Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-10-2010, 01:42 PM   #211
for hobbywing is it possible more steps in Boost starts RPM, Turbo Delay and timing Punch.
it would be beautiful had you do this
maximnaegels is offline   Reply With Quote
Old 05-10-2010, 02:12 PM   #212
xrayal's Avatar
ok settings for 422. tight/technical indoor on carpet. sp gt2.0 pro, sp13.5 ultrasportsman feigro v1, interlect ip 5000/35c, cyclone wce, fdr 7.921, motor temp after 5.5min 65degrees
1-1
2-1
3-3
4-9
5-4
6-1
7-2
8-1
9-8
10-1
11
12-9
13-2
14-3
15-2
no faults. exellent rip, stunning acceleration/top end. 3rd in the A. beating tekins and gms. cant see how it can be improved.
downloaded the cirtix interface, love the look of the rev counter style dials. is that going to be the only difference between hw and sp?
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 05-10-2010, 03:18 PM   #213
i have a hobbywing 80amp esc in my 1/8th truggy , can this be loaded onto this esc ..the stock422 has been loaded onto my sp lpf and its mental ....
shaun207 is offline   Reply With Quote
Old 05-10-2010, 04:35 PM   #214
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by hobbywing View Post
Hello, Kschu
Do you mean a Hobbywing Speed Calculator program? It is not for car ESC, it only works for helicopter ESC to calculate the blade speed (head speed) when the ESC works with a governor mode.
The LCD program box not only works for Hobbywing car ESC, but also works for Hobbywing Platinum series Aircraft/helicopter ESC, so the Speed calculator is a subprogram software in the programs group.
Hope the above information helps.
thanks...
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-10-2010, 07:34 PM   #215
Joel Lagace's Avatar
its been suggested to allow us to run 2 different firmware but i think it maybe impossible for the ESC to carry 2 and possilby difficult for the LCD to do it???
If it cannot be done....
Perhaps the next firmware that includes the Supercharger could have the ability to be turned off? IT could be as simple as selecting 1 for every setting in the supercharger section of the setup. So for the last 5 parameters pertaining to the supercharger we could select 1 for all of them to effectively shut off the super charger for slick tracks or low turn mod motors..
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-10-2010, 07:58 PM   #216
kschu's Avatar
anyone tested 422 software with 9.5t motor??
Old 05-10-2010, 11:28 PM   #217
yes I have run the 9,5 on 422 for some time
chovden is offline   Reply With Quote
Old 05-11-2010, 12:19 AM   #218
Man a 9.5 must be quick lol. I think it would be interesting to try a 6.5 in touring modified using 422 with a very high start and end RPM for timing boost to keep it cooler and run no turbo. I bet you could make a 6.5 go just as fast as any 4T but with a smoother spool up compared to a 4T.
Mike
ixlr8nz is offline   Reply With Quote
Old 05-11-2010, 12:23 AM   #219
on a very big track my 9,5 is as fast everywhere as a LRP x12 5,5, on a smaller track where we raced this weekend the fastest speedpassion with a LRP 9,5 stock motor where about 0,2-0,3 seconds slower a lap then a modified car
Old 05-11-2010, 04:01 AM   #220
Stein Tumert's Avatar
ESC Settings?
Motor?
Temp after 5 min?
FDR?
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 05-11-2010, 05:06 AM   #221
COBRARACING's Avatar
no it cannot be loaded it is only for the 1/10th esc's 60amp.120amp and the new xtreme stock only .the turbo timing software is good for 10.5 and up not for mod
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 05-11-2010, 05:11 AM   #222
The esc can hold only 1 firmware at a time but the lcd can hold 3 different settings .
Old 05-11-2010, 05:15 AM   #223
Thanks, Mos-Leung!
#1) I think it is a good suggestion. I will discuss the suggestion with our R&D depatment, but it is 23:35pm in China now, I think our engineers are all asleep.
#2 I am worried about that the flash memory of the LCD program box is not big enough to store 3 different firmwares, unless we use additional memory. But that will increase the manufacturing cost, that is not good for users to pay more for this LCD box. Anyway, thanks very much for this suggestion !!!
Thanks for your comment. :
#1 " it is 23:35pm in China " i know this cause i'm in Hong Kong where next to you (Shenzhen).
#2. Store 2 firmwares in LCD will be fine. One for mod , other for supercharged. So, we can change the mod/stock firmware without PC.
If it still not enough memories in LCD, how about add some option on supercharge firmware to disable the supercharge feature. i hope it will become 'mod' only.....
mos-leung is offline   Reply With Quote
Old 05-11-2010, 05:17 AM   #224
Agree .... if impossible just shut off the supercharge
Old 05-11-2010, 05:18 AM   #225
Originally Posted by Stein Tumert View Post
ESC Settings?
Motor?
Temp after 5 min?
FDR?
From Memory may not på 100% accurate, I am not 100% sure on setting 4 and 9 the rest is correct.
4-8
9-7
12-9
13-7
14-1
15-4
Motor LRP 9,5 stock spec, locked timing.
FDR 8,1
Temp after a 5minute racce with about 1 minute warm up to get good temp in the tires about 50C with SP heatsink no fan.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
