mantain low temperature so that i can avoid damages?
best FDR (a range of course) ?
Thank you so much in advance!
moraccio is offline   Reply With Quote
Old 01-13-2011, 03:17 AM   #2310
I'm running a Xerun 60A with 518 stock firmware - motor is a Losi 17.5 which has 15 degrees physical timing, according to the Losi forums.
I'm currently running everything maxed with FDR around 5.2 - temps are not too bad, around 60-odd deg celsius - my next tweak will be raising FDR to see the effect, but I'm curious to know if I'm missing a trick?
colmo is offline   Reply With Quote
