Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-15-2010, 12:55 PM   #1951
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can the blue & black 60amp xerun ver 2.0 or 2.1 be used in Roar Sportsman class?
with light flashing mode?
they are not on the list tho, only speed passion
LOSI123 is offline   Reply With Quote
Old 12-15-2010, 01:08 PM   #1952
COBRARACING's Avatar
There on the arrcmcc list so since your in Australia roar doesnt matter for now .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-15-2010, 01:11 PM   #1953
csracing's Avatar
Trader Rating: 22 (100%+)
Cobra,
Check your email regarding ongoing brake problems.
CSR
csracing is offline   Reply With Quote
Old 12-15-2010, 01:12 PM   #1954
Originally Posted by RevMaxx View Post
just a Q: what happens to HW ESCs if u accidentally plugged the battery terminals in reversed polarity order?
switched on then your in trouble but it all depends how quick you turn it off.
Old 12-15-2010, 01:43 PM   #1955
Some information about brakes .
Now it seems that some of you dont really understand the braking system on the HW esc's as i have received emails about not enough brakes ,delays in brakes etc .
Now the software with brakes hasnt changed since the day HW started so to say that software has change the brakes as to no improvement is not true .
here is some info for you to understand the braking system and how it works .
maximum brake force: The esc provides proporsional braking function.The Braking force relates to the position of the throttle stick .Maximum braking force refers to the force when the throttle stick is located at the top (end point) of the reverse zone .A very large brake force can shoten the braking time but can stip your spur gear.
Initial brake force : Also known as minimum brake force ,and it refers to the force when the throttle lever is located at the initial position of the reverse zone .The default value is is equal to the drag brake force so the braking effect can be very linear and smooth.
Drag Brake force :set the amount of drag braking applied at the neutral throttle position to simulate the light braking effect of a neutral brushed motor while coasting.
The are only two reasons why you wouldnt have enough brakes
1.braking settings are wrong .
2.esc is on its way out .
according to checks on older software that i was sent by email we have concluded after checks that nothing has changed along the lines of software upgrades for brakes especially less brakes .
Most times it can also be the speed and setting functions of your radio .
next i will post info about turbo settings so you all understand how it works .
regards Angelo
Old 12-15-2010, 01:50 PM   #1956
csracing's Avatar
I will make a video in the next couple days that shows what I'm talking about. I've been involved in R/C racing for 20 years now so I'm quite aware of all of the brake settings and how they interact. For the record, I have HW, Novak and Tekin ESCs currently. The HW is the only speedo that will not go full 100% brake from any forward trigger position without a physical pause in neutral with the trigger. With the pause, I get proportional (100% in this case) brakes. Without the pause, I get a delay in the time it takes to get full brakes (solid green LED).
Pretty basic issue. Perhaps that's just the way the HW speedo works. If so that's fine, but I don't belive it's working as intended.
CSR
Old 12-15-2010, 02:09 PM   #1957
2wdrive's Avatar
I have a question about the new hobbywing xerun motors, The ones that have the bullet connectors for the motor wires and the redesigned sensor connector. They have fixed timing so how much timing do the 10.5t and 13.5t have?
2wdrive is offline   Reply With Quote
Old 12-15-2010, 02:30 PM   #1958
Im sure the timing is fixed at 18-22 degree.anyone who tells you zero is lieing no matter what brand or motor .
Old 12-15-2010, 02:32 PM   #1959
CSR
You dont have to do a video of it but you can contact me via skype at
teamcobraracing and this way we can have a video conference and i can see 100% what your talking about and the issues you have .
Old 12-15-2010, 02:59 PM   #1960
csracing's Avatar
Unfortunately I have not stepped into the latest decade with video interfacing on my PC..
I'll put something simple together and get you a link or a file to review.
I appreciate the support.
CSR
Old 12-15-2010, 03:10 PM   #1961
Default HELP ME WITH SOME SETTINGS
I am on the verge of buying a Corally Red 13.5 motor, and wanted to know if someone has a good set up for it with 518 software.
Lohan
Lohan is offline   Reply With Quote
Old 12-15-2010, 05:53 PM   #1962
Cobra,have a PM,Thanks!
bazspencer is offline   Reply With Quote
Old 12-15-2010, 11:41 PM   #1963
LOSI123's Avatar
thanks guys, also
Can you run the blue 60amp ver 2.1 with a 13.5 "boosted settings" in a Touring car and still not need the fan?
Do you think i would get away with it?
Old 12-15-2010, 11:53 PM   #1964
2wdrive's Avatar
Thanks, In combination with the xerun esc there is a temperature cuttoff if the motor gets too hot. Do you know by any chance how much the temperature cutoff is? I can't find it on the site or manual.
Old 12-16-2010, 12:38 AM   #1965
Hi Angelo,
Drag Brake force - is this only in the neutral postion or the entire throttle range (including positive throttle).
i.e. if you go from 100% to 80% throttle, increasing this value will make you slow down from 100% to 80% in a shorter amount of time.
I feel the drag brake force is in effect for the entire throttle range when I change this setting.
Thanks.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is online now   Reply With Quote
