Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-11-2011, 06:13 PM   #2266
COBRARACING's Avatar
Originally Posted by mc4798 View Post
we know you have been patient but its a serious annoucement so the rotating wheels are not neccessary.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-11-2011, 06:36 PM   #2267
Originally Posted by COBRARACING View Post
Hi guys
I have set up download links on the following website for you guys to download the files much easier
http://www.cobrarc.com.au/
regards Angelo
thanc cobra...
zamrioo2 is offline   Reply With Quote
Old 01-11-2011, 07:16 PM   #2268
both types of firmware are similar as for the 108 it has a little less boost as some sp and duo motors have high kv ratings and lower internal resistance from thinner or smaller wire windings being used so we introduced the 108 to compensate for it so you guys can use your motors without having to worry to much about temp and performance thats all .
so you have the best of both worlds dont you agree .
Old 01-11-2011, 07:50 PM   #2269
Godbreaker's Avatar
cobra, is this the latest firmware?
Godbreaker is offline   Reply With Quote
Old 01-11-2011, 07:59 PM   #2270
irgo's Avatar
Originally Posted by AGNO View Post
Hello Angelo, but what is really the difference between 1224STOCK and 110108STOCK ?
110108Stock max Advanced 30
011224Stock max Advanced 46
another differeces is on their DynamicThrootle (Boost) Curve.
Originally Posted by Born2Run View Post
I'm so confused
I Have two questions:
1)What motors should uses 1224 ?
2) On 110108 ,on the table with the recommended settings for 1/10 on-road
with 11.5T motor #13 boost start RPM is set to 2000.On 1224 for 11.5T motor #13 boost start RPM is set to 7000.
2000RPM on #13 for a 11.5T is correct?
That RPM start is designed for 1S.
Quark Force
irgo is offline   Reply With Quote
Old 01-11-2011, 09:25 PM   #2271
Born2Run's Avatar
011224Stock max Advanced 48
irgo i got that number (2000) from the table with the recommended setting list.It says for 2cells lipo,motor endbell phys.timing 0 to 15.It doesn't say that is for 1S.Check by your self.
Whatever
Born2Run is offline   Reply With Quote
Old 01-11-2011, 10:20 PM   #2272
irgo's Avatar
right i see miss typed there about (2000rpm)
that only happened when 1S is Applied.
and i see that's now 0~15 but 0~5 mention there.
, yes it need an explanation....
Quark Force
Old 01-11-2011, 10:40 PM   #2273
warnos's Avatar
So if you have 224 on and u use a duo/fiango/SP type motor just use max a of 30 degrees boost? Rather then having to put 108 on.
I used 224 with a Tekin motor and it was extremily fast.. very happy with 224 don't really want to go back down to 30 degrees after using 48..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 01-11-2011, 10:40 PM   #2274
Born2Run's Avatar
I don't want to burn anything.
Whatever
Old 01-11-2011, 11:27 PM   #2275
irgo's Avatar
Cheers
with Physical timing 5.... 51
Quark Force
Old 01-11-2011, 11:43 PM   #2276
TeamWTF's Avatar
Used this software for the first time today... With another racer so it was good to get some testing done...
I was using 6.0 and he was using 5.5 (Fdr)
I was using max boost and turbo (30 and 16)
He was more conservative...
Pretty much found you are better to use lower FDR and less timing... This is on a large track. With the old software i was using 5.2 fdr.
Mind you the car was fast... just generated more heat then i would have liked.
I would rather use 30 boost and say 5-10 turbo to reduce the off-power 'braking' effect when it comes off turbo as the track has a large sweeper at the end of the straight.
Overall though, very happy with the extra adjustability....
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 01-12-2011, 01:31 AM   #2277
chinaman's Avatar
Originally Posted by TeamWTF View Post
... Pretty much found you are better to use lower FDR and less timing... This is on a large track. With the old software i was using 5.2 fdr ...
was using 5.0FDR and still came out at about 40deg after 5 mins.
tried 4.5FDR and still came out 50deg ... maybe the track was a bit wet and air temp about 5deg ... with a bit more grip, i presume the temp will be higher too ...
small track - 6 corners and 1 chicane ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-12-2011, 02:01 AM   #2278
AGNO's Avatar
For engines Xerun 10.5 which version is most appropriate?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-12-2011, 02:13 AM   #2279
CFR
CFR's Avatar
similar question but with 13.5
here's a picture of my 1s software
database is 1.79
CFR is offline   Reply With Quote
Old 01-12-2011, 02:57 AM   #2280
Dear Loyal customers
I will answer your questions in the next couple of hours as i have something important to mention for the US market .
The Deal with horizon Hobby has been terminated because of many reason we wish not to discuss It's a sad day for the us racers who want other brands that they choose to use including hobbywing,speed passion and many more.It's a sad day not only for Hobbywing but also Horizon hobby who we worked tirelessly for over 6 months to get this project up and running .
Horizon is no way to blame for any of this they have worked really hard with us the problem is outside of horizon hobby and out of the control and hobbywing and Horizon .
It has been real battle in the last couple of weeks which led to my trip to china in short notice but what doesnt kill us only makes us stronger
Now enough of the bad news and more into the good news as we cannot establish a distributor for the usa as of the above statement we have decided to personally to service every canadian,us and southamerican citizen with hobbywing products direct to the dealers who want to purchase and the end user this way the pricing will stay competative worldwide .
We will in time meaning a couple of weeks after chinese new year which gives the usa time to settle after the winter period we will be setting up a online website and going direct from our factory to the usa to service you all .This will only be for the us continent for the time being .
We will set up a service faciltity with exceptable shipping rates for returns just to cater for our us citizens and as you know our customer support and tech support is state of the Art .
So the conclusion is we are giving you an easier path for purchase and support as we can no longer work with politics this is a business and a sport not washington .
This is a good thing for the dealer and end user .
Believe me when i tell you there is more to come from Hobbywing from what i saw with the limited time i had at the factory many more to come cant say much for the time being..
