Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-20-2010, 01:57 PM   #1996
M7H
M7H's Avatar
Originally Posted by morgy View Post
just purchased a hobbywing xtreme got it fitted to my car then proceded to try and set it up but read through the instructions only to find i couldn't do it through the setup button !!! looks like i'll need an LED program card or a LCD program box, GUTTED !!!!
Only if you install a software version with only 10 settings, you don't need the program box, if you install the latest software version with 15 setting, you do need the box....
Serpent
M7H is offline   Reply With Quote
Old 12-20-2010, 02:36 PM   #1997
COBRARACING's Avatar
Originally Posted by zamrioo2 View Post
this Q has been asked at 2 thread, but no response... hope here i will get the answer... i am user of ezrun 5.5t n xerun 2.1 120A...
for the esc with dynamic timing (without supercharge/turbo timing)... let say the motor rpm limit is about at 8000rpm on load... and max esc timing is 20deg (motor timing is 0deg) ...
1. is that mean at max rpm/8000rpm will be at max timing/20deg (same with max speed i guess)...?
2. if the throttle at 40%, is the timing introduced to the motor will be at 8deg...? (40% of 20deg)
3. same with no2 Q, if throttle trigger hard from 0% - 100%... is max timing will be introduced at low rpm too...?
4. max speed is max rpm... is the max speed is about limit of current (max Amp) which apply to motor from esc, or it is caused by max timing...?
1.no motor has zero timing may it be mechanical or fixed .Mechanical on zero position still have 3 -6 degree timing not matter what brand and fixed timing say zero but they sit at about 18-22 degree.
2.yes will be at 40% as the timing set to say 26 degree doesnt mean you will have the max timing at 40% throttle it will ramp up in a linear movement as you throttle to full power .
3.yes you will have max timing at full throttle even at low rpm as the rpm ramps up as your ramming the power at an instant.
4 caused by max timing as the timing will control the current flow through the esc.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-20-2010, 06:09 PM   #1998
thanc a lot cobraracing... appreciate your explaination...
zamrioo2 is offline   Reply With Quote
Old 12-21-2010, 08:23 PM   #1999
In the last couple of months i have been doing a crack down on fake hobbywing goods and online stores .
There seesm to be alot of them out there and we are working through everyone of them .so be careful what you buy and from where you buy it from .
They seem to use the hobbywing logos on there sites and pictures also but all products are 100% fakes .especially the aircraft and ez run 35 amp and 60 amp .
This website is one of them
http://www.targethobby.com/
I will post more and more as they surface .
Our customers are very important to us and we must protect not only them but our brand and product.
please if you see anything out there or you have bought a product that just doesnt seem right to you please let us know by email at
ive posted some sample the bec we have only two wire config not three like this one . our circiuts are red not green like these ones and have a look at the solder quality and these are heatshrinked hobbywing wow.and many more .
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-25a-back.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-f-flying-technology-co_-ltd.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-targethobby_2.jpg
Old 12-21-2010, 10:23 PM   #2000
jake95's Avatar
Trader Rating: 27 (100%+)
can you run the hobbywing xerun without the fan with 17.5 motor
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 12-21-2010, 10:41 PM   #2001
yes you can but with no turbo settings .
Old 12-23-2010, 03:24 PM   #2002
Hey Cobra,
Heard that there is a new stock software on the way, one that has a nicer turbo rampdown..? Is that true?
Regards,
Roy
rbakker is offline   Reply With Quote
Old 12-23-2010, 03:32 PM   #2003
Default funny u shld say that
Originally Posted by rbakker View Post
Hey Cobra,
Regards,
Roy
I started a thread on the smoothest esc - and a chap called singhen (I think) indicated that new software is on its' way
Lohan is offline   Reply With Quote
Old 12-23-2010, 03:44 PM   #2004
True, wasn`t sure, so i asked here by Cobra, he should know more,
sent a PM to the guy from youre thread too.
Maybe Cobra cann explain some off the features.
Old 12-23-2010, 04:16 PM   #2005
jake95's Avatar
i need a fdr with software 518 with speedpassion v3 21.5 motor and hobbywing extreme stock
XRAY✯NOSRAM✯SANWA
Old 12-23-2010, 04:30 PM   #2006
Originally Posted by jake95 View Post
i need a fdr with software 518 with speedpassion v3 motor and hobbywing extreme stock
You cann read back this thread, it is asked a thousand times...
off course we should know how many turns the motor is...
Old 12-23-2010, 10:30 PM   #2007
begrie's Avatar
The more you read the more knowledge you Gain
Please refer to previous page, there a lot of info... you might find sumthin interesting tho
Gud luck searching m8
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 12-23-2010, 10:59 PM   #2008
Hey Cobra,
Regards,
Roy
Guys you are so quick i got to give it to you yes there is something new coming out as we are going from your normal c programming to C++ so many news things coming your way in the new year .
Old 12-24-2010, 01:58 AM   #2009
chinaman's Avatar
The manual has some recommendations ...
FDR 3.5 - 5.5
i guess start with 4.5 and work from there ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 12-24-2010, 09:40 AM   #2010
Hey Cobra,
man we are fast....lol....for sure when we drive the HW..!!
Nice to hear that c++ is on the way, once learned to use it when studying.
Think it`s difficult.
Hope you will give us a nice write up when its there.
Kind regards,
Roy
PS. more and more people are starting to use the HW overhere in the Netherlands.
