Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 01-11-2011, 08:01 AM   #2251
AGNO's Avatar
Originally Posted by COBRARACING View Post
Hi guys
there was a mistake on the previous instructions for the 2 tyoes of firmware i have attached the correct ones .
sorry about that and yes also we will have the 508 v3.0 with the 8 options of brskes but the led card will not be able to be used just the lcd programmer.
Hello Angelo, but what is really the difference between 1224STOCK and 110108STOCK ?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-11-2011, 08:02 AM   #2252
Send a message via MSN to geubes
Originally Posted by Tire Chunker View Post
the 1224 software should not be used with HW, SP or Due motors. What motors should uses 1224 novak?
The 1224 worked great with my Novak in sedan but 1224 with a duo in 1/12th stock could not get the motor warm and the speed up.
Tom
weird because 1224 worked great with my Duo3 in Touring Car and was nice and cold but quick
geubes is offline   Reply With Quote
Old 01-11-2011, 08:19 AM   #2253
defcone's Avatar
Trader Rating: 15 (100%+)
What's new in 105 software? The mod one.
defcone is offline   Reply With Quote
Old 01-11-2011, 10:51 AM   #2254
chinaman's Avatar
there was a mistake on the previous instructions for the 2 types of firmware i have attached the correct ones ...
cheers ... i guess that explains my questions earlier in the thread ...
and actually, everyone else's conundrum as well ...
looking forward to the next time I will be down at the track for further runs with the speedo there was just not enough time the last time round ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-11-2011, 10:52 AM   #2255
getpip's Avatar
Originally Posted by daleburr View Post
Thanks for the new PDF, I think it makes a lot more sense now and answers most of the questions (although for some reason I had to install Chinese fonts to make it work, even though it's all in English).
Dale
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 01-11-2011, 10:58 AM   #2256
Originally Posted by M7H View Post
I will start with the same settings as I have now with the 518STOCK, and go from there...
Enjoy your study.
Strength/stiffness?
I always just replace what's broken, and only study my bank account.
Maybe a idea to start with the same settings, but then without turbo..
Just put the "old" turbo degrees extra by boost and make the rpm range fit perfect for the track...That is what i`m going to do outside.
(and offcourse a late turbo 0,5s, that only works on the straight, ala Hara.....for the mach outdoors, on really high rpm the motor cann handle more timing..)
It starts with stifness, from there displacement is calculated and stresses,
will see how it ends.....lol
rbakker is offline   Reply With Quote
Old 01-11-2011, 11:04 AM   #2257
chinaman's Avatar
Originally Posted by getpip View Post
I am having a similar problem ... Do you think you could convert it to a word doc and repost for us?
TY
just install the chinese fonts and it will work fine ...
btw the document is all in english, but i suspect characters like ( ) / are not in english ... i think ... found that out when I was resizing the fonts in the earlier document and found out that they were just characters and not recognised by word ... a bit of re-typing and managed to sort out the document just so that the large table in between do not appear in between pages, when the document is printed out, sorry am a bit of a OCD
Old 01-11-2011, 11:06 AM   #2258
could be a silly question, but doesnt the amount of adjustability in 1224 make 110108 a little redundant? or are the changes a little more sinister and for a reason? As surely you could just set 1224 to limit at 30 degrees by working out the actual total?
Btw the document does confirm some points to how this differs to the old 518.
Aka More timing/boost and a controllable turbo curve
Old 01-11-2011, 11:11 AM   #2259
getpip's Avatar
Got it sorted .. the problem was that Adobe wwas telling me the chinese fonts were an 'unavailable resource' .... had to get the latest acrobat update then install the fonts!
Old 01-11-2011, 11:21 AM   #2260
CFR
CFR's Avatar
XERUN-120A-1S-SD (V2.1) Brushless ESC
software/firmware, which one for Stock and were do I download it?
post a starting setup for the above please using 10.5 in 12th pancar
7.5 if you have one also
running on a medium sized & grip carpet track
have the software and hand held LCD programmer at the ready
CFR is offline   Reply With Quote
Old 01-11-2011, 01:19 PM   #2261
Born2Run's Avatar
I'm so confused
I Have two questions:
1)What motors should uses 1224 ?
2) On 110108 ,on the table with the recommended settings for 1/10 on-road
with 11.5T motor #13 boost start RPM is set to 2000.On 1224 for 11.5T motor #13 boost start RPM is set to 7000.
2000RPM on #13 for a 11.5T is correct?
Whatever
Born2Run is offline   Reply With Quote
Old 01-11-2011, 04:00 PM   #2262
begrie's Avatar
Hi, can i use soft 110108_STOCK for my sensorless 13T motor?
I am afraid if this soft only for sensored motor.
Thank you.
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 01-11-2011, 05:11 PM   #2263
COBRARACING's Avatar
Dear Loyal Customers
I have an annoucement to make for the USA market within 48 hours
I will answer all your pm's soon and all your thread questions very soon.
sorry for the delay
regards Angelo
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-11-2011, 06:02 PM   #2264
mc4798's Avatar
sorry for the delay
regards Angelo
mc4798 is offline   Reply With Quote
Old 01-11-2011, 06:11 PM   #2265
Hi guys
I have set up download links on the following website for you guys to download the files much easier
http://www.cobrarc.com.au/
regards Angelo
