Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 01-08-2011, 05:18 PM   #2161
can i use the current stock boost profile with 1s racing? just got myself a 1/12 car and have a xerun 2.0 esc laying in the box (not the 1s version)
Hatebreed is offline   Reply With Quote
Old 01-08-2011, 07:00 PM   #2162
COBRARACING's Avatar
Originally Posted by rbakker View Post
Thanks a lot offcourse for the great products and communication.
Got a question about 1 things from the manual, could someone explain it to me in very simple English:
0°to 38°with the trim step of 1°
(The actual max Boost Timing is 30°. If the setting value is more than 30°, the Turbo Timing will be functional with the first priority )
It means the timing now goes from 0 degree to 38 degree with 1 degree increases at a time .if your normal timing is set above the 30 degree benchmark the turbo timing will automatically come in.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-08-2011, 07:02 PM   #2163
Yes the current turbop stock software will work with your 2.0 but remeber when ruinning the esc in your 1/12 car you will need a booster .
Old 01-08-2011, 07:04 PM   #2164
Originally Posted by mc4798 View Post
Thank you very much.
One more quick question, Is there a smaller capacitor that can be used for the xerun v2.0 ?
yes you can but you have to make sure the capacitor is low esr .Low internatla resistance to smaooth out the ripple current .
hobbywing has the 2 x capacitor bank or the super cap 4 . anything that is 10v to 16v will be fine but low esr .
Old 01-08-2011, 07:11 PM   #2165
glide 1's Avatar
besides the voltage values (10v-16v) what values do we want in farads. I also think solid capacitors would be better than the regular ones that come in the older Xerun ver 2.0
glide 1 is offline   Reply With Quote
Old 01-08-2011, 07:43 PM   #2166
mc4798's Avatar
Is it possible that you could shoot me a link to what I would need ?
I search 10v low esr and this is what I am finding.
Thanks again
mc4798 is offline   Reply With Quote
Old 01-08-2011, 07:46 PM   #2167
1) Do you mean that if you just want a lot of timing, that comes lineair with the rpm and you dont want the extra timing from the turbo..?
Then dont use boost 25 and turbo 10 (not linear on rpm),
but just only use boost 35 (linear on rpm)
Or do you mean:
2) When i use 38 timing, then the first 30 degrees of timing will occur between the start and the end rpm,
and when it reaches 30 degrees, automaticly the turbo is added...
or is it just this simple:
3) When is use 38 of timing boost and 10 turbo,
it only uses 30 timing boost and the 10 turbo and just dont uses the 8 extra timing boost from the start....
Could you explain once more, just want to know what we are doing....
rbakker is offline   Reply With Quote
Old 01-08-2011, 10:20 PM   #2168
33uf-100uf is enough the larger you go the bigger the capacitor gets in its capacity but also in physical size so there is no benefit really in saving room .
Old 01-08-2011, 10:26 PM   #2169
Or do you mean:
Old 01-08-2011, 10:53 PM   #2170
with this much community support and hardware versatility (and please don't mention the price), HW makes the BEST ESC in the world. Cheers!
cheapskate.brok is offline   Reply With Quote
Old 01-08-2011, 11:30 PM   #2171
Just got back from a full day of racing (10 Hours Worth!) And the new software is amazing. Its everything I was asking for.
Its going to take alittle while to maximize the timing/gearing on the car though. Tomorrow I might play around with the extra boost.
Tonight i ran 82mm RollOut , with 1000 start RPM, 150rpm/deg, 30 Boost, 10Turbo, with 15 deg on the end bell (55 deg total - 17.5BL Novak). The car had a ton of rip on the infield, and didnt feel lacking down the straight. It did get alittle warm though (around the 6-7 minute mark you can feel it drop alittle).
Last race night (518Stock) I was running 11.3's. Tonight I was running 10.5's.
Shawn.
Shawn68z is offline   Reply With Quote
Old 01-09-2011, 03:14 AM   #2172
InZane's Avatar
Originally Posted by csracing View Post
Says "Hobbywing USB Link V1.63" at the top of the interface. I see other V3.0 configurations, just nothing for no timing software.
CSR
I have the same problem ...
InZane is offline   Reply With Quote
Old 01-09-2011, 03:37 AM   #2173
millbank's Avatar
I can't even download the hobbywing usb software?
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 01-09-2011, 03:44 AM   #2174
It's here;
Hi Guys
Just an early treat for the weekend i have two links for the new software that can be downloaded forget monday as i said ive decided early as i know what the racer and hobbiest is like we want it now now now because thats how i would be .lol
The software is for stock racing 1/10th .
Please read the instructions first as there are quite a few options you might not understand .But i can tell you that the brakes have gone from 4 options to 8 and more steps have been added in programming especially with timing.
links are below
thank you all for supporting hobbywing .
http://www.filefactory.com/file/b4g9....63_110105.rar
http://www.filefactory.com/file/b4g9...are_110106.doc
any download problems please let me know via email teamcobraracing@gmail.com
enjoy your racing guys and i hope to see some of you at the TITC in february in thailand
Old 01-09-2011, 03:45 AM   #2175
Hold on, is that a Justock?
